I have been struggling with a problem.
I am attempting to write the following to SPI.
All is ok when I send this:
uint8_t data[] = "MD111111111111111111111111111111111#(40)";
However, what I need to do is have the string in a variable and send the string variable.
For instance:
String myString = "MD111111111111111111111111111111111#(40)";
uint8_t data[] = myString;
ecoguy:
As we said from @Pauls, you can use string or String but String are very heavy.
I think that you confuse string (array of char) and String (object-class)
Hi All,
I am still having problems.
Going back to basics - here is the original example sketch:
// rf22_reliable_datagram_client.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple addressed, reliable messaging client
// with the RF22ReliableDatagram class.
// It is designed to work with the other example rf22_reliable_datagram_server
#include <RF22ReliableDatagram.h>
#include <RF22.h>
#include <SPI.h>
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 255
// Singleton instance of the radio
RF22ReliableDatagram rf22(CLIENT_ADDRESS);
if (!rf22.init())
Serial.println("RF22 init failed");
// Defaults after init are 434.0MHz, 0.05MHz AFC pull-in, modulation FSK_Rb2_4Fd36
uint8_t data[] = "Hello World!";
// Dont put this on the stack:
uint8_t buf[RF22_MAX_MESSAGE_LEN];
while (1)
Serial.println("Sending to rf22_datagram_server");
// Send a message to rf22_server
if (!rf22.sendtoWait(data, sizeof(data), SERVER_ADDRESS))
Serial.println("sendtoWait failed");
// Now wait for a reply from the server
// Serial.println(rf22.lastRssi(), HEX); // of the ACK
uint8_t len = sizeof(buf);
uint8_t from;
if (rf22.recvfromAckTimeout(buf, &len, 2000, &from))
Serial.print("got reply from : 0x");
Serial.print(from, HEX);
Serial.print(": ");
Serial.println((char*)buf);
Serial.println("No reply, is rf22_datagram_server running?");
The "canned" message "Hello World!" I must be able to change to my own.
As an example, I have an RFID reader that I obtain data from, this data I need to transmit via the RFM22
So: The "Hello World!" message must be changed to the data I have from the RFID.
For you, the compiler analize the code line:
Hello World!
123456789012
and allocate a variable (an array o vector) of name data and 12 elements of type uint8_t.
If you receive a msg from any other device and is a string (vector/array of char) you can send this vector instead "data" or copy from this vector to "data" array.
You can use memcpy() for example. And you must define uint8_t data[30] with a constant space that you know, 30 for example, so big to allow the other message to be copied into it.
Hi nid69ita,
Could you possibly give me a code snippet as to how I should approach this.
I am an absolute newbie and reading up on memcpy has me more confused than ever
This is the data that is sent:
uint8_t data[] = "Hello World";
I need to change/substitute the "Hello World" text with my own text string.
eg. "SW0000001D10"
For instance,
I have a string that I can type on the Arduino Serial Monitor that is:
"SW0000001D10"
This string must now be sent to the RFM22 with:
uint8_t data[] = "SW0000001D10"
Now for me is not clear. You want send some chars to RFM22 (using rf22.sendtoWait). okay.
From where you receive the string? In last post you tell about serial monitor, previous post you tell about RFID ?!?
Do you have tried to send the string using this as constant (not receiving from serial or RFID) ?
(simply change "Hello World" with "SW0000001D10")
uint8_t data[] = "SW0000001D10";
and use
Thanks Igor,
Yes I have tried:
and send with:
and it works perfectly.
In order to understand what I am doing and how this all works, I am, for now, using the Serial Monitor as the "Input" for the data I want to send with: uint8_t data[] =
I will later, once I understand this, change it to what is received from RFID port.
If I type "SW0000001D10" into Serial Monitor, I must use this to send to the RFM22: uint8_t data[] = "SW0000001D10";
If I type "SW9999999D10" into Serial Monitor, I must use this to send to the RFM22: uint8_t data[] = "SW9999999D10";
It is these strings that are not constant and will change.
So, whatever I type in the Serial Monitor, will be sent to the RFM22 with: uint8_t data[] = "XXX...XXX".
Where "XXX...XXX" is the data.
const unsigned int MAX_INPUT = 50; // how much serial data we expect before a newline
char input_line [MAX_INPUT];
unsigned int input_pos = 0;
const byte MSG_LEN=12; // SW0000001D10
void setup ()
{ Serial.begin(9600);
} // end of setup
{ if (Serial.available () > 0)
{ char inByte = Serial.read ();
switch (inByte)
{ case '\n': // discard carriage return
case '\r': // discard carriage return
default:
if (input_pos < (MAX_INPUT - 1)) // keep adding if not full ... allow for terminating null byte
{ input_line [input_pos++] = inByte;
if (input_pos >= MSG_LEN)
{ input_line [input_pos] = 0; // terminating null byte
process_data (input_line);
input_pos = 0; // reset buffer for next time
} // end of switch
} // end of incoming data
// do other stuff here like testing digital input (button presses) ...
} // end of loop
void process_data (char * data) // here to process incoming serial data after a terminator received
{ Serial.println (data); // for now just display it
if (!rf22.sendtoWait(data, MSG_LEN , SERVER_ADDRESS))
} // end of process_data
On function process_data() you need to send to RF22.
Is not a perfect code, only tried one time
#include <RF22.h>
#include <SPI.h>
#define CLIENT_ADDRESS 100
if (!rf22.init())
//uint8_t data[] = "0000001D00";
void loop(){
switch (inByte)
default:
} // end of switch
} // end of loop
// if (!rf22.sendtoWait(data, MSG_LEN , SERVER_ADDRESS))
When I run this, whatever I type in the Serial monitor IS displayed - works great.
If I uncomment this line:
I get the following errors on compiling:
rf22_reliable_datagram_CPX_01.ino: In function 'void process_data(char*)':
rf22_reliable_datagram_CPX_01:60: error: invalid conversion from 'char*' to 'uint8_t*'
rf22_reliable_datagram_CPX_01:60: error: initializing argument 1 of 'boolean RF22ReliableDatagram::sendtoWait(uint8_t*, uint8_t, uint8_t)'
