Hello,
I think you use I2C and not SPI !!
SDA and SCL are I2C signals.
It is very simple :
for OLED you have to determine the DeviceAdresse by a I2C scanner, if you do not know :
#include <Wire.h>
Wire.begin();
Serial.println("\nI2C Scanner");
byte error, address;
int nDevices;
Serial.println("Recherche en cours...");
nDevices = 0;
for(address = 1; address < 127; address++ )
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial.print("Equiment I2C trouve a l'addresse 0x");
if (address<16)
Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
nDevices++;
else if (error==4)
Serial.print("Erreur inconnue a l'address 0x");
if (address<16)
Serial.print("0");
Serial.println(address,HEX);
if (nDevices == 0)
Serial.println("Aucun Equipement I2C trouve\n");
Serial.println("Fini\n");
delay(5000);
and then you use your oled device with this adress, here an example with the display I use :
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
the adress is : 0x3C
For RTC it is strange, you do not need to define adress, but It works perfectly, so the combined code is like :
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
// rtrc + oled
DS3231 clock;
RTCDateTime dt;
// oled
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Initialize DS3231
Serial.println("Initialize DS3231");;
clock.begin();
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
