i want to take a battery powered (3v) lcd thermometer, remove the thermistor and replace it with an arduino, and have the arduino set the temp the lcd display,
i know i should really control the lcd directly, but finding a 3 digit plus *C symbol 7 segment lcd is hard (can get the bare lcd's, but would need a control chip etc) and for £2.33 i got a small lcd thermometer that is in a case that i can use.
So, i'm thinking the thermistor just changes resistance as the temperature changes, the thermometer is just reading the resistance and adjusting the display accordingly.
so i just need to get the arduino to send out a resistance that changes to match the input (which will be from the serial port in the form of strings of numbers and text, one of them which will be for the temp)
my first thought is to use 2 pins as a sort of digital potentiometer, so the voltage on one pin rises as the other falls.
I've never really played with thermometers other than using a thermocouple and reading the resistance of it with an arduino.
i could be really daft and have the arduino heat up a resistor thats held against the thermistor, temps i'll be needing will be from minus 10 to plus 30 C, so getting the temp below ambient wont work with that daft idea.
Can i get some suggestions of how i might do this please.
