CONTROL SURFACE LIBRARY - MCU Track name
Hello,
I am trying to use the CONTROL_SURFACE library to make a MIDI control surface for use with the Reaper DAW along with the CSI (Control Surface Integrator) plugin.
I am using an ESP32S3 board with two SH1106G displays connected on SPI bus. I would like to get to having a surface with 8 channels (8 faders, 8 displays, etc.) but for now I am doing my tests with only two displays.
I started from the MCU-OLED SSD1306-x2 example sketch and tried to adapt it to my needs.
I can see all the information correctly on the two displays but the strange thing is that the track names after number 8 discover and are not displayed. The other values on the other hand (VU, mute, solo, pan, etc.) are updated correctly according to the track selected on the DAW.
I try to explain myself better: if on the DAW I select (with the mouse) track 1, I correctly display the values of tracks 1 to 8; if I move to track 9 the names of tracks 9 to 16 disappear, while the rest are displayed correctly.
I would like to understand if the problem is in the sketch code, in the integration of the controller in the DAW, or in the fact that I have not understood something :slight_smile:
I am not a programmer and I am trying to learn from the example sketches and documentation - could you point me in the right direction?
Thank you very much!
Here is my sketch:
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Control_Surface.h> // Include the Control Surface library
#include <Display/DisplayInterfaces/DisplayInterfaceSH1106.hpp>
// ----------------------------- MIDI Interface ----------------------------- //
   Instantiate a MIDI interface to use for the Control Surface.
USBMIDI_Interface midi;
//USBDebugMIDI_Interface midi(115200);
// ----------------------------- Display setup ------------------------------ //
   Instantiate and initialize the SH11O6G OLED display
constexpr int8_t OLED_MOSI = 11;   // Data/Command pin of the display
constexpr int8_t OLED_MISO = 12;   // Data/Command pin of the display
constexpr int8_t OLED_CLK = 13;   // Data/Command pin of the display
constexpr int8_t OLED_CS_L = 3;   // Chip Select pin of the L display
constexpr int8_t OLED_CS_M = 9;   // Chip Select pin of the L display
//constexpr int8_t OLED_CS_R = 10;  // Chip Select pin of the R display
//constexpr int8_t OLED_CS_RR = 4;  // Chip Select pin of the R display
constexpr int8_t OLED_DC = 14;    // Data/Command pin of the display
constexpr int8_t OLED_RST_L = -1; // Use the external RC circuit for reset
constexpr int8_t OLED_RST_M = -1; // Use the external RC circuit for rese
//constexpr int8_t OLED_RST_R = -1; // Use the external RC circuit for reset
//constexpr int8_t OLED_RST_RR = -1; // Use the external RC circuit for reset
// Instantiate the L displays
Adafruit_SH1106G sh1106Display_L {128, 64, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST_L, OLED_CS_L};
// Instantiate the M displays
Adafruit_SH1106G sh1106Display_M {128, 64, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST_M, OLED_CS_M};
// Instantiate the R displays
//Adafruit_SH1106G sh1106Display_R {128, 64, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST_R, OLED_CS_R};
// Instantiate the RR displays
//Adafruit_SH1106G sh1106Display_RR {128, 64, OLED_MOSI, OLED_CLK, OLED_DC, OLED_RST_RR, OLED_CS_RR};
// --------------------------- Display interface ---------------------------- //
// Implement the display interface, specifically, the begin and drawBackground
// methods.
class MySH1106_DisplayInterface : public SH1106_DisplayInterface {
 public:
  MySH1106_DisplayInterface(Adafruit_SH1106G &display)
    : SH1106_DisplayInterface(display) {}
  void begin() override {
    // Initialize the Adafruit_SSD1306 display
    if (!disp.begin())
      FATAL_ERROR(F("SH1106G allocation failed."), 0x1106);
    // If you override the begin method, remember to call the super class method
    SH1106_DisplayInterface::begin();
    void drawBackground() override { disp.drawLine(60, 0, 60, 6, SH110X_WHITE); }
} display_L = sh1106Display_L, display_M = sh1106Display_M;// display_R = sh1106Display_R, display_RR = sh1106Display_RR;
// ------------------------------- Bank setup ------------------------------- //
   Create a bank and a bank selector to change its setting.
