c++
#include <SPI.h>
#include <WiFi.h>
#include <TimedAction.h>
char ssid[] = "yourNetwork";
char pass[] = "secretPassword";
int keyIndex = 0;
int status = WL_IDLE_STATUS;
WiFiServer server(80);
TimedAction timedAction = TimedAction(800 ,off);
#define pin0 3
#define pin1 4
#define pin2 5
#define pin3 6
#define on 0
#define of 1
Serial.println("stert");
digitalWrite(pin0, on);
digitalWrite(pin1, on);
digitalWrite(pin2, on);
digitalWrite(pin3,on);
pinMode(pin0, OUTPUT);
pinMode(pin1, OUTPUT);
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
while(true);
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to Network named: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
delay(10000);
server.begin();
printWifiStatus();
String c;
WiFiClient client = server.available();
client.setTimeout(5);
if (client) {
while (client.connected()) {
c = client.readString();
if (c=="10") {
r1_r();
l_off();
client.stop();
else if (c=="11")
r2_r();
l_off();
client.stop();
else if (c=="14")
r1_l();
r_off();
client.stop();
else if (c=="17")
r2_l();
r_off();
client.stop();
else if (c=="4")
r1_r();
r1_l();
client.stop();
else if (c=="8")
r2_r();
r2_l();
client.stop();
else if (c=="7")
r1_r();
r2_l();
client.stop();
else if (c=="5")
r2_r();
r1_l();
client.stop();
else if (c=="20")
l_off();
r_off();
client.stop();
Serial.println(c);
/*Serial.println(c.length());*/
timedAction.check();
void r1_r(){
digitalWrite(pin0, of);
void r2_r(){
digitalWrite(pin1, of);
void r1_l(){
digitalWrite(pin2, of);
digitalWrite(pin3, on);
void r2_l(){
digitalWrite(pin3, of);
void r_off(){
void l_off(){
void off(){
if (c=="")
r_off();
l_off();
c="";
void printWifiStatus() {
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.println(ip);
Imports System.Net.Sockets
Imports System.Text
Imports Microsoft.Xna
Imports Microsoft.Xna.Framework
Imports Microsoft.Xna.Framework.Input
Imports Microsoft.Xna.Framework.GamerServices
Imports Microsoft.Xna.Framework.Content
Public Class Form1
Dim oTcpClient As New TcpClient
Dim oNetworkStream As NetworkStream
Dim postBytes As Byte()
Private Sub Form1_Load(sender As System.Object, e As System.EventArgs) Handles MyBase.Load
Timer1.Interval = 50
Timer1.Enabled = True
Timer2.Interval = 700
Timer2.Enabled = False
End Sub
Sub snd(ByVal s As String)
Try
oTcpClient = New TcpClient
oTcpClient.Connect("192.168.1.73", 80)
oNetworkStream = oTcpClient.GetStream
If oTcpClient.Connected Then
postBytes = Encoding.ASCII.GetBytes(s)
oNetworkStream.Write(postBytes, 0, postBytes.Length)
oNetworkStream.Flush()
End If
oTcpClient.Close()
Catch ex As Exception
End Try
End Sub
Dim RightY, LeftY As Int16
Dim Signal, signal_old As Int16
Dim iss As Boolean = False
' Timer1.Interval = 50
Public Sub Timer1_Tick(sender As System.Object, e As System.EventArgs) Handles Timer1.Tick
Dim currentState As GamePadState = GamePad.GetState(PlayerIndex.One)
Signal = 0
RightY = (currentState.ThumbSticks.Right.Y.ToString("0"))
LeftY = (currentState.ThumbSticks.Left.Y.ToString("0"))
If RightY > 0 Then
Signal = 1 '1
La_RightY_u.BackColor = Drawing.Color.Red
La_RightY_d.BackColor = Drawing.Color.Black
ElseIf RightY < 0 Then
Signal = 2 '2
La_RightY_d.BackColor = Drawing.Color.Red
La_RightY_u.BackColor = Drawing.Color.Black
Else
Signal = 11
End If
If LeftY > 0 Then
Signal += 3 '3+4+5
La_LeftY_u.BackColor = Drawing.Color.Red
La_LeftY_d.BackColor = Drawing.Color.Black
ElseIf LeftY < 0 Then
Signal += 6 '6+7+8
La_LeftY_d.BackColor = Drawing.Color.Red
La_LeftY_u.BackColor = Drawing.Color.Black
Else
Signal += 9 '6+7+8
End If
If Signal <> signal_old Then
snd(Signal)
signal_old = Signal
Console.WriteLine(Signal)
Me.Text = Signal
If Signal = 20 Then
Else
Timer2.Enabled = True
End If
End If
End Sub
Private Sub Timer2_Tick(sender As System.Object, e As System.EventArgs) Handles Timer2.Tick
snd(Signal)
End Sub
End Class
Projects.rar (971 KB)
