controlling 2 stepper motors with a joystick in 2 axis
Hello everyone,
I'm new to the Arduino world.. recently started programming.
I am doing a project right now which needs to control 2 stepper motor with a finger joystick, so that when I move the joystick only 1 stepper will move according to his axis.
I wrote the code, but when I move the joystick the steppers move together and I can't figure out why.
My system built of:
2 stepper motor bipolar
2 l298n
1 finger joystick
Arduino Uno
This is the code:
int DIRECTION_X = A1;
int COIL1_A = 8;
int COIL1_B = 9;
int COIL2_A = 10;
int COIL2_B = 11;
int DIRECTION_Y = A2;
int COIL1_C = 4;
int COIL1_D = 5;
int COIL2_C = 6;
int COIL2_D = 7;
int DELAY = 2;
pinMode(COIL1_A, OUTPUT);
pinMode(COIL2_B, OUTPUT);
pinMode(COIL1_C, OUTPUT);
pinMode(COIL2_D, OUTPUT);
void setStep(int coil1a, int coil1b, int coil2a, int coil2b) {
digitalWrite(COIL1_A, coil1a);
digitalWrite(COIL1_B, coil1b);
digitalWrite(COIL2_A, coil2a);
digitalWrite(COIL2_B, coil2b);
digitalWrite(COIL1_C, coil1a);
digitalWrite(COIL1_D, coil1b);
digitalWrite(COIL2_C, coil2a);
digitalWrite(COIL2_D, coil2b);
delay(DELAY);
void forwards() {
setStep(HIGH, LOW, HIGH, LOW);
setStep(LOW, HIGH, HIGH, LOW);
setStep(LOW, HIGH, LOW, HIGH);
setStep(HIGH, LOW, LOW, HIGH);
void backwards() {
int directionX = analogRead(DIRECTION_X);
int directionY = analogRead(DIRECTION_Y);
if(directionX == 0) {
forwards();
if(directionX == 1023) {
backwards();
if(directionY == 0) {
forwards();
if(directionY == 1023) {
backwards();
delay(1);
I really appriciate if you guys can help me with that. I really don't know how to solve this. :slight_smile:
stepper motor program exp.txt (1.46 KB)
An easy beginning would be to write a simple program that only reads the joystick values and Serial.print() them on the IDE screen. Then you can easily see the problem with your code logic.
Paul
ArduinoArt:
You seem to have only two functions to move the motors - forwards() and backwards(). If you want the motors to move separately then you will need separate pairs of functions for both motors - perhaps forward() backwards() moveLeft() and moveRight()
And you will also need to create a separate version of the setStep() function for each motor.
...R
Stepper Motor Basics
Simple Stepper Code
You could save a lot of coding by using the Stepper library. See File->Examples->Stepper->stepper_oneStepAtATime