Bank<2> bank(4); // Create a new bank with 6 tracks per bank
// Create a new bank selector to control the bank using a push button
//IncrementSelector<2> bankselector {bank, 4};
// Create a new bank selector to control the bank using two push buttons
IncrementDecrementSelector<2> bankselector {bank, {5, 6}, Wrap::Wrap};
// -------------------------- MIDI Input Elements --------------------------- //
 * Define all elements that listen for MIDI messages.
// Main MCU LCD screen, used to get track names
MCU::LCD<> lcd {};
// Time display_L keeps track of the bar counter
//MCU::TimeDisplay timedisplay {};
// Play / Record
//NoteValue play {MCU::PLAY};
//NoteValue record {MCU::RECORD};
// Mute
Bankable::NoteValue<2> mute[] {
  {bank, MCU::MUTE_1},
  {bank, MCU::MUTE_2},
  {bank, MCU::MUTE_3},
  {bank, MCU::MUTE_4},
/*  {bank, MCU::MUTE_5},
  {bank, MCU::MUTE_6},
  {bank, MCU::MUTE_7},
  {bank, MCU::MUTE_8},
// Solo
Bankable::NoteValue<2> solo[] {
  {bank, MCU::SOLO_1},
  {bank, MCU::SOLO_2},
  {bank, MCU::SOLO_3},
  {bank, MCU::SOLO_4},
/*  {bank, MCU::SOLO_5},
  {bank, MCU::SOLO_6},
  {bank, MCU::SOLO_7},
  {bank, MCU::SOLO_8},
NoteValue rudeSolo {MCU::RUDE_SOLO};
// Record arm / ready
Bankable::NoteValue<2> recrdy[] {
  {bank, MCU::REC_RDY_1},
  {bank, MCU::REC_RDY_2},
  {bank, MCU::REC_RDY_3},
  {bank, MCU::REC_RDY_4},
/*  {bank, MCU::REC_RDY_5},
  {bank, MCU::REC_RDY_6},
  {bank, MCU::REC_RDY_7},
  {bank, MCU::REC_RDY_8},
// VU meters
MCU::Bankable::VU<2> vu[] {
  {bank, 1, MCU::VUDecay::Default},
  {bank, 2, MCU::VUDecay::Default},
  {bank, 3, MCU::VUDecay::Default},
  {bank, 4, MCU::VUDecay::Default},
/*  {bank, 5, MCU::VUDecay::Default},
  {bank, 6, MCU::VUDecay::Default},
  {bank, 7, MCU::VUDecay::Default},
  {bank, 8, MCU::VUDecay::Default},
// VPot rings
MCU::Bankable::VPotRing<2> vpot[] {
  {bank, 1},
  {bank, 2},
  {bank, 3},
  {bank, 4},
/*  {bank, 5},
  {bank, 6},
  {bank, 7},
  {bank, 8},
// ---------------------------- Display Elements ---------------------------- //
 * Define all display_L elements that display_L the state of the input elements.
// Track names
MCU::LCDDisplay lcddisps[] {
  // track (1), position (0, 40), font size (1)
  {display_L, lcd, bank, 1, 1, {0, 0}, 1, SH110X_WHITE},
  {display_L, lcd, bank, 2, 1, {66, 0}, 1, SH110X_WHITE},
  {display_M, lcd, bank, 3, 1, {0, 0}, 1, SH110X_WHITE},
  {display_M, lcd, bank, 4, 1, {66, 0}, 1, SH110X_WHITE},
//  {display_R, lcd, bank, 5, 1, {0, 0}, 1, SH110X_WHITE},
//  {display_R, lcd, bank, 6, 1, {66, 0}, 1, SH110X_WHITE},
//  {display_RR, lcd, bank, 7, 1, {0, 0}, 1, SH110X_WHITE},
 // {display_RR, lcd, bank, 8, 1, {66, 0}, 1, SH110X_WHITE},
  {display_L, lcd, bank, 1, 2, {0, 7}, 1, SH110X_WHITE},
