Controlling Multiple Sensor with Bluetooth
why not capture all the ultrasonic stuff in a sub-function with the prints and all the IR stuff in a 2nd sub-function with the prints can just call them both from loop every second or so?
what the reason for the serial commands?
I am assuming = really not knowing it. A part of the projects requirements is to have remotely activating / deactivating sensor-readings
There are a lot of more things to define:
how many characters can you send from your smartphone over bluetooth
are you limited to a single character or can you SEND multiple characters?
If you can send multiple-characters the mode of operation ultrasonic-sensor AND IR-sensor
at the same time
can be activated through sending TWO characters "UI" U for ultra-sonic "I" for infrared
THis requieres to read in not only a single character but multiple characters.
If you don't want to do this approach another approach is to use different single characters for each mode of operation
	switch (data) {
      case 'A':
        OperationMode = readOnlyUltraSonicSensor;
      case 'B':
        OperationMode = readOnlyInfraRedSensor;
      case 'C':
        OperationMode = read_UltraSonic_And_InfraRedSensor;
      case 'D':
        // whatever else modes of operation are needed
void operateSensors() {
	switch (OperationMode) {
      case readOnlyUltraSonicSensor:
        // code for that
      case readOnlyInfraRedSensor:
        // code for that
      case read_UltraSonic_And_InfraRedSensor:
        // code for that
Same philosophy as gcjr:
very good coding divides the code into functional sub-units where each subunit does ONE SINGLE thing
This means there is a function for
-reading distance from the ultraSonic-Sensor one time
-reading infraRed-Sensor one time
  • etc.
And bases on that the mode read_UltraSonic_And_InfraRedSensor
does a call to the two BASIC functions
best regards Stefan
