I’m trying control a stepper with a single button.
I would like it to move x amount of steps when the button is pressed and move x amount of steps the opposite direction once the button is pressed again.
// rotate stepper 1 turn with push of button at speed set by potentiometer.
// by groundFungud AKA charlie goulding.
// change step, dir, button and pot pins to match your set up
// tested with an Uno with CNC shield V3,
// hence the step, dir and enable pin numbers
// stepper set to 4X microstepping
// pushbutton toggles stepper move direction
#include <AccelStepper.h>
const byte stepPin = 2;
const byte dirPin = 5;
const byte enablePin = 8; // stepper enable for CNC shield
const byte buttonPin = 9; // wired to ground and pin 9
const byte potPin = A0;
bool moveDir = false; // stepper direction flag
long moveSteps = 800; // number of steps to move per button press
// Define a stepper and the pins it will use
AccelStepper stepper(AccelStepper::DRIVER, stepPin, dirPin);
bool lastButtonState = HIGH; // button history
pinMode(enablePin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
digitalWrite(enablePin, LOW); // enable steppers
// Change these to suit your stepper if you want
stepper.setMaxSpeed(100); // initial speed only
stepper.setAcceleration(500);
int potValue = analogRead(potPin); // read pot
potValue = map(potValue, 0, 1023, 50, 4000);
stepper.setMaxSpeed(potValue); // change the speed by pot setting.
stepper.setAcceleration(potValue / 2);
static unsigned long timer = 0;
unsigned long interval = 50; // check switch 20 times per second
if (millis() - timer >= interval)
timer = millis();
// read the pushbutton input pin:
bool buttonState = digitalRead(buttonPin);
// compare the new buttonState to its previous state
if (buttonState != lastButtonState)
if (buttonState == LOW) // button went from not pressed to prssed
Serial.println(potValue);
moveDir = !moveDir; // toggle direction
if (moveDir == true)
stepper.move(moveSteps); // move 800 steps, RELATIVE to current position
stepper.move(-moveSteps);
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
stepper.run(); // must be called very often
// ideally once every loop iteration
