That's basically a poor man's port of the BASIC STAMP code in the datasheet.
What happens is more than odd. One servo rotates clockwise very slowly and the other rotates counter-clockwise very slowly (it looks like about the same speed, in opposite directions).
Am I not doing this right at all? I'm completely new to using continuous rotation servos so I admit I'm a bit lost!
That's because 1500 microseconds is just an approximation of the zero speed value. You will have to use a 'trim' correction value for each servo as each will have it's own sweet spot value between 100% forward speed( around 2 millsec), 100% backward speed (around 1 millsec), and 0% center speed (around 1.5 millisec).
Oh, well that's great news.. I'll start experimenting
Any idea why I'm getting one servo spinning clockwise and the other counter-clockwise though? For kicks I grabbed the code for the Bundoggle robot (Bunedoggle - Take it to 11) and tried it after taking out the vision stuff and just using the movement, I get the same thing with that code - one servo goes one way, the other reverses...
Just normal variation in each servo's calibration. Play with the 1500 microsecond variable value (up or down a small amount) and you should find the value that makes each servo stay still.
Thanks man, I really appreciate it.. I was worried I was doing something horribly wrong. Looks like 1516 works for both of these..
As far as the clockwise/counter-clockwise thing goes -- doh, they're mounted in a wheel configuration so they're moving the same direction, I just have them mounted inverted.. Oops :
Those continuous rotation servos have trim pots - send the "center/stop" signal, then turn the trim pot till the servo stops. It's located right where the wire enters the servo.
