Connecting G213V Gecko Driver to Arduino Mega
Hey everyone,
So I recently purchased a G723-400-4 Geckodrive motor and a G213V Digital Step Drive from Geckodrive also. Now the G213V calls for a step input, direction input, and a ground. I looked at a few libraries that people recommended but I just can't seem to get it to work. Does anyone have a sketch written that they've used to control a Gecko Stepper Driver before? Just so I can test it and start to understand how it works?
From what i've read Pin 1 would be the steps, Pin 2 would be direction, and GND would be my common it's just the code I can't seem to figure out.
Thanks for any help.
Assuming it takes 5v signals that are compatible with the Arduino I/O pins then the AccelStepper library should work fine. You need to initialize your AccelStepper instance as DRIVER.
You should not use Arduino pins 0 and 1 as they are used for serial communication.
This simple code should also work (assuming you match the pins to the driver)
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// as posted on Arduino Forum at http://forum.arduino.cc/index.php?topic=208905.0
byte directionPin = 6;
byte stepPin = 5;
int numberOfSteps = 100;
byte ledPin = 13;
int pulseWidthMicros = 20;  // microseconds
int millisbetweenSteps = 25; // milliseconds
  Serial.println("Starting StepperTest");
  digitalWrite(ledPin, LOW);
  delay(2000);
  pinMode(directionPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(directionPin, HIGH);
  for(int n = 0; n < numberOfSteps; n++) {
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(pulseWidthMicros);
    digitalWrite(stepPin, LOW);
    delay(millisbetweenSteps);
    digitalWrite(ledPin, !digitalRead(ledPin));
  delay(3000);
  digitalWrite(directionPin, LOW);
...R
Thank you for that. I'll definitely give that a try and let you know how it works out.
Well I tried it. The motor made some noise and turned a bit but not much else. Not really sure what went wrong.
The power supply is more than enough to power the motor I believe and the pins were all hooked up correctly.
Any ideas what could have happened?
