hi, does anyone here know about controlling servo dc linear from flex sensor as input signal? i just want to know whether i can read the servo stroke length as the result of bending the flex. or can i read the output value?
Please give full details of the hardware you are talking about - without this there is nothing to do on.
i'm using firgelli L12R and arduino mega2560..
Flex sensor not hardware then? Please post a link to the datasheet or product page, don't expect us
to all slog through that boring stuff.
Sorry
this is product page of 2.2" flex sensor
and this is for firgelli L12R
http://www.actuonix.com/L12-R-Linear-Servo-For-Radio-Control-p/l12-r.htm
actualy i have made the code, but it seems like the code only read the input from flex sensor
here it is
Coding_Astero_1.ino (4.1 KB)
So that flex sensor has about 10k when straight upto a max of about 20k when fully bent,
it seems.
I'd use a 10k resistor with it in a resistor divider, and use map() to map the values appropriately
to the range 0 to 180 for a call to servo.write () to control the linear actuator. It takes standard
RC servo signalling which makes things very simple.
Do you actually need a sensor - that thing is a servoactuator and will go to where you tell it and
hold position. It must have an internal sensor to do that already.
yes. actually the code i made already control the servo position. i use firgelli L12 with stroke length 5cm, but the code will make the stroke length 2.5cm
i am a bit confused about the voltage output. so, the voltage output from flex will be transfer to actuator, is that right? so is it also right if the actuator voltage input = voltage output from flex?
You have some code? Post it please if you want help with it!
i already uploaded it above
agnessilivas:
Did it compile for you?
var1 not declared,
var1 = map(flex_Thumb, 0, 511, 0, 90); // scale the value between 0-90 to use it in servo
Also servo is 0 to 180, not 0 to 90, that is why you are only getting 2.5cm from a 5cm throw.
Same for var2
Tom...
