hello friends i have exported hex file from my Arduino mini pro and i want
to convert this Arduino mini pro hex file to normal code which can be edited in Arduino Software (IDE) if u can do it i will pay u 100$ thanks
By “normal code”, I guess you mean C++ (not simply assembler code) so the task would be to convert ATmega328p machine code to (readable) C++. Don’t underestimate the scale of this task and, even in the case in the case of very small sketch, you’d have to unpick the Arduino run time system. More difficulties emerge when a large number of complex libraries have been used.
Starting again from a clear specification might be the only viable solution.
Clearly the answer is to rewrite the sketch. Just figure out what it is supposed to do. Write it down and get someone to program from the specification.
