Converting Arduino Compatible library to work with ESP32
I am using a library for DS3231 RTC provided by Rinky-Dink Electronics. Link: http://www.rinkydinkelectronics.com/library.php?id=73. This library is only compatible with Arduino boards but I want to make it work for my ESP32 board. I don't want to switch to a another library that is compatible with ESP32 library as earlier I have already written a whole bunch of code for my Arduino code with the DS3231 library that I mentioned and for some reasons I am switching from Arduino to ESP32 and don't really want to do much changes in my original code. Can someone let me know what changes should I do in the library to make it compatible. For ease I am also writing the cpp and .h file over here.
DS3231.h:
  DS3231.cpp - Arduino/chipKit library support for the DS3231 I2C Real-Time Clock
  Copyright (C)2015 Rinky-Dink Electronics, Henning Karlsen. All right reserved
  This library has been made to easily interface and use the DS3231 RTC with
  an Arduino or chipKit.
  You can find the latest version of the library at
  http://www.RinkyDinkElectronics.com/
  This library is free software; you can redistribute it and/or
  modify it under the terms of the CC BY-NC-SA 3.0 license.
  Please see the included documents for further information.
  Commercial use of this library requires you to buy a license that
  will allow commercial use. This includes using the library,
  modified or not, as a tool to sell products.
  The license applies to all part of the library including the
  examples and tools supplied with the library.
#ifndef DS3231_h
#define DS3231_h
#if defined(__AVR__)
	#include "Arduino.h"
	#include "hardware/avr/HW_AVR_defines.h"
#elif defined(__PIC32MX__)
	#include "WProgram.h"
	#include "hardware/pic32/HW_PIC32_defines.h"
#elif defined(__arm__)
	#include "hardware/arm/HW_ARM_defines.h"
#endif
#define DS3231_ADDR_R	0xD1
#define DS3231_ADDR_W	0xD0
#define DS3231_ADDR		0x68
#define FORMAT_SHORT	1
#define FORMAT_LONG		2
#define FORMAT_LITTLEENDIAN	1
#define FORMAT_BIGENDIAN	2
#define FORMAT_MIDDLEENDIAN	3
#define MONDAY		1
#define TUESDAY		2
#define WEDNESDAY	3
#define THURSDAY	4
#define FRIDAY		5
#define SATURDAY	6
#define SUNDAY		7
#define SQW_RATE_1		0
#define SQW_RATE_1K		1
#define SQW_RATE_4K		2
#define SQW_RATE_8K		3
#define OUTPUT_SQW		0
#define OUTPUT_INT		1
class Time
public:
	uint8_t		hour;
	uint8_t		min;
	uint8_t		sec;
	uint8_t		date;
	uint8_t		mon;
	uint16_t	year;
	uint8_t		dow;
	Time();
class DS3231
	public:
		DS3231(uint8_t data_pin, uint8_t sclk_pin);
		void	begin();
		Time	getTime();
		void	setTime(uint8_t hour, uint8_t min, uint8_t sec);
		void	setDate(uint8_t date, uint8_t mon, uint16_t year);
		void	setDOW();
		void	setDOW(uint8_t dow);
		char	*getTimeStr(uint8_t format=FORMAT_LONG);
		char	*getDateStr(uint8_t slformat=FORMAT_LONG, uint8_t eformat=FORMAT_LITTLEENDIAN, char divider='.');
		char	*getDOWStr(uint8_t format=FORMAT_LONG);
		char	*getMonthStr(uint8_t format=FORMAT_LONG);
		long	getUnixTime(Time t);
		void	enable32KHz(bool enable);
		void	setOutput(byte enable);
		void	setSQWRate(int rate);
		float	getTemp();
	private:
		uint8_t _scl_pin;
		uint8_t _sda_pin;
		uint8_t _burstArray[7];
		boolean	_use_hw;
		void	_sendStart(byte addr);
		void	_sendStop();
		void	_sendAck();
		void	_sendNack();
		void	_waitForAck();
