Hello,
I want to convert text to integers, or even better, to binary.
I've already written something to convert integers to binary, but eventually I want to convert text to binary.
I know you can print the ASCII value of every char of a string, but I don't want to print te value, I want the ASCII value as a variable, so I can use it
Is there anyone who has an idea?
Text is binary. Integers are binary. Everything in the computer is binary. What do you mean?
char a_string[10]; // make a char array to hold string
strcpy(a_string, "25"); // Place string in array
unsigned long value = atoi(a_string); // atoi converts the array of ascii to an int
for (byte i = 1; i < 10; i++) { // print the new "value" variable to the monitor...times it by 1 to 9 for example.
Serial.println(value * i);
delay(100);
A very simple example of capturing a string of numeric characters into a String, then converting the String into an integer.
//zoomkat 7-30-10 serial servo test
//type servo position 0 to 180 in serial monitor
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.attach(9);
Serial.println("servo-test"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the String readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured String
int n = readString.toInt(); //convert readString into a number
Serial.println(n); //so you can see the integer
myservo.write(n);
readString="";
Individual ASCII characters are bytes. If the parity bit is masked,
numbers 0 through 9 are 0x30 to 0x39.
If the numbers are entered as HEX, you need A through F being 0x41 to 0x46.
If lower case, a to f it is 0X61 to 0x66.
Converting is then just math.
123
is
0x31,0x32,0x33.
Typical conversion programs read left to right and first check
each digit to be in range. If so it subtracts 0x30.
If there is another digit, it multiplies the sum by 10 ( 16 if hex )
and adds the next converted value.
Programming should be simple enough.
Dwight
You can also write zoomcat's code without using the String class, which usually results in smaller code. His code compiles to 6026 bytes. The following code does not use the String class, but instead uses a char array to form a C string:
#include <Servo.h>
char readString[10];
myservo.attach(9);
byte charsRead;
if (Serial.available() > 0) {
charsRead = Serial.readBytesUntil('\n', readString, 9); // Read until newline
readString[charsRead] = '\0'; // Now it's a string
if (charsRead > 0) {
Serial.println(readString); // so you can see the captured String
int n = atoi(readString); // convert readString into a number
Serial.println(n); // so you can see the integer
myservo.write(n);
It compiles to 4314 bytes.
