int i, j;
i=j=1500;
while (i>500 && j<2500) {
ruotadestra.writeMicroseconds(i);
ruotasinistra.writeMicroseconds(j);
i-=100;
j+=100;
The problem is that, for each iteration, the board loses the connection. I have understood that it is a error in codes, but I don't understand what. Can you help me?
Thank you!
Thank you!
Are you powering your servos from the arduino? If so, this usually causes the arduino to crash and reset.
Just use a four AA pack for the servos, and use whatever you're using at the moment to power the Arduino (I'll assume it isn't a 9V radio battery)
Connect the grounds together.
