Control light with ESP32 with ALEXA and manual switch.
Hello, I found on the web how to connect an ESP32 to Alexa to control a lamp, everything is working only that I would like to integrate the system by manually controlling it with an manual switch (not push button).
Down there is a code tha i'm using. (without switch)
thank for your help.
*  Download the libraries:
*  https://github.com/Aircoookie/Espalexa
* Per ESP32:   https://dl.espressif.com/dl/package_esp32_index.json   Per ESP8266:   http://arduino.esp8266.com/stable/package_esp8266com_index.json
#ifdef ARDUINO_ARCH_ESP32
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
#include <Espalexa.h>
// Inizializzo il Relè al pin D1
#define RelayPin1 5  //D1
//------- #define RelayPin2 4  //D2
boolean connectWifi();
void firstLightChanged(uint8_t brightness);
// Credenziali WI-FI
const char* ssid = "";
const char* password = "";
// Nome del dispositivo
String Device_1_Name = "Luce";
//----- String Device_2_Name = "Lampada";
boolean wifiConnected = false;
Espalexa espalexa;
 pinMode(RelayPin1, OUTPUT);
//------- pinMode(RelayPin2, OUTPUT);
 // Inizializzo una connessione wifi
 wifiConnected = connectWifi();
 if (wifiConnected)
   // Metti qui il nome del tuo dispositivo
   espalexa.addDevice(Device_1_Name, firstLightChanged);
//----------- espalexa.addDevice(Device_2_Name, firstLightChanged);
   espalexa.begin();
   while (1)
     Serial.println("Cannot connect to WiFi. Please check data and reset the ESP.");
     delay(2500);
 espalexa.loop();
 delay(1);
 //Controllo del dispositivo
 if (brightness == 255)
     digitalWrite(RelayPin1, HIGH);
     Serial.println("Device1 ON");
   digitalWrite(RelayPin1, LOW);
   Serial.println("Device1 OFF");
     digitalWrite(RelayPin2, HIGH);
     Serial.println("Device2 ON");
   digitalWrite(RelayPin2, LOW);
   Serial.println("Device2 OFF");
 boolean state = true;
 int i = 0;
 WiFi.mode(WIFI_STA);
 WiFi.begin(ssid, password);
 Serial.println("");
 Serial.println("Connecting to WiFi");
 Serial.print("Connecting...");
   Serial.print(".");
   if (i > 20) {
     state = false; break;
   i++;
 Serial.println("");
 if (state) {
   Serial.print("Connected to ");
   Serial.println(ssid);
   Serial.print("IP address: ");
 else {
   Serial.println("Connection failed.");
 return state;
(Code tags added by moderator - please Edit and clean up all the extra blank lines)
gabriele_basso:
  • GitHub - Aircoookie/Espalexa: Alexa voice control for ESP8266/ESP32 (including brightness and color!)
  • Per ESP32:   https://dl.espressif.com/dl/package_esp32_index.json
    #include <WiFi.h>
    #else
    #endif
    Espalexa espalexa;
    if (wifiConnected)
    espalexa.begin();
    while (1)
    delay(2500);
    espalexa.loop();
    delay(1);
    int i = 0;
    Serial.println("");
      Serial.print(".");
      if (i > 20) {
      i++;
    Serial.println("");
    if (state) {
    else {
    return state;