  {display_L, lcd, bank, 2, 2, {66, 7}, 1, SH110X_WHITE},
  {display_M, lcd, bank, 3, 2, {0, 7}, 1, SH110X_WHITE},
  {display_M, lcd, bank, 4, 2, {66, 7}, 1, SH110X_WHITE},
//  {display_R, lcd, bank, 5, 2, {0, 7}, 1, SH110X_WHITE},
//  {display_R, lcd, bank, 6, 2, {66, 7}, 1, SH110X_WHITE},
//  {display_RR, lcd, bank, 7, 2, {0, 7}, 1, SH110X_WHITE},
//  {display_RR, lcd, bank, 8, 2, {66, 7}, 1, SH110X_WHITE},
// Time display
MCU::TimeDisplayDisplay timedisplaydisplay {
  // position (0, 0), font size (1)
  display_L, timedisplay, {0, 0}, 1, SH110X_WHITE,
// Play / Record
BitmapDisplay<> playDisp {
  display_L, play, XBM::play_7, {16 + 64, 0}, SH110X_WHITE,
BitmapDisplay<> recordDisp {
  display_L, record, XBM::record_7, {26 + 64, 0}, SH110X_WHITE,
// Mute
BitmapDisplay<> muteDisp[] {
  {display_L, mute[0], XBM::mute_10B, {14, 50}, SH110X_WHITE},
  {display_L, mute[1], XBM::mute_10B, {14 + 64, 50}, SH110X_WHITE},
  {display_M, mute[2], XBM::mute_10B, {14, 50}, SH110X_WHITE},
  {display_M, mute[3], XBM::mute_10B, {14 + 64, 50}, SH110X_WHITE},
//  {display_R, mute[4], XBM::mute_10B, {14, 50}, SH110X_WHITE},
//  {display_R, mute[5], XBM::mute_10B, {14 + 64, 50}, SH110X_WHITE},
//  {display_RR, mute[6], XBM::mute_10B, {14, 50}, SH110X_WHITE},
//  {display_RR, mute[7], XBM::mute_10B, {14 + 64, 50}, SH110X_WHITE},
// Solo
BitmapDisplay<> soloDisp[] {
  {display_L, solo[0], XBM::solo_10B, {14, 50}, SH110X_WHITE},
  {display_L, solo[1], XBM::solo_10B, {14 + 64, 50}, SH110X_WHITE},
  {display_M, solo[2], XBM::solo_10B, {14, 50}, SH110X_WHITE},
  {display_M, solo[3], XBM::solo_10B, {14 + 64, 50}, SH110X_WHITE},
//  {display_R, solo[4], XBM::solo_10B, {14, 50}, SH110X_WHITE},
//  {display_R, solo[5], XBM::solo_10B, {14 + 64, 50}, SH110X_WHITE},
//  {display_RR, solo[6], XBM::solo_10B, {14, 50}, SH110X_WHITE},
//  {display_RR, solo[7], XBM::solo_10B, {14 + 64, 50}, SH110X_WHITE},
BitmapDisplay<> rudeSoloDisp {
  display_L, rudeSolo, XBM::solo_7, {56 + 64, 0}, SH110X_WHITE};
BitmapDisplay<> recrdyDisp[] {
  {display_L, recrdy[0], XBM::rec_rdy_10B, {14 + 14, 50}, SH110X_WHITE},
  {display_L, recrdy[1], XBM::rec_rdy_10B, {14 + 14 + 64, 50}, SH110X_WHITE},
  {display_M, recrdy[2], XBM::rec_rdy_10B, {14 + 14, 50}, SH110X_WHITE},
  {display_M, recrdy[3], XBM::rec_rdy_10B, {14 + 14 + 64, 50}, SH110X_WHITE},
//  {display_R, recrdy[4], XBM::rec_rdy_10B, {14 + 14, 50}, SH110X_WHITE},
//  {display_R, recrdy[5], XBM::rec_rdy_10B, {14 + 14 + 64, 50}, SH110X_WHITE},
//  {display_RR, recrdy[6], XBM::rec_rdy_10B, {14 + 14, 50}, SH110X_WHITE},
//  {display_RR, recrdy[7], XBM::rec_rdy_10B, {14 + 14 + 64, 50}, SH110X_WHITE},
// VU meters
MCU::VUDisplay<> vuDisp[] {
  // position (32+11, 60), width (16), bar height (3) px, bar spacing (1) px
