Ok- I apologize in advance if there is an obvious answer to this, but I haven't been able to find it yet.
I'm receiving a string from a Bluetooth Low Energy module. It sends it over (not via serial) in an ASCII code.
String GetStringFromBLE(){
unsigned char buf[16] = {
0};
unsigned char len = 0;
while ( BLEMini.available())
receivedByte = BLEMini.read();
receivedChar = receivedByte;
if (receivedChar != 0x0A)
if (len < 16) {
buf[len++] = receivedChar;
else {
for (int i = 0; i < len; i++){
//SOMEHOW get each element of buf[] into a string (str)
return str;
I can't figure out how to convert the ASCII code into it's proper string or char letter counterpart. (i.e. 104 should be 'h') I know that Serial.write() does this but I want it as a stored variable, not written to the serial. My gut is that this should be fairly simple but it seems to be escaping me. Thanks in advance for any advice or tips.
What am I half remembering ? Are there any circumstances where all the elements of an array are initialised to zero in that way ? I am sure that I have seen mention of it.
A quick test shows that it seems to work but I appreciate that it may not be consistent behaviour. I am not sure how authoritative it is, but C++ Notes: Array Initialization seems to say that uninitalised elements of an array will be set to zero.
When you said 'Nope' I did wonder if it applied to special cases only. I agree, zero terminating as you add a character does seem more natural and is the obvious (and easy) thing to do.
per your suggestion, and I think(?) I understood most of it.
(I will definitely change my program so that I'm not trying to use 'blocking'.)
But I believe my question is slightly different. I'll see if I can explain it more clearly...
I'm getting an ASCII number instead of the actual character.
So if I send 'hello' over BLE to this code:
unsigned char buf[16] = {0};
if (len < 16) {
else {
Serial.println(buf[i]);
return str;
It will write:
104
101
108
108
111
13
rather than
h
e
l
l
o
I know that I could use Serial.write() instead of Serial.println(), but I'm not interested in writing it to the serial. I want to store it to a string var and be able to manipulate that string.
I hope I'm on the right line of inquiry and will review the Gammon tutorial again to see if there's something in there that I missed...
crutchre:
The question as stated doesn't make much sense and may imply that you've just understood what you're seeing.
When you store a character value in your code, it's stored as an ascii character code. If you type an 'h' character into the serial monitor and then read is from the serial port into a char variable, the value in the char variable is the number 104. If you then write the char value back to the serial port the IDE will receive a byte containing the number 104 and print the pattern of pixels that looks like 'h' on your screen.
If you receive an 'h' (ascii code 104) and do something with it which causes the string "104" to appear somewhere else then the problem is not with your character value, it's that the method you're using to output it is formatting the ascii character code as a decimal number before it displays it. That's a mistake in the way you're outputting the value, not a problem with the value itself.
PaulS - you called it. Specifying the char array (buf) as unsigned made it behave in a way that I didn't understand. Deleting the unsigned command solved it. (It was left over from some copied code).
Thank you everyone for the guidance and tips.
I'm certainly learning a lot as I go and appreciate the help.
