Controlling RPM of stepper motors with CNC shield
Hello everyone.
I am currently trying to control three stepper motors with a CNC shield (with A4988 drivers) on top of the Arduino Uno. I got everything wired and already did some testing to make sure that everything works. My question is related to the code itself. Each driver (or stepper) is controlled via two pins on the Uno. One for "direction" and one for "step".
I am now wondering how I can adjust the rotational speed of the stepper motors. I know that you can do it with adjusting the time intervall between each step, but this seems quite circumstancial and iterative to me. Is there some kind of library or function which I can use to maybe set the steps per second or something like that?
Thanks in advance!
Kind regards
You could try the MotoStepper class of my MobaTools lib to control your steppers.
You could also try accelStepper library. Has plenty of options
I would also recommend reading this:
@MicroBahner @cncnotes Thanks for your replies. I will look into both recommendations. I might come back with eventual questions :wink: have a nice day!
Robin2's simple stepper code tutorial will give you the basics of controlling stepper speed.
Thanks for your tip. I tried it with this code and everything worked fine!
