I'm new and I need help. I don't know how to connect BME280 to ESP8266(WeMos D1 mini) via SPI.
I know I should do this like that:
SCK (SPI Clock) GPIO 14
SDO (MISO) GPIO 12
SDI (MOSI) GPIO 13
CS (Chip Select) GPIO 15
I have problem with GPIO15, pinout reference says that input needs to be pulled to GND. I have read that it needs resistor to work or it will never boot up(bcs its need 0 to boot up).
This is my solution:
Will it work?
Guys, help me pls and sorry for my poor english.
PS.
I have to use SPI bcs I'm already using I2C to connect DHT22.
I2C is a shared bus. You can put several devices on it.
But I have to admit that I'm unaware of a DHT22 with an I2C interface. Do you have a link to this device? I know there's the AM2320; is that what you meant?
A DHT is not an I2C device. So you can not combine it with another I2C device on the bus (I2C pins). You can only combine I2C devices on the I2C bus if the pins are used for I2C.
Your schematic in the opening post might work (I think it will but I'm not deep into ESP8266). The easy test is to built it (on e.g. a breadboard) and test.
Pulling D8 / CS low will, as far as I understand it, put the BME280 in SPI mode. But I have never used the BME280
You are right my DHT is not I2C device it's probably 1 wire connection(if I'm wrong please correct me). So my idea now is very simple and I want to ask you will it work???
To be everything more simple I decided to connect BME280 over I2C(GPIO4 and GPIO5) and DHT22 as 1-wire connection to GPIO14. Screenshot below to show what I want to do:
