Convert and pad to two digits << SOLVED>>
I am using a keypad with IR receiver - the value when a key is pressed (0)=0x16.(1)=0xC etc
I wish to pad the input to two places and have it shown as 00, 01 - 99
Can anyone help with the coding please.
    if (value < 10)
      Serial.print('0');  // Add leading zero
    Serial.print(value);
Thanks for the quick reply - I am not sure how that would convert and pad value.
could you give me a clearer idea.
if value = 0xC then result= ????
it’s Hex representation of …
0123456789ABCDEF …
12
@dolittle, the idea is not to change the variable itself, but only add the zero when displaying that value.
This is what johnwasser did, I put both decimal and hexadecimal in there:
  Serial.begin( 115200);
  int key = random( 0, 25);
  // Print as decimal
  // Value is 10 or above ? No leading zero
  // Value is 9 or below ? Add leading zero
  if( key < 10)
    Serial.print( "0");     // Add leading zero
  Serial.print( key, DEC);
  // Print as hexadecimal
  // Value is 0x10 or above ? No leading zero
  // Value is 0x9 or below ? Add leading zero
  Serial.print( "  0x");
  if( key < 0x10)
    Serial.print( "0");
  Serial.print( key, HEX);
  delay( 500);
Try this sketch in Wokwi:
[ADDED] Updated the sketch in Wokwi. Added the printf() as shown by @groundFungus but made it safer.
Using the sprintf() function.
int numberA = 7;
int numberB = 0xc;
    char numAstr[5];
    char numBstr[5];
    sprintf(numAstr,"%02d", numberA);
    Serial.print("number A = ");
    Serial.print("0X");
    Serial.println(numAstr);
    sprintf(numBstr,"%02X", numberB);
    Serial.print("number B = ");
    Serial.print("0X");
    Serial.println(numBstr);
Output:
number A = 0X07
number B = 0X0C
It was not clear that you wanted the result in hexadecimal.
    if (value < 0x10)
    Serial.print(value, HEX);
Sorry for not explaining myself better - something along this line: I know its not correct but this is what I am looking for
String doConvert(HEX value) {
  string result ;
  if (value < 0x10)
    result = '0'+ 'what';
    result =' what';
      return result;
The return should be two characters 01,02,03,04 etc
String doConvert(int value)
  String result ;
  if (value < 0x10)
    result = '0' + String(value, HEX);
    result = String(value, HEX);
  return result;
perfect - thank you
Nice to see you came up with own solution
Thanks for pointing that out, seems to be floppy fingers.
