Hi all, i'm trying to control an ac motor speed with pot (v/f), i need to make an 3 phase inverter then adjust the motor speed with pot
i want to make a proteus design simulation first.
I am unclear about how to start, many thanks for any assistance.
Hi, @vitreus
So you want to make a variable speed drive?
What power?
What voltage?
What motor?
Can you please tell us your electronics, programming, arduino, hardware experience?
Tom...
It's not clear if you need to make inverter or control inverter....
min 250 watt 230V 50hz, i dont have any motor just want to see the output on oscilloscope
i just made an inverter using only mosfet and arduino, im an electric electronic engineering student, dont have much experience.
Hi, @vitreus
For your own safety can I suggest you do this at a much lower voltage if you have no real need for 250W 230Vac?
Do you understand the basics of a VSD controller.
Tom..
Can you please post your inverter schematic?
Tom...
Sorry but we need a better resolution schematic to read.
In your CAD, "EXPORT" a jpg or png image and post it.
Thanks.. Tom..
So have it in a simulation.
Do you have any code?
If so can you please post it?
250W load, at 24V assuming 100% efficiency.
Battery current ;
P = V * I
250 = 24 * I
I = 250 /24 = 10.4Amps.
I hope you are not aiming to use 24V on the UNO Vin?
Look at the UNO specs.
Also look at MOSFET max gate voltage specs.
Tom..
const int sPWMArray[] = {500,500,750,500,1250,500,2000,500,1250,500,750,500,500}; // This is the array with the SPWM values change them at will
const int sPWMArrayValues = 13; // You need this since C doesn’t give you the length of an Array
// The pins
const int sPWMpin1 = 3;
const int sPWMpin2 = 5;
// The pin switches
bool sPWMpin1Status = true;
bool sPWMpin2Status = true;
pinMode(sPWMpin1, OUTPUT);
pinMode(sPWMpin2, OUTPUT);
// Loop for pin 1
for(int i(0); i != sPWMArrayValues; i++)
if(sPWMpin1Status)
digitalWrite(sPWMpin1, HIGH);
delayMicroseconds(sPWMArray[i]);
sPWMpin1Status = false;
digitalWrite(sPWMpin1, LOW);
// Loop for pin 2
if(sPWMpin2Status)
digitalWrite(sPWMpin2, HIGH);
sPWMpin2Status = false;
digitalWrite(sPWMpin2, LOW);
this is the code that i used.
i made this project in real life as well. the load in the simulation is just a thing for load. i used a 230v capacitor for load in real life to see the output signal. If I remember correctlyi just got around 0.4 amps output.
ofc i didnt use 24v for uno vin, i used another battery for uno.
