Connection Timed Out Error Using Modbus
I am trying to pull information from the Renogy DC-DC Battery Charger via RS485 and Modbus communication. I am using the Arduino MKR WIFI 1010 and the Arduino MKR 485 Shield with it. In order to communicate I am using a RJ45 cable. My problem is when I run my code (Attached below), I get an error message saying, "Connection timed out." Does anyone have any fixes?
#include "ArduinoRS485.h"
#include "ArduinoModbus.h"
float voltage;
  delay(1500);
  if (!ModbusRTUClient.begin(9600)) {
    Serial.println("- Failed to start Modbus RTU Client!");
    while (1);
  voltage = readVoltage();
  Serial.print("Battery Voltage: ");
  Serial.print(voltage);
  Serial.println(" V");
  delay(3000); // Delay 1 second between readings
float readVoltage() {
  float voltage = 0.0;
  // Send reading request over RS485 to address 0x01 and register 0x0101 (example)
  if (!ModbusRTUClient.requestFrom(0x01, INPUT_REGISTERS, 0x0101, 1)) {
    // Error handling
    Serial.print("- Failed to read the voltage! Error: ");
    Serial.println(ModbusRTUClient.lastError());
    // Response handler
    uint16_t highWord = ModbusRTUClient.read();
    uint16_t lowWord = ModbusRTUClient.read();
    uint32_t millivolt = (highWord << 16) | lowWord; // Combine high and low words
    voltage = millivolt / 1000.0; // Convert millivolts to volts
  return voltage;
That's a screen shot. Please never do that again.
Please read and use this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
especially the parts about posting code.
My apologies. I fixed it.
Somehow the communication doesn't function.
Schematics might tell more. Users manual for the charger might tell useful things.
I have reviewed the manual and have had no luck. I will attach pictures of my setup and wire output for the RJ45 cable. If anyone has any suggestions please let me know.
What about making it available for forum?
Charge Controller RS485 MODBUS Protocol V1.7.pdf (603.7 KB)
Since I have a new account it would not let me upload the pdf. I got it fixed though and have attached it above.
For half duplex, you should be using the Y & Z terminals on the MKR485.
Do I need to change the switches on top of the Arduino that correspond to half/full duplex, A/B, and Y/Z?
Looking at the photo in post #5, you may need to switch in the terminating resistor on Y-Z using switch 3.
This worked! Thank you for your help.
