convert int into multiple bytes
hey,
I'm pretty new to Arduino and got a question about converting a int into bytes beacause I want to send some Information over I2C. I read that the I2C_anything lib can make that happen or you split it into 2 Bytes.
But is there a way to convert every single digit of an int number into a byte, so I can send every digit alone?
e.g. the number 457 splits into 3 Bytes. Byte 1=4, Byte 2=5 and Byte 3=7.
itoa() will convert an int to an array of chars. A char and a byte are the same size.
Thx, I'll give it a try later :slight_smile:
Here's a chunk of code I am working on that will convert anything into an array of bytes:
template <class T> void CopyAnything( const T& Source,  T& Destination) {
  int i;
  const byte* _Source = (const byte*)(const void*)&Source;
   byte* _Destination = (const byte*)(const void*)&Destination;
  for (i = 0; i < sizeof(Source); i++) {
    _Destination[i] = _Source[i];
template <class T> void writeData( const T& Source) {
  int i;
  byte X;
    X = _Source[i];      // << X represents the destination for the array of bytes to be copied to
template <class T> void readData(  const T& Destination) {
  int i;
  byte X;
    _Destination[i] = X; //  << X represents the data in bytes you wish to insert into the object
This is inspired from EEPROMAnything.h
Kritzl:
Typically, you would not send an int as a series of bytes to be interpreted as a decimal number. An int is two bytes, so usually you'd send the top (or the bottom) 8 bits first and then send the other 8 bits.
Do do this, you use the C++ "bit filddling" operators, which are <<, >>, >>>, &, |, ^, and ~.
to send:
int theValue;
send((byte) (theValue>>8));
send((byte) (theValue));
to recieve:
int theValue;
theValue = 0;
theValue |= ((int)readAByte()) << 8;
theValue |= ((int)readAByte()) ;
