control a circuit
i have ready circuit which is controlled by press button. The circuit have inbuilt power supply and gnd. I want to switch on button using arduino. how could i ?
I don't understand. If you have a press button and a circuit you want to power, why not just use it directly?
regards allan
allanhurst:
regards allan
i want to arduino pin as switch to that button, instead of press.
What voltage and current does your circuit use?
Just use a servo, attach a hammer to it and control the servo to hit the button when you want to press it.
Or in other works, tell us everything about that magic circuit :wink:
(deleted)
Yeah, a (reed)relay will always work but there probably is a possibility that is not that extremely bulky...
(deleted)
septillion:
we do not have enough information to make any determinations. if the signal is to an opto and passing 5mA, how much more do you need ?
if the switch is for a 50hp motor at 208 volts... say about 150 amps....
what could we offer that was a bit more bulky ?
In all situations you can replace a switch with a relay, even for the 50hp motor. Granted, you need a proper relay.
spycatcher2k:
You could use a MOSFET or a transistor instead.
Or even plain nothing if it's just CMOS :wink:
So indeed, we need more info :slight_smile:
