Controlling an Electronic Throttle Body using a PID controller
Thank you for your suggestions! I have changed the code to have the correct safety features and have looked up PID tuning. I have tried the manual tuning method described on Wikipedia with some success. It no-longer jitters, but it takes a while to reach the set point sometimes. I have tried to use the PID Autotune program, but I can't seem to get it to work. Here is my code so far:
  PID_Basic_Throttle.ino
 Bosch electronic throttle body control
 for MSOE SAE Formula Hybrid 2014
 Author: Austin R. Bartz
 Last Revision Date: 4/3/2014
 Hardware Connections:
 -L298N H-Bridge Enable A: Pin 9
 -L298N H-Bridge Input 1:  Pin 8
 -L298N H-Bridge Input 2:  Pin 11
 -TPS 0:                   Pin A0
 -TPS 1:                   Pin A1
 -Throttle Input:          Pin A2
//H-Brdige Pins
#define pinI1 8
#define pinI2 11
#define speedPin 9
//PID Library
#include <PID_v1.h>
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,1,0,0, DIRECT);
//TPS0 Idle= 863  WOT= 56
//TPS1 Idle= 164  WOT= 969
  TCCR1B = TCCR1B & 0b11111000 | 0x01;
  int TPS0 = -1*(analogRead(0)-862);
  int TPS1 = (analogRead(1)-163);
  int TPS =  (TPS1 + TPS0)/2;
  if(abs(TPS0 - TPS1) >= 5)
    analogWrite(speedPin,0);
  //initialize the variables we're linked to
  Input = TPS;
  Setpoint = map(analogRead(3), 85, 1023, 0, 800);
  //turn the PID on
  myPID.SetMode(AUTOMATIC);
  pinMode(pinI1,OUTPUT);
  pinMode(pinI2,OUTPUT);
  pinMode(speedPin,OUTPUT);
  digitalWrite(pinI2,LOW);
  digitalWrite(pinI1,HIGH);
  float Kp = mapfloat(analogRead(4), 0, 1023, 0, 5);
  Serial.print(Kp, DEC);
  Serial.print("  ");
  float Ki = mapfloat(analogRead(5), 0, 1023, 0, 5);
  Serial.print(Ki, DEC);
  Serial.print("  ");
  //myPID.SetTunings(Kp, Ki, 0.00);
  myPID.SetTunings(0.15, 2.00, 0.00);
  int TPS0 = constrain(-1*(analogRead(0)-867), 0, 810);
  int TPS1 = constrain((analogRead(1)-153), 0, 810);
  if(abs(TPS0 - TPS1) >= 10)
  Input = TPS;
  int TP0 = map(analogRead(3), 85, 1023, 0, 800);
  int TP1 = map(analogRead(2), 555, 1023, 0, 800);
  int TP = ((TP0+TP1)/2);
  int TPdiff = abs(TP0-TP1);
  while(TPdiff >= 5)
  Setpoint = TP0;
  if(Setpoint <= 5)
    myPID.Compute();
    analogWrite(speedPin,Output);
  Serial.print("TPS0:");
  Serial.print(TPS0, DEC);
  Serial.print("  ");
  Serial.print("TPS1:");
  Serial.print(TPS1, DEC);
  Serial.print("  ");
  Serial.print("Input:");
  Serial.print(Input, 0);
  Serial.print("  ");
  Serial.print("Pot0:");
  Serial.print(TP0);
  Serial.print("  ");
  Serial.print("Pot1:");
  Serial.print(TP1);
  Serial.print("  ");
  Serial.print("Setpoint:");
  Serial.print(Setpoint, 0);
  Serial.print("  ");
  Serial.print("Output:");
  Serial.println(Output, 0);
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