		uint8_t	_readByte();
		void	_writeByte(uint8_t value);
		void	_burstRead();
		uint8_t	_readRegister(uint8_t reg);
		void 	_writeRegister(uint8_t reg, uint8_t value);
		uint8_t	_decode(uint8_t value);
		uint8_t	_decodeH(uint8_t value);
		uint8_t	_decodeY(uint8_t value);
		uint8_t	_encode(uint8_t vaule);
#if defined(__arm__)
		Twi		*twi;
#endif
#endif
DS3231.cpp:
#include "DS3231.h"
// Include hardware-specific functions for the correct MCU
	#include "hardware/avr/HW_AVR.h"
  #include "hardware/pic32/HW_PIC32.h"
	#include "hardware/arm/HW_ARM.h"
#endif
#define REG_SEC		0x00
#define REG_MIN		0x01
#define REG_HOUR	0x02
#define REG_DOW		0x03
#define REG_DATE	0x04
#define REG_MON		0x05
#define REG_YEAR	0x06
#define REG_CON		0x0e
#define REG_STATUS	0x0f
#define REG_AGING	0x10
#define REG_TEMPM	0x11
#define REG_TEMPL	0x12
#define SEC_1970_TO_2000 946684800
static const uint8_t dim[] = { 31,28,31,30,31,30,31,31,30,31,30,31 };
/* Public */
Time::Time()
	this->year = 2014;
	this->mon  = 1;
	this->date = 1;
	this->hour = 0;
	this->min  = 0;
	this->sec  = 0;
	this->dow  = 3;
DS3231::DS3231(uint8_t data_pin, uint8_t sclk_pin)
	_sda_pin = data_pin;
	_scl_pin = sclk_pin;
Time DS3231::getTime()
	Time t;
	_burstRead();
	t.sec	= _decode(_burstArray[0]);
	t.min	= _decode(_burstArray[1]);
	t.hour	= _decodeH(_burstArray[2]);
	t.dow	= _burstArray[3];
	t.date	= _decode(_burstArray[4]);
	t.mon	= _decode(_burstArray[5]);
	t.year	= _decodeY(_burstArray[6])+2000;
	return t;
void DS3231::setTime(uint8_t hour, uint8_t min, uint8_t sec)
	if (((hour>=0) && (hour<24)) && ((min>=0) && (min<60)) && ((sec>=0) && (sec<60)))
		_writeRegister(REG_HOUR, _encode(hour));
		_writeRegister(REG_MIN, _encode(min));
		_writeRegister(REG_SEC, _encode(sec));
void DS3231::setDate(uint8_t date, uint8_t mon, uint16_t year)
	if (((date>0) && (date<=31)) && ((mon>0) && (mon<=12)) && ((year>=2000) && (year<3000)))
		year -= 2000;
		_writeRegister(REG_YEAR, _encode(year));
		_writeRegister(REG_MON, _encode(mon));
		_writeRegister(REG_DATE, _encode(date));
void DS3231::setDOW()
	int dow;
	byte mArr[12] = {6,2,2,5,0,3,5,1,4,6,2,4};
	Time _t = getTime();
	dow = (_t.year % 100);
	dow = dow*1.25;
	dow += _t.date;
	dow += mArr[_t.mon-1];
	if (((_t.year % 4)==0) && (_t.mon<3))
		dow -= 1;
	while (dow>7)
		dow -= 7;
	_writeRegister(REG_DOW, dow);
void DS3231::setDOW(uint8_t dow)
	if ((dow>0) && (dow<8))
char *DS3231::getTimeStr(uint8_t format)
	static char output[] = "xxxxxxxx";
	Time t;
	t=getTime();
	if (t.hour<10)
		output[0]=48;
		output[0]=char((t.hour / 10)+48);
	output[1]=char((t.hour % 10)+48);
	output[2]=58;
	if (t.min<10)
		output[3]=48;
		output[3]=char((t.min / 10)+48);
	output[4]=char((t.min % 10)+48);
	output[5]=58;
	if (format==FORMAT_SHORT)
		output[5]=0;
	if (t.sec<10)
		output[6]=48;
		output[6]=char((t.sec / 10)+48);
	output[7]=char((t.sec % 10)+48);
	output[8]=0;
	return (char*)&output;
char *DS3231::getDateStr(uint8_t slformat, uint8_t eformat, char divider)
	static char output[] = "xxxxxxxxxx";
	int yr, offset;
	Time t;
	t=getTime();
	switch (eformat)
		case FORMAT_LITTLEENDIAN:
			if (t.date<10)
				output[0]=48;
				output[0]=char((t.date / 10)+48);
			output[1]=char((t.date % 10)+48);
			output[2]=divider;
			if (t.mon<10)
				output[3]=48;
				output[3]=char((t.mon / 10)+48);
			output[4]=char((t.mon % 10)+48);
			output[5]=divider;
			if (slformat==FORMAT_SHORT)
				yr=t.year-2000;
				if (yr<10)
					output[6]=48;
					output[6]=char((yr / 10)+48);
				output[7]=char((yr % 10)+48);
				output[8]=0;
				yr=t.year;
				output[6]=char((yr / 1000)+48);
				output[7]=char(((yr % 1000) / 100)+48);
				output[8]=char(((yr % 100) / 10)+48);
				output[9]=char((yr % 10)+48);
				output[10]=0;
		case FORMAT_BIGENDIAN:
				offset=0;
				offset=2;
				yr=t.year-2000;
				if (yr<10)
					output[0]=48;
					output[0]=char((yr / 10)+48);
				output[1]=char((yr % 10)+48);
				output[2]=divider;
				yr=t.year;
				output[0]=char((yr / 1000)+48);
				output[1]=char(((yr % 1000) / 100)+48);
				output[2]=char(((yr % 100) / 10)+48);
				output[3]=char((yr % 10)+48);
				output[4]=divider;
			if (t.mon<10)
				output[3+offset]=48;
				output[3+offset]=char((t.mon / 10)+48);
			output[4+offset]=char((t.mon % 10)+48);
			output[5+offset]=divider;
			if (t.date<10)
				output[6+offset]=48;
				output[6+offset]=char((t.date / 10)+48);
			output[7+offset]=char((t.date % 10)+48);
			output[8+offset]=0;
		case FORMAT_MIDDLEENDIAN:
			if (t.mon<10)
				output[0]=48;
				output[0]=char((t.mon / 10)+48);
			output[1]=char((t.mon % 10)+48);
			output[2]=divider;
			if (t.date<10)
				output[3]=48;
				output[3]=char((t.date / 10)+48);
			output[4]=char((t.date % 10)+48);
			output[5]=divider;
				yr=t.year-2000;
				if (yr<10)
					output[6]=48;
				output[8]=0;
				yr=t.year;
				output[10]=0;
char *DS3231::getDOWStr(uint8_t format)
	char *output = "xxxxxxxxxx";
	char *daysLong[]  = {"Monday", "Tuesday", "Wednesday", "Thursday", "Friday", "Saturday", "Sunday"};
	char *daysShort[] = {"Mon", "Tue", "Wed", "Thu", "Fri", "Sat", "Sun"};
	Time t;
	t=getTime();
	if (format == FORMAT_SHORT)
		output = daysShort[t.dow-1];
		output = daysLong[t.dow-1];
	return output;
char *DS3231::getMonthStr(uint8_t format)
	char *output= "xxxxxxxxx";
	char *monthLong[]  = {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"};
	char *monthShort[] = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
	Time t;
	t=getTime();
		output = monthShort[t.mon-1];
		output = monthLong[t.mon-1];
	return output;
long DS3231::getUnixTime(Time t)
	uint16_t	dc;
	dc = t.date;
	for (uint8_t i = 0; i<(t.mon-1); i++)
		dc += dim[i];
	if ((t.mon > 2) && (((t.year-2000) % 4) == 0))
		++dc;
	dc = dc + (365 * (t.year-2000)) + (((t.year-2000) + 3) / 4) - 1;
	return ((((((dc * 24L) + t.hour) * 60) + t.min) * 60) + t.sec) + SEC_1970_TO_2000;
void DS3231::enable32KHz(bool enable)
  uint8_t _reg = _readRegister(REG_STATUS);
  _reg &= ~(1 << 3);
  _reg |= (enable << 3);
  _writeRegister(REG_STATUS, _reg);
void DS3231::setOutput(byte enable)
  uint8_t _reg = _readRegister(REG_CON);
  _reg &= ~(1 << 2);
  _reg |= (enable << 2);
  _writeRegister(REG_CON, _reg);
void DS3231::setSQWRate(int rate)
  _reg &= ~(3 << 3);
  _reg |= (rate << 3);
float DS3231::getTemp()
	uint8_t _msb = _readRegister(REG_TEMPM);
	uint8_t _lsb = _readRegister(REG_TEMPL);
	return (float)_msb + ((_lsb >> 6) * 0.25f);
/* Private */
void	DS3231::_sendStart(byte addr)
	pinMode(_sda_pin, OUTPUT);
	digitalWrite(_sda_pin, HIGH);
	digitalWrite(_scl_pin, HIGH);
	digitalWrite(_sda_pin, LOW);
	digitalWrite(_scl_pin, LOW);
	shiftOut(_sda_pin, _scl_pin, MSBFIRST, addr);
void	DS3231::_sendStop()
