Hey guys,
I have a problem with (at least) one row in my code. My intention is to instantiate some objects for HTTP requests. I store their pointers in an array requestsBatch because I will call them from within an helper function. After storing them I'll do some time checks and then send the request to the server. After a successful request the object will be deleted.
It seems the variable address is problematic but I can't see why. I hope someone can brighten up the darkness in my brain... thank you!
const char* root_ca_sherz = "myCert";
int currentRequestsBatchIndex=0;
class HTTPREQUESTS {
public:
HTTPREQUESTS(String strAddress = "", String strParameters = "", bool bSendImmediately=false, const char* cert=root_ca_sherz) {
address = strAddress;
parameters = strParameters;
certificate = cert;
currentRequestsBatchIndex++;
Serial.println("New object instantiated");
Serial.println(address);
Serial.println(parameters);
~HTTPREQUESTS() {
currentRequestsBatchIndex--;
bool sendRequest() {
Serial.println("Called from within sendRequest()");
Serial.println(address); // <<<<<< THIS ROW CAUSES THE REBOOT
http.begin(address+"/"+parameters, certificate); //, root_ca_sherz
int httpCode = http.GET();
Serial.print("HTTP Code: ");
Serial.println(httpCode);
Serial.print("Payload: ");
Serial.println(http.getString());
if (httpCode > 0) { //Check for the returning code
return true;
else {
Serial.println("Error on HTTP request");
return false;
http.end();
return false;
return true;
private:
const char* certificate="";
String parameters;
String device;
String address;
unsigned long timestamp=0;
int sendAttempts=0;
bool sendImmediately = false;
unsigned long lastSendAttemp=0;
HTTPREQUESTS *requestsBatch[5];
delay(3000);
Serial.println("Ready");
String address = "https://myAddress.com";
String parameters = "?secret=XXXXX&deviceName=deviceName&status=1&value=999&time=123456789&functionName=functionName";
HTTPREQUESTS *req01 = new HTTPREQUESTS(address, parameters);
// Store pointer to array to use it later
requestsBatch[currentRequestsBatchIndex] = req01;
Serial.println("Object stored in array");
Serial.print(F("Send request: "));
if(requestsBatch[0]->sendRequest()) {
//delete requestsBatch[0];
Serial.println("requestsBatch[0] deleted");
