where do i connect the gnd of the rs485 to ttl?
you connect the RS485 A, B and GND to the A B GND of the other RS485 modules
hi i tried connecting the npk to the pro mini with the RS485 3V3 module.
connection:
code:
// Arduino pro mini AltSoftSerial test using pin 8 Rx and 9 Tx
// note Serial baudrate is 57600 (115200 give problems)
// works with RS485 board with Auto Transmit/Receive Switching Control
// e.g. https://quartzcomponents.com/products/rs485-ttl-module-with-protection-auto-transmit-receive-switching
#include <AltSoftSerial.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define RX 8
#define TX 9
// pro mini RX pin 8
// pro mini TX pin 9
const byte nitro[] = {0x01, 0x03, 0x00, 0x1e, 0x00, 0x01, 0xe4, 0x0c};
const byte phos[] = {0x01, 0x03, 0x00, 0x1f, 0x00, 0x01, 0xb5, 0xcc};
const byte pota[] = {0x01, 0x03, 0x00, 0x20, 0x00, 0x01, 0x85, 0xc0};
byte values[11];
AltSoftSerial mod;
Serial.begin(57600);
mod.begin(57600);
pinMode(RX, OUTPUT);
pinMode(TX, OUTPUT);
// put RS-485 into receive mode
digitalWrite(TX, LOW);
digitalWrite(RX, LOW);
byte val1, val2, val3;
Serial.print("Nitrogen: ");
val1 = nitrogen();
Serial.print(" = ");
Serial.print(val1);
Serial.println(" mg/kg");
delay(250);
Serial.print("Phosphorous: ");
val2 = phosphorous();
Serial.print(val2);
delay(250);
Serial.print("Potassium: ");
val3 = potassium();
Serial.print(val3);
byte nitrogen() {
// clear the receive buffer
mod.flushInput();
// switch RS-485 to transmit mode
digitalWrite(TX, HIGH);
digitalWrite(RX, HIGH);
delay(1);
// write out the message
for (uint8_t i = 0; i < sizeof(nitro); i++ ) mod.write( nitro[i] );
// wait for the transmission to complete
mod.flush();
// switching RS485 to receive mode
// delay to allow response bytes to be received!
delay(200);
// read in the received bytes
for (byte i = 0; i < 7; i++) {
values[i] = mod.read();
Serial.print(values[i], HEX);
Serial.print(' ');
return values[4];
byte phosphorous() {
mod.flushInput();
delay(1);
for (uint8_t i = 0; i < sizeof(phos); i++ ) mod.write( phos[i] );
mod.flush();
delay(200);
Serial.print(' ');
return values[4];
byte potassium() {
mod.flushInput();
delay(1);
for (uint8_t i = 0; i < sizeof(pota); i++ ) mod.write( pota[i] );
mod.flush();
delay(200);
Serial.print(' ');
return values[4];
but the serial monitor prints these values:
have you a USB-RS485 dongle ?
plug it in a PC connect A and B to the RS485-TTL board and you should be able to communicate between pro mini running the program of post 24 and a terminal emulator on the PC - see my test in post 16
That's an interesting choice of colour for the 4 wires on the connector to the RS485 module: GND appears to be a red wire and VCC a black wire....
hi! can i just use an 8 bit logic converter (i have one) instead to connect the MAX485 to pro mini?
UPDATE: it finally workeddd. i just used connected the vcc of the MAX485 to the level converter and connected the rest of its pins to the pro mini.
thank you for your help guys <333
