Connecting arduino to another serial device
Hello.
I have a device that recieves data over serial port, Im using a terminal on windows to send data to that device via an USB-Serial Adapter and it works OK.
I need to send the same data but using arduino instead of the PC but Im getting some weird behaviour... every character looks like if it was "randomized".
I'm using the same USB serial adapter and terminal on the PC to see what the arduino is sending and, if I send 'a' (97), recieve 'O' (79), if I send 'c' (99) ,recieve 'N' (78)
This is a very simple sketch that works OK on the serial monitor of the arduino IDE ( I get a b c d e ... etc), but when I use the serial adapter or the final device every thing gets weird. Im getting the same issue no matter if I use Software serial or the real Serial. I've tried adding \r and \n, and used serial.print() and serial.write() but still the same
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  mySerial.begin(9600);
  pinMode(13, OUTPUT);
char cont = 'a';
    Serial.print(cont);
  digitalWrite(13, HIGH);
  digitalWrite(13, LOW);
  cont++;
In the example I get: 5E 17 5D 2E 5C 0B 5B 2D 5A 16 59 2C 58 05 57 2B 56 15 55 2A 54 0A 53 29...... :smiling_face_with_tear:
I dont know if I have explained myself...
But would appreciete any help.
Thank you
Your seeing the numeric values, not the ASCII characters.
ASCII table.
I assume that you have an Arduino UNO which you have connected with PC using a USB Port. You are sending the characters - a, b, c, d, ... to the OutputBox of the Serial Monitor and they are appearing well.
You have created a SUART (Software UART Port) Port using DPin-10, 11 and there is no use of this port in your sketch of post #1.
So, I have not understood what you are doing to achieve what?
Hello to everyone, Thanks for the answers.
Im aware of the ascii table, the problem was on the serial adapter.., Im using another one and is working as expected now.
Thank you.
You have not told what you are trying to achieve? What is the purpose of the mySerial(10, 11) Port?
