Connecting 2 Arduinos via TX/RX pins
I have a project to make about controlling a small train model wirelessly like sending PWM and HIGH/LOW orders to it. I do have UART wireless modules which work by serial communication, I got it working on PICs as I have a little experience in C language and it works by wires the same it works by the modules. Two codes, one transmitting and the other for receiving.
I tried to get working on Arduino Unos but with no luck, it seems like I can't write the proper code. I just need a sample code to send HIGH/LOW states from on Arduino to another serially.
Thanks in advance :slight_smile:
What have you tried? HIGH/LOW states of what? You send information over the serial port, just like you were sending it to the Serial Monitor. If you want to send information to the effect that pin 8 was HIGH, you might send "<8, 1>".
Is the connection on the hardware side correct?
Arduino1 TX goes to Arduino2 RX vise versa as you are talking on connecting two arduino's
PaulS:
I tried these codes:
Transmitter:
const int buttonPin = 2;
const int ledPin =  13;
int buttonState = 0;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  buttonState = digitalRead(buttonPin);
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    Serial.print("a" );
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW);
    Serial.print("b" );
  delay(2);
Receiver:
char x;
  x=Serial.read();
  if (x=='a') {
    // turn LED on:
  else {
    // turn LED off:
    digitalWrite(ledPin, LOW); ;
  delay(2);
I'm sure there is something wrong in them, but I can't figure it out.
gharryh:
Yes I did that.
One problem
  x=Serial.read();
  if (x=='a') {
    // turn LED on:
  else {
    // turn LED off:
If there are no characters (which will be just about every time this code runs) x will == -1, therefore you will always execute the else block.
Even when you finally get an 'a' the LED will only light until the next loop, about 50uS later. With the right tools you would see than, but the eye won't.
Look up Serial.available(), and also don't have an else, test for 'b'
Rob
Are the grounds of the two Arduinos connected?
Graynomad:
One problem
  x=Serial.read();
if (x=='a') {
   // turn LED on:
 else {
   // turn LED off:
______
Rob
I will try that and see.
PaulS:
No, that is the point I think, I need them to be away from each other and control them remotely, so no wires are connected between them, the same I did with PICs.
EDIT: I connected both grounds and it worked, but this won't help me in my project, can I get it to work without connecting the grounds?
No. If the Arduinos can be connected by wires from Rx to Tx and from Tx to Rx, connecting the grounds shouldn't be a problem. You'll need to explain why two wires is OK, but three wires is not.
I'm confused; are you testing your code with or without the wireless modules? If you're testing without them to check your code then you will need to connect RX, TX and ground between the arduinos. If the wireless modules are in place, then of course, no connection between arduinos is required.
PaulS:
The two wires are just for testing, I said that I'm gonna connect them by UART wireless modules which work the same way the wires do. That's why I don't want the ground connected.
wildbill:
I'm testing with wires for now, I will try with the modules and see what happens with no wires attached.
When you go wireless, you won't need to connect the grounds. Wired, you do.
PaulS:
Thanks a lot for your help guys. I will try it now
