I copied the code shown below from another thread and it works (couldn't get the normal servo sweep code to work). The only problem is that the code below doesn't start the servo from the same place each time. I would like to be able to get my continuous rotation servos to self center themselves at the start of the code. Is it possible using the technique shown below? Is it possible at all with a continuous rotation servo?
//Servo control via direct access to AVR PWM registers
#define servo1control OCR1A // servo1 is connected to Arduino pin9
#define servo2control OCR1B // servo2 is connected to Arduino pin10
//servo constants -- trim as needed
#define servo1null 3035
#define servo2null 3000
// Most servos are analog devices so the exact null point may vary somewhat device to device.
// This is particularly true of continuous rotation servos.
void setup(){
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
TCCR1B = 0b00011010; // Fast PWM, top in ICR1, /8 prescale (.5 uSec)
TCCR1A = 0b10100010; //clear on compare match, fast PWM
// to use pin 9 as normal input or output, use TCCR1A = 0b00100010
// to use pin 10 as normal input or output, use TCCR1A = 0b10000010
ICR1 = 39999; // 40,000 clocks @ .5 uS = 20mS
servo1control = servo1null; // controls chip pin 15 ARDUINO pin 9
servo2control = servo2null; // controls chip pin 16 ARDUINO pin 10
void loop(){
// move servo for demonstration purposes
servo1control = 2500; // valid range is servonull +/- 1000
// - is counter clockwise
// + is clockwise
// The difference from servonull represents servo angle or,
//for continuous rotation servos, speed.
//These values may differ somewhat unit to unit
delay(3000);
servo1control = 3570;
delay(3000);
