Hi, I was looking to see if I could connect 9 Arduino UNOs to a Raspberry Pi 4?
you could try plugging the UNO USB cables into the RPi USB ports (would require a USB expander for 9 UNOs)
each UNO would create a virtual serial port which you could access as /dev/ttyUSB0, /dev/ttyUSB1, etc
what programs were you planning to run on the RPi?
give more details of the overall project?
Welcome to the forum
What type of data do you want to pass between the Pi and the Unos and why so many Unos ?
Bear in mind that the Uno GPOI pins operate at 5V whilst the Pi operates at 3.3V
Thanks, I am trying to run motors on the arduinos and run an ai camera on the Pi 4.
how many motors/UNO?
how far apart are the UNOs?
how are you powering the system?
as a quick check I connected nine ESP32 board to a RPi 3B+
ran the following Python program
import serial
from serial.tools import list_ports
if __name__ == "__main__":
for port in list_ports.comports():
if "USB" in port.hwid:
print(f"Name: {port.name}")
print(f"Description: {port.description}")
print(f"Location: {port.location}")
print(f"Product: {port.product}")
print(f"Manufacturer: {port.manufacturer}")
print(f"ID: {port.pid}\n")
which displayed
raspberrypi:~ $ python3 ListCOMports.py
Description: CP2102 USB to UART Bridge Controller - CP2102 USB to UART Bridge Controller
Product: CP2102 USB to UART Bridge Controller
Manufacturer: Silicon Labs
Description: USB2.0-Ser!
Product: USB2.0-Ser!
Manufacturer: None
Description: USB Serial
Product: USB Serial
Manufacturer: None
Product: USB Serial
Manufacturer: None
Product: USB Serial
Manufacturer: None
Description: Feather RP2040 CAN - Board CDC
Product: Feather RP2040 CAN
Manufacturer: Adafruit
Description: USB Single Serial
Product: USB Single Serial
Manufacturer: None
a Java terminal emulator displayed
Thanks!
