Controlling many Servo using a Function
I'm trying to work out how to use one function with inputs to be able to control all 12 of my servos, without it being overly bloated.
A cut down version of my code I'm trying to achieve is below.
#include <Servo.h>
Servo servo01;
Servo servo02;
Servo servo03;
Servo servo04;
servo01.attach(11);
servo02.attach(11);
servo03.attach(11);
servo04.attach(11);
void ServoMove(int ServoNo, int ServoAdjust) {
  "servo" += ServoNo.write(ServoAdjust);
  ServoMove(01, 0);
The above obviously doesn't work but hopefully its clear what I'm trying to achieve. It does work if I have 'servo01.write(ServoAdjust);' instead. But I'm trying to avoid having to write all of them individual functions.
I presume there is an easy solution that my brain just isn't seeing.
Thanks in advance.
Thank you!
I was thinking about trying arrays but i wasn't sure they would work using the servo code.
In the setup code I would presume I need to have the servo attach increment inside a for loop. I guess this would mean that they will need to be in sequence?
Something like this?
  for (int i = 1; i <= 4; i++) {
    servo[i].attach(i + 11);