	pinMode(_sda_pin, INPUT);
void	DS3231::_sendNack()
void	DS3231::_sendAck()
void	DS3231::_waitForAck()
	while (digitalRead(_sda_pin)==HIGH) {}
uint8_t DS3231::_readByte()
	uint8_t value = 0;
	uint8_t currentBit = 0;
	for (int i = 0; i < 8; ++i)
		currentBit = digitalRead(_sda_pin);
		value |= (currentBit << 7-i);
		delayMicroseconds(1);
	return value;
void DS3231::_writeByte(uint8_t value)
	shiftOut(_sda_pin, _scl_pin, MSBFIRST, value);
uint8_t	DS3231::_decode(uint8_t value)
	uint8_t decoded = value & 127;
	decoded = (decoded & 15) + 10 * ((decoded & (15 << 4)) >> 4);
	return decoded;
uint8_t DS3231::_decodeH(uint8_t value)
  if (value & 128)
    value = (value & 15) + (12 * ((value & 32) >> 5));
    value = (value & 15) + (10 * ((value & 48) >> 4));
  return value;
uint8_t	DS3231::_decodeY(uint8_t value)
	uint8_t decoded = (value & 15) + 10 * ((value & (15 << 4)) >> 4);
	return decoded;
uint8_t DS3231::_encode(uint8_t value)
	uint8_t encoded = ((value / 10) << 4) + (value % 10);
	return encoded;
Ok so i tried adding this to the header code and I am getting the following errors after trying to compile it.
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.cpp.o:(.literal._Z5setupv+0x8): undefined reference to `DS3231::begin()'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\src\main.cpp.o: in function `setup()':
C:\Users\Aditya\Documents\PlatformIO\Projects\Set_time_ds3231/src/main.cpp:31: undefined reference to `DS3231::begin()'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\liba69\libDS3231.a(DS3231.cpp.o):(.literal._ZN6DS32317setTimeEhhh+0x0): undefined reference to `DS3231::_writeRegister(unsigned char, unsigned char)'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\liba69\libDS3231.a(DS3231.cpp.o):(.literal._ZN6DS32317getTimeEv+0x0): undefined reference to `DS3231::_burstRead()'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\liba69\libDS3231.a(DS3231.cpp.o): in function `DS3231::setTime(unsigned char, unsigned char, unsigned char)':
C:\Users\Aditya\Documents\PlatformIO\Projects\Set_time_ds3231/lib/DS3231/DS3231.cpp:89: undefined reference to `DS3231::_writeRegister(unsigned char, unsigned char)'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Aditya\Documents\PlatformIO\Projects\Set_time_ds3231/lib/DS3231/DS3231.cpp:90: undefined reference to `DS3231::_writeRegister(unsigned char, unsigned char)'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Aditya\Documents\PlatformIO\Projects\Set_time_ds3231/lib/DS3231/DS3231.cpp:91: undefined reference to `DS3231::_writeRegister(unsigned char, unsigned char)'
c:/users/aditya/.platformio/packages/toolchain-xtensa-esp32/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: .pio\build\esp32dev\liba69\libDS3231.a(DS3231.cpp.o): in function `DS3231::getTime()':
C:\Users\Aditya\Documents\PlatformIO\Projects\Set_time_ds3231/lib/DS3231/DS3231.cpp:74: undefined reference to `DS3231::_burstRead()'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\esp32dev\firmware.elf] Error 1
You omitted the hardware file where all the real changes would be required due to all the processor register bit twiddling (and incidentally, where all your undefined references are).
First reaction? Wow, what a contorted way of avoiding using the Wire library. Had the original author used the Wire library, you likely wouldn't be in this pickle.
