I've a simple program I've started to control RGB LEDs with PWM on an Arduino nano. Its in its early stage of programming. And the Serial output is not what I am expecting. I've attached my code, and the Serial Monitor Capture. Can anyone tell me what is happening here....
unsigned long Counter;
/* Pin 13: 1 Second Square Wave Timer1 interrupt)
Pin 8: 1KHz Square wave oscillator (0 to 5V amplitude) Timer-0 interrupt
Pin 9: 4 Khz square wave oscillator Timer-2 interrupt
Looking with Oscilloscope. These are very Square, and accurate.
998.5 KHz & 3.99KHz
//timer interrupts
//by Amanda Ghassaei
//June 2012
//http://www.instructables.com/id/Arduino-Timer-Interrupts/
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 3 of the License, or
(at your option) any later version.
//timer setup for timer0, timer1, and timer2.
//For arduino uno or any board with ATMEL 328/168.. diecimila, duemilanove, lilypad, nano, mini...
//this code will enable all three arduino timer interrupts.
//timer0 will interrupt at 2kHz
//timer1 will interrupt at 1Hz
//timer2 will interrupt at 8kHz
//Initial LED setting for each of 14 bottle RGB LED's.
// The next LED's value is off by about 20 from previous
int RED[14] = {255, 236, 216, 196, 176, 156, 136, 116, 96, 76, 56, 36, 16, 0};
int GRN[14] = {0, 16, 36, 56, 76, 96, 116, 136, 156, 176, 196, 216, 236, 255};
int BLU[14] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
int Pointer[14] = {0, 16, 36, 56, 76, 96, 116, 136, 156, 176, 196, 216, 236, 255};
int Cnt = 0;
//storage variables
boolean toggle0 = 0;
boolean toggle1 = 0;
boolean toggle2 = 0;
Serial.print("Interrupt Setup Example V2.sco 6/30/21 by LJT Preliminary\n\n");
//set pins as outputs
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
cli();//stop interrupts
//set timer0 interrupt at 2kHz
TCCR0A = 0;// set entire TCCR2A register to 0
TCCR0B = 0;// same for TCCR2B
TCNT0 = 0;//initialize counter value to 0
// set compare match register for 2khz increments
OCR0A = 124;// = (16*10^6) / (2000*64) - 1 (must be <256)
// turn on CTC mode
TCCR0A |= (1 << WGM01);
// Set CS01 and CS00 bits for 64 prescaler
TCCR0B |= (1 << CS01) | (1 << CS00);
// enable timer compare interrupt
TIMSK0 |= (1 << OCIE0A);
//set timer1 interrupt at 1Hz
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
// set compare match register for 1hz increments
OCR1A = 15624;// = (16*10^6) / (1*1024) - 1 (must be <65536)
// turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS12 and CS10 bits for 1024 prescaler
TCCR1B |= (1 << CS12) | (1 << CS10);
TIMSK1 |= (1 << OCIE1A);
//set timer2 interrupt at 8kHz
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
// set compare match register for 8khz increments
OCR2A = 249;// = (16*10^6) / (8000*8) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS21 bit for 8 prescaler
TCCR2B |= (1 << CS21);
TIMSK2 |= (1 << OCIE2A);
sei();//allow interrupts
}//end setup
ISR(TIMER0_COMPA_vect) { //timer0 interrupt 2kHz toggles pin 8
//generates pulse wave of frequency 2kHz/2 = 1kHz (takes two cycles for full wave- toggle high then toggle low)
ISR(TIMER1_COMPA_vect) { //timer1 interrupt 1Hz toggles pin 13 (LED)
//generates pulse wave of frequency 1Hz/2 = 0.5kHz (takes two cycles for full wave- toggle high then toggle low)
//Serial.println("\n\t\t1Hz\n");
ISR(TIMER2_COMPA_vect) { //timer1 interrupt 8kHz toggles pin 9
//generates pulse wave of frequency 8kHz/2 = 4kHz (takes two cycles for full wave- toggle high then toggle low)
//Will Set the value for each set of LEDs for each of 14 bottles
//the PWM takes place in an intCnt++){
Serial.println(".");
for (int LED = 0; LED <= 13; LED++) {
Serial.print("LED=");
Serial.print(LED);
//Serial.print("\tPointer[]= ");
if (Cnt <= 255) { //Zone 1
RED[Pointer[LED]] = Cnt;
GRN[Pointer[LED]] = 255 - Cnt;
BLU[Pointer[LED]] = 0;
if (Cnt > 255 && Cnt <= 511) { //Zone 2
RED[Pointer[LED]] = 511 - Cnt;
GRN[Pointer[LED]] = 0;
BLU[Pointer[LED]] = Cnt - 255;
if (Cnt > 511 && Cnt <= 767) { //Zone 3
RED[Pointer[LED]] = 0;
GRN[Pointer[LED]] = Cnt - 511;
BLU[Pointer[LED]] = 767 - Cnt;
if (RED[Pointer[LED]]>=256) {
RED[Pointer[LED]]=0;
} else if (RED[Pointer[LED]] < 0) {
if (GRN[Pointer[LED]]>=256) {
GRN[Pointer[LED]]=0;
} else if (GRN[Pointer[LED]] < 0) {
if (BLU[Pointer[LED]]>=256) {
BLU[Pointer[LED]]=0;
} else if (BLU[Pointer[LED]] < 0) {
Serial.print("........\t");
Serial.print(Pointer[LED]); Serial.print("\tR: ");
Serial.print(RED[Pointer[LED]]); Serial.print("\tG: ");
Serial.print(GRN[Pointer[LED]]); Serial.print("\tB: ");
Serial.println(BLU[Pointer[LED]]);
if (Pointer[LED] <= 767) {
Pointer[LED] = Pointer[LED] + 1;
Pointer[LED] = 0;
}//endif
} //END FOR
delay(3000);//temp delay 1 second to look at printout
} //End Sub
/* Arrays RED[], GRN[], BLU[] contain the value of that Bottles RGB-LED between 0 and 255
void SetOutputs() {
static int PWMvalue;
PWMvalue++;
for (int LEDPtr = 0; LEDPtr <= 13; LEDPtr++) {
if (RED[LEDPtr] < PWMvalue) {
digitalWrite(RED[LEDPtr], HIGH);
digitalWrite(RED[LEDPtr], LOW);
if (GRN[LEDPtr] < PWMvalue) {
digitalWrite(GRN[LEDPtr], HIGH);
digitalWrite(GRN[LEDPtr], LOW);
if (BLU[LEDPtr] < PWMvalue) {
digitalWrite(BLU[LEDPtr], HIGH);
digitalWrite(BLU[LEDPtr], LOW);
}//endfor
}//end sub
This is what the Serial output looks like...
Blockquote
had to send this as an image, cause cutting and pasting was not working...
Blockquote
Issues I am Seeing:
- List item
Seems to reboot and redo the Setup. I dont think that should be happening.
Also you can see the printout is not aligning (first instance around "LED=5"
After first instance of "LED=13", get some garage numbers... then see the Print from Setup() routing.
Any ideas... I sure this is something simple, and I'm just not seeing it. Any help greatly appreciated.
