connection refused error for multiple http request
hi
i am using esp8266 module with arduino uno board.
i am able to upload the sketch in the esp8266 and it works fine until i make another http GET request.
ERROR
load 0x4010f000, len 1384, room 16
tail 8
chksum 0x2d
csum 0x2d
v4ceabea9
~ld
[HTTP] GET... code: 200
{"Description":"SG 923 AMD 16:30 SCH "}
[HTTP] GET... failed, error: connection refused
esp8266 code
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#define USE_SERIAL Serial
ESP8266WiFiMulti WiFiMulti;
    USE_SERIAL.begin(115200);
    WiFi.mode(WIFI_STA);
    WiFiMulti.addAP("DIGISOL", "edot2018");
    if((WiFiMulti.run() == WL_CONNECTED)) {
        HTTPClient http;
        USE_SERIAL.print("[HTTP] begin...\n");
        http.begin("http://192.168.1.12/FlightStats/api/Flight/GetArrivingFlightsStatus/"); //HTTP
        USE_SERIAL.print("[HTTP] GET...\n");
        int httpCode = http.GET();
        if(httpCode > 0) {
            USE_SERIAL.printf("[HTTP] GET... code: %d\n", httpCode);
            if(httpCode == HTTP_CODE_OK) {
                String payload = http.getString();
                USE_SERIAL.println(payload);
            USE_SERIAL.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
        http.end();
    delay(5000);
help plz
esp8266 code
    delay(5000);
help plz
That last part won't even compile.
Why do you need ESP8266WiFiMulti? Post a link to this library.
delay(5000);
help plz
Sorry this "help plz" was suppose to be outside the code tag ::slight_smile:
if there are more then one wifi network then it selects best of those two.
but i think wifi should not affect the http get command, because i am connecting to wifi in the setup at once in the setup.
and i am able to get the http code 200 twice after that m getting connection refused error.
If you are sometimes able to connect, and sometimes not, I think you should be looking at the server to see why it is refusing some connections.
We don't do text-speak here.
but this code works without any error with the robotDyn Uno wifi board.
Any news on this? I have the same problem. My first GET succeeds, but all subsequent GETs fail with 'connection refused'. Here is my function which is called from a timer every 60 seconds. I have also tried calling the function from a button press instead of the timer. The WIFI status is always reported as 'CONNECTED'. I also have a 'ESP8266WebServer' running which is accessible.
void updateDomoticz(){
  if(!connected){
    Serial.println("Not connected to WIFI");
  }else{
    String str;
    if(relayStatus==1)
      str = "/json.htm?type=command&param=udevice&idx="+String(data.idx)+"&nvalue=1&svalue=On";
      str = "/json.htm?type=command&param=udevice&idx="+String(data.idx)+"&nvalue=0&svalue=Off";
    Serial.println("Sending:"+str);
    HTTPClient client;
    client.begin(String(data.IP),data.port,str);
    int resp = client.GET();
    if(resp<0){
      Serial.println("Domoticz failure:"+client.errorToString(resp));
    }else{
      Serial.println("Domoticz responded with "+String(resp));
    client.end();
kingrolo:
Have you found a solution ?
I'm getting the same issue. I have 3 instances on the HTTPClient and they all work once only. I'm definitely calling end. https.GET() returns 0 or less and https.errorToString(httpCode).c_str() is connection refused. Everything was fine until I tried to use https and added client->setInsecure(). Snipit below.
if (WiFi.status() == WL_CONNECTED) {// Check WiFi connection status
std::unique_ptrBearSSL::WiFiClientSecureclient(new BearSSL::WiFiClientSecure);
client->setInsecure();
HTTPClient https; // Declare an object of class HTTPClient
https.begin(*client, url); // Specify request destination
int httpCode = https.GET(); //Send the request
if (httpCode > 0) { // Check the returning code
line = https.getString(); // Get the request response payload
quoteString=String("HTTPS GET failed, error:") + https.errorToString(httpCode).c_str();
Serial.println(quoteString);
https.end();
return false;
https.end(); //Close connection
// Serial.print("Response :"); Serial.println(line); // debug info
quoteString="Wifi connection failed";
return false;
