Something like this?
if (input <537 || >487);
input=0
if (input >537 || < 1023);
map the output for forward
if (input >0 || <486);
map the out put for reverse
input=0
int16_t value = map(analogRead(pin), 0, 1024, -255, 255)
If (value < -10) //backwards
value *= -1; //flip to positive, do reverse stuff
else if(value > 10)
//do forward stuff
// stop
Change your deadzone from 10 and -10 to whatever you want
Hello dana_lynn
Consider:
int ljoystick; // ljoystick Value
int ljoystickmapped; // Value after mapping
int ljoystickfwd;
int ljoystickrev;
const uint8_t Ljoystick {A0};
const uint16_t Offset {12};
Serial.begin(9600); //Open serial port
ljoystick = analogRead (Ljoystick);
switch (ljoystick)
case 0 ... 512-Offset:
ljoystickfwd = map (ljoystick, 0, 512 - Offset, 255, 0);
Serial.print ("Forward: "), Serial.println (ljoystickfwd);
case 512+Offset ... 1023:
ljoystickrev = map (ljoystick, 512 + Offset, 1023, 0, 255);
Serial.print ("Reverse: "), Serial.println (ljoystickrev);
default:
Serial.println ("Stopp");
delay(100);
ljoystick = analogRead (PotPin); //Read in the L joystick data
//Serial.println (ljoystick); //Print analog L joystick value
ljoystickmapped = map (ljoystick,0,1023,0,255); //ljoystick mapped value
ljoystickfwd = map (ljoystickmapped,128,255,0,255); // map for forward
Serial.print ("Forward :");
ljoystickrev = map (ljoystickmapped,0,128,0,255); // Reverse map for reverse function
ljoystickrev = map (ljoystickrev,255,0,0,255);
Serial.print (" Reverse : ");
Nope, you're overthinking it again.
Didn't you say we're not using negative numbers?
Try something like:
if (ljoystick < 487) {
// this is for reverse
ljoystickrev = map(ljoystick, 0, 486, 255, 1);
ljoystickfwd = 0;
else if (ljoystick <= 536) {
// this is for the center deadband
ljoystickrev = 0;
ljoystickfwd = 0;
else {
// this is for forward
ljoystickrev = 0;
ljoystickfwd = map(ljoystick, 537, 1023, 1, 255);
Hi Paul,
Works GREAT!
I added the right joystick, and did the analogWrites. Everything is perfect.
Thanks you so much!!!!!
Hi Odometer,
I'll try your code after work today. It makes sense, so this should be interesting.
Thanks you for all your help. You people on this forum are AWESOME!!!
Dana
We do our best.
Have fun in the last days of the year and enjoy programming in C++.
Hi Paul,
In the code for the joystick, can I add a digitalWrite so that anytime the joystick is doing an analogWrite to pins 5,6,10,11 it will digitalWrite pin 2 HIGH? Once the analogWrite is off the digital pin 2 will go LOW...
Hello dana_lynn
Post your current sketch to see what happens.
int rjoystick;
int ljoystickfwd;
int ljoystickrev;
int rjoystickfwd;
int rjoystickrev;
const uint8_t Rjoystick {A1};
const uint16_t Offset {50};
switch (ljoystick)
analogWrite (11,ljoystickfwd);
digitalWrite (2,HIGH); // my digitalWrite
analogWrite (10,ljoystickrev);
default:
Serial.println ("Stop");
analogWrite (11,0);
analogWrite (10,0);
digitalWrite (2,LOW); // my digitalWrite
rjoystick = analogRead (Rjoystick);
switch (rjoystick)
rjoystickfwd = map (rjoystick, 0, 512 - Offset, 255, 0);
Serial.print ("Forward: "), Serial.println (rjoystickfwd);
analogWrite (5,rjoystickfwd);
rjoystickrev = map (rjoystick, 512 + Offset, 1023, 0, 255);
Serial.print ("Reverse: "), Serial.println (rjoystickrev);
analogWrite (6,rjoystickrev);
default:
analogWrite (6,0);
analogWrite (5,0);
type or paste code here
It appears to work, but instead of a HIGH it only has a few hundred Mv
Post your schematic too
Joystick Works.pdf (5.3 KB)
Hello dana_lynn
In case of "case default" of joystick right the port pin 2 will written to LOW.
I took them out and now it does go high, but stays high. Where can I put the digitalWrite low to get it to go low when the joystick is not being used?
Do you drive a motor shield?
I“m confused.
Make this modifcations to your sketch.
pinMode (2,OUTPUT);
Did you make pin 2 an OUTPUT mode pin?
Does using the same pin and LED for both joysticks make sense?
Inquiring minds want to know.
a7
When any of the joysticks are moved, I need to start a hydraulic pump.
The analog writes will drive the hydraulic valve PWM coils.
So I want to drive a MOSFET anytime a joystick is moved in any direction.
