Hi all
Could this be a nice project ? I will surly try if it's feasible.
Would It be possible to use a simple (geared) DC motor as a Servo with the use off an Arduino + V2.3 motor shield ? . Off course it would be necessary to attach a potentiometer to the main shaft and connect it to an analog Input.
So more precise the question would be : is there any software arond that can do the job?
There could be several ways to operate the servo:
1 manual (with an other pot.)
2 automatic (programmed)
3 by an rc servo signal
That could be done. If you want it to respond to a "normal" [u]servo pluse[/u], that could be tricky. But simple clockwise/counterclockwise motor control (based on the position-pot) would be simple.
If you are using an Arduino, the Arduino's ADC can "read" the position of a pot.
Once you have the servo attached to the Arduino and working, that's just a matter of programming.
Easy with the appropriate hardware!
There are servo libraries if you make your servo respond to the normal servo-control pulses. If you so it some other way, you'll have to develop your own software.
On the input side, there are examples using a pot. I'm not sure what's out there for RC control.\