  {display_L, vu[0], {32 + 11, 63}, 16, 3, 1, SH110X_WHITE},
  {display_L, vu[1], {32 + 11 + 64, 63}, 16, 3, 1, SH110X_WHITE},
  {display_M, vu[2], {32 + 11, 63}, 16, 3, 1, SH110X_WHITE},
  {display_M, vu[3], {32 + 11 + 64, 63}, 16, 3, 1, SH110X_WHITE},
//  {display_R, vu[4], {32 + 11, 63}, 16, 3, 1, SH110X_WHITE},
//  {display_R, vu[5], {32 + 11 + 64, 63}, 16, 3, 1, SH110X_WHITE},
//  {display_RR, vu[6], {32 + 11, 63}, 16, 3, 1, SH110X_WHITE},
//  {display_RR, vu[7], {32 + 11 + 64, 63}, 16, 3, 1, SH110X_WHITE},
// VPot rings
MCU::VPotDisplay<> vpotDisp[] {
  // position (0, 10), outer radius (14) px, inner radius (12) px
  {display_L, vpot[0], {0, 15}, 14, 12, SH110X_WHITE},
  {display_L, vpot[1], {64, 15}, 14, 12, SH110X_WHITE},
  {display_M, vpot[2], {0, 15}, 14, 12, SH110X_WHITE},
  {display_M, vpot[3], {64, 15}, 14, 12, SH110X_WHITE},
//  {display_R, vpot[4], {0, 15}, 14, 12, SH110X_WHITE},
//  {display_R, vpot[5], {64, 15}, 14, 12, SH110X_WHITE},
//  {display_RR, vpot[6], {0, 15}, 14, 12, SH110X_WHITE},
//  {display_RR, vpot[7], {64, 15}, 14, 12, SH110X_WHITE},
// Bank setting
BankDisplay bankDisp[] {
  // first track of the bank (1), position (0, 50), font size (2)
  {display_L, bank, 1, {0, 50}, 2, SH110X_WHITE},
  {display_L, bank, 2, {64, 50}, 2, SH110X_WHITE},
  {display_M, bank, 3, {0, 50}, 2, SH110X_WHITE},
  {display_M, bank, 4, {64, 50}, 2, SH110X_WHITE},
//  {display_R, bank, 5, {0, 50}, 2, SH110X_WHITE},
//  {display_R, bank, 6, {64, 50}, 2, SH110X_WHITE},
//  {display_RR, bank, 6, {0, 50}, 2, SH110X_WHITE},
//  {display_RR, bank, 7, {64, 50}, 2, SH110X_WHITE},
// --------------------------------- Setup ---------------------------------- //
/*#ifdef DEBUG_OUT
    DEBUG_OUT.begin(115200); // Initialize the debug output
    while (!DEBUG_OUT);      // and wait for it to become available
#endif
  // Correct relative mode for MCU rotary encoders
  RelativeCCSender::setMode(MACKIE_CONTROL_RELATIVE);
  Control_Surface.begin(); // Initialize Control Surface
// ---------------------------------- Loop ---------------------------------- //
  Control_Surface.loop(); // Refresh all elements
A first step would be to see which messages your DAW sends when you change the tracks. You can use the Control Surface: Mackie-Control-Universal-Reverse-Engineering.ino example, the format of the LCD messages is explained here: Control Surface: LCD< BufferSize > Class Template Reference.
Hi PieterP, thanks a lot for your response and suggestions.
I follow your advice and here ie an extract of my serial console output.
I mapped my surface as MCU in Reaper (without CSI plugin) and as you can see all seem ok: track names are updated correctly, as well as VU meters and PAN.
