Const and calculation problem
    qbcan CanSat example.
    This sketch reads temperature and pressure data and sends it to the Ground station
//Include the required libraries
#include <qbcan.h>
#include <Wire.h>
#include <SPI.h>
//Pressure sensor object
BMP180 bmp;
//Radio Parameters
#define NODEID        2    //unique for each node on same network
#define NETWORKID     100  //the same on all nodes that talk to each other
#define GATEWAYID     1    //Receiving node
#define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
const TempGradient = -0,0065;
const StartPressure = 1019;
const StartTemp = 283,15;
const StartAltitude = 10;
const GasConstant = 287,06;
const GravAcceleration = 9,81;
//Radio object
char payload[50];
RFM69 radio;
  //Initialize serial connection for debugging
  Serial.println("REBOOT");
  // Initialize pressure sensor.
  if (bmp.begin())
    Serial.println("BMP180 init success");
    //In case of error let user know of the problem
    Serial.println("BMP180 init fail (disconnected?)\n\n");
    while(1); // Pause forever.
  //Initialize radio
  radio.initialize(FREQUENCY,NODEID,NETWORKID);
  radio.setHighPower(); //To use the high power capabilities of the RFM69HW
  radio.encrypt(ENCRYPTKEY);
  Serial.println("Transmitting at 433 Mhz");
  double T,P;
  // Get a new pressure reading:
  bmp.getData(T,P);
  long Temp = (T,2);
  long Pressure = (P,2);
  //Display data
  Serial.print("Absolute pressure: ");
  Serial.print(P,2);
  Serial.println(" mb.");
  Serial.print("Temperature: ");
  Serial.print(T,2);
  Serial.println(" deg C.");
  // Calculate Altitude
  Altitude = (StartTemp/TempGradient)*(pow((Pressure/StartPressure),(-TempGradient*GasConstant/GravAcceleration))-1)+ StartAltitude
  // Display Altitude
  Serial.print("Altitude: ");
  Serial.print(Altitude);
  Serial.println(" meters high");
  //Send Data
  sprintf(payload,"T: %d C, P: %d mb.",(int)T,(int)P);
  Serial.println(payload);
  radio.send(GATEWAYID, payload, 50);
  Serial.println("Send complete");
There are the following errors:
Arduino: 1.8.1 (Windows 10), Board:"SparkFun Pro Micro, ATmega32U4 (5V, 16 MHz)"
CanSat_-_With_Altitude_V1:22: error: 'TempGradient' does not name a type
CanSat_-_With_Altitude_V1:23: error: 'StartPressure' does not name a type
CanSat_-_With_Altitude_V1:24: error: 'StartTemp' does not name a type
CanSat_-_With_Altitude_V1:25: error: 'StartAltitude' does not name a type
CanSat_-_With_Altitude_V1:26: error: 'GasConstant' does not name a type
CanSat_-_With_Altitude_V1:27: error: 'GravAcceleration' does not name a type
C:\Users\Lars\Desktop\Cansat\Code\CanSat_-_With_Altitude_V1\CanSat_-_With_Altitude_V1.ino: In function 'void loop()':
CanSat_-_With_Altitude_V1:77: error: 'Altitude' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'StartTemp' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'TempGradient' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'StartPressure' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'GasConstant' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'GravAcceleration' was not declared in this scope
CanSat_-_With_Altitude_V1:77: error: 'StartAltitude' was not declared in this scope
exit status 1
option enabled in File -> Preferences.
I don't understand why the constants don't work and why the Altitude calculation doesn't also.
Please help, I don't know people irl who understand Arduino.
LuckyBuck:
I don't understand why the constants don't work ...
Because you haven't specified what type (uint8_t, int, long, float, etc) you want them to be.
In addition to the above comment, what is the comma supposed to do?
jremington:
It's supposed to be a decimal point.
When programming, one must remember to "be American" and use a decimal dot, not a decimal comma.