d0 60 00 on cable 1
d0 70 00 on cable 1
90 18 00        (SELECT_1) on cable 1
90 4a 00        (AUTOMATION_READ_OFF) on cable 1
90 4b 00        (AUTOMATION_WRITE) on cable 1
90 4c 00        (AUTOMATION_TRIM) on cable 1
90 4d 00        (AUTOMATION_TOUCH) on cable 1
90 4e 00        (AUTOMATION_LATCH) on cable 1
90 19 7f        (SELECT_2) on cable 1
90 4c 7f        (AUTOMATION_TRIM) on cable 1
d0 00 00 on cable 1
d0 10 00 on cable 1
d0 20 00 on cable 1
d0 30 00 on cable 1
d0 40 00 on cable 1
d0 50 00 on cable 1
d0 60 00 on cable 1
d0 70 00 on cable 1
90 10 00        (MUTE_1) on cable 1
90 08 00        (SOLO_1) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 00 30 31 5F 31 4B 69 20 F7 on cable 1
90 00 00        (REC_RDY_1) on cable 1
d0 00 00 on cable 1
d0 10 00 on cable 1
d0 20 00 on cable 1
d0 30 00 on cable 1
d0 40 00 on cable 1
d0 50 00 on cable 1
d0 60 00 on cable 1
d0 70 00 on cable 1
90 19 00        (SELECT_2) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 00 30 39 5F 42 61 73 20 F7 on cable 1
90 18 7f        (SELECT_1) on cable 1
90 11 00        (MUTE_2) on cable 1
90 09 00        (SOLO_2) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 07 31 30 5F 42 61 73 20 F7 on cable 1
90 01 00        (REC_RDY_2) on cable 1
90 12 00        (MUTE_3) on cable 1
90 0a 00        (SOLO_3) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 0E 31 31 5F 45 6C 65 20 F7 on cable 1
90 02 00        (REC_RDY_3) on cable 1
90 1a 00        (SELECT_3) on cable 1
90 13 00        (MUTE_4) on cable 1
90 0b 00        (SOLO_4) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 15 31 32 5F 45 6C 65 20 F7 on cable 1
90 03 00        (REC_RDY_4) on cable 1
90 1b 00        (SELECT_4) on cable 1
90 14 00        (MUTE_5) on cable 1
90 0c 00        (SOLO_5) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 1C 31 33 5F 45 6C 65 20 F7 on cable 1
90 04 00        (REC_RDY_5) on cable 1
90 1c 00        (SELECT_5) on cable 1
90 15 00        (MUTE_6) on cable 1
90 0d 00        (SOLO_6) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 23 31 34 5F 45 6C 65 20 F7 on cable 1
90 05 00        (REC_RDY_6) on cable 1
90 1d 00        (SELECT_6) on cable 1
90 16 00        (MUTE_7) on cable 1
90 0e 00        (SOLO_7) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 2A 31 35 5F 45 6C 65 20 F7 on cable 1
90 06 00        (REC_RDY_7) on cable 1
90 1e 00        (SELECT_7) on cable 1
90 17 00        (MUTE_8) on cable 1
90 0f 00        (SOLO_8) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 31 31 36 5F 48 61 6D 20 F7 on cable 1
90 07 00        (REC_RDY_8) on cable 1
90 1f 00        (SELECT_8) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 00 31 37 5F 4C 65 61 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 07 31 38 5F 4C 65 61 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 0E 31 39 5F 42 61 63 20 F7 on cable 1
90 1a 7f        (SELECT_3) on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 15 32 30 5F 42 61 63 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 1C 32 31 5F 42 61 63 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 23 32 32 5F 42 61 63 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 2A 32 33 5F 42 61 63 20 F7 on cable 1
System Exclusive message: [15] F0 00 00 66 14 12 31 32 34 5F 42 61 63 20 F7 on cable 1
90 73 00        (RUDE_SOLO) on cable 1
90 5a 00        (SOLO) on cable 1
b0 4b 31 on cable 1
b0 4a 37 on cable 1
d0 00 37 on cable 1
d0 10 37 on cable 1
d0 20 37 on cable 1
d0 30 37 on cable 1
Therefore, I think the problem is in the implementation of the MCU protocol in CSI: analyzing the output of the serial monitor, the track names are sent correctly but no message is sent when I select a track after number 8. At this point I think I might as well do without it and use Reaper's native MCU mapping directly.
The only problem for the moment is that in the LCD display I only see the first line (the one with the track name) but not the second one (with the value of the changed parameter, e.g. PAN: how can I display it?
Thank you for your help.
The LCDDisplay constructor accepts an optional line argument: Control Surface: LCDDisplay Class Reference
You can simply create a second instance with line=2.
Thanks, PieterP and sorry for the delay in replying to you!
I tried following your suggestion and inserting the second instance with "line=2" but it remains empty on the display.
I also tried displaying only the second line on the display but no value is shown.
I use Reaper as my DAW and have mapped the Arduino as Mackie Control Universal.
Are you sure that your DAW is sending anything for the second line? All the SysEx messages in your previous post seem to be updating the first line only (all offsets are less than 56).
You could try to print all characters in lcd.getText(), but I assume that it'll be the same as the display. (IIRC, lcd.getText()[56] is the first character of the second line.)