HW_AVR.h
void DS3231::begin()
	if ((_sda_pin == SDA) and (_scl_pin == SCL))
		_use_hw = true;
		// activate internal pullups for twi.
		digitalWrite(SDA, HIGH);
		digitalWrite(SCL, HIGH);
		//delay(1);  // Workaround for a linker bug
		// initialize twi prescaler and bit rate
		cbi(TWSR, TWPS0);
		cbi(TWSR, TWPS1);
		TWBR = ((F_CPU / TWI_FREQ) - 16) / 2;
		// enable twi module, acks, and twi interrupt
		TWCR = _BV(TWEN) | _BV(TWIE)/* | _BV(TWEA)*/;
		_use_hw = false;
		pinMode(_scl_pin, OUTPUT);
void DS3231::_burstRead()
	if (_use_hw)
		// Send start address
		TWCR = _BV(TWEN) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTA);						// Send START
		while ((TWCR & _BV(TWINT)) == 0) {};										// Wait for TWI to be ready
		TWDR = DS3231_ADDR_W;
		TWCR = _BV(TWEN) | _BV(TWINT) | _BV(TWEA);									// Clear TWINT to proceed
		TWDR = 0;
		// Read data starting from start address
		TWCR = _BV(TWEN) | _BV(TWEA) | _BV(TWINT) | _BV(TWSTA);						// Send rep. START
		TWDR = DS3231_ADDR_R;
		for (int i=0; i<7; i++)
			TWCR = _BV(TWEN) | _BV(TWINT) | _BV(TWEA);								// Send ACK and clear TWINT to proceed
			_burstArray[i] = TWDR;
		TWCR = _BV(TWEN) | _BV(TWINT);												// Send NACK and clear TWINT to proceed
		TWCR = _BV(TWEN)| _BV(TWINT) | _BV(TWSTO);									// Send STOP
		_sendStart(DS3231_ADDR_W);
		_waitForAck();
		_writeByte(0);
		_waitForAck();
		_sendStart(DS3231_ADDR_R);
		_waitForAck();
			_burstArray[i] = _readByte();
			if (i<6)
				_sendAck();
				_sendNack();
		_sendStop();
uint8_t DS3231::_readRegister(uint8_t reg)
	uint8_t	readValue=0;
	if (_use_hw)
		TWDR = reg;
		readValue = TWDR;
		_waitForAck();
		_writeByte(reg);
		_waitForAck();
		_waitForAck();
		readValue = _readByte();
		_sendNack();
		_sendStop();
	return readValue;
void DS3231::_writeRegister(uint8_t reg, uint8_t value)
	if (_use_hw)
		TWDR = reg;
		TWDR = value;
		_waitForAck();
		_writeByte(reg);
		_waitForAck();
		_writeByte(value);
		_waitForAck();
		_sendStop();
Yes. There have been other issues with this library reported over time in these threads. I think that changing to RTCLib or one of the other more widely used libraries would be a more simple path to take.
Sorry but I don't really understand. What exactly should I be doing in the library to make it work for my board. From the looks of it I understand that the library that I am using is utilizing a niche way to define the hardware component. If possible can you guide what changes should I do because the main code is really long and switching to a new library with all new function definitions would be hectic.
Actually this library was working great when I was using it with my Arduino nano board. But now that I had to switch to ESP32 its giving me some troubles. My earlier impression was that it would be quite simple switching from Arduino to ESP32 as the ESP32 also supports the arduino framework but now well.....
A simpler solution might be not to use an RTC. Then the troublesome library will no longer be needed.
ESP32 can get time from the internet when it starts up and stay synchronised to keep the time accurate. Almost no code is required for this, as all the required functions are included in the ESP32 Arduino core.
Sorry, but I've run into this library before and I have no desire to work with it again.
My advice to you would be to pick another RTC library. If you truly don't want to rewrite your code, write a compatibility layer to make the new library look like the rinky-dink one.
The library does not do very much (for example, no alarms etc.). What methods from it have you used in your previous code ? It should not be too difficult to write a few wrapper routines for another DS3231 library which is already ESP32 compatible so that changes to your existing code are at a minimum.
Actually I am not connecting my ESP32 to the internet in my project
I dont really know how to make the compatibility layer that you are talking abouy
The library is particularly used for a suffisticated Menu system where I am basically setting date and time and logging the date and time at particular instamces of sensor data. This might not seem huge but referejces of the library functions and calls are too much. Switching to new library would be a huge task but if I looking at other people comments I dont think I have any option. Any library you or anyone else suggest for the DS3231 Library that works great with the ESP32 board
I can't make a specific recommendation for a DS3231 library which is compatible with the ESP32. I use an ancient hacked library myself and need to avoid using the Arduino time library (Time.h/TimeLib.h) but I hope someone else can make such a recommendation.
As for your usage of the Rinky-Dink Electronics library, can you show a sample sketch where you set the time and read the time. If you use multiple variants of the possible set time and read time methods, try to show those also.
Sure here's the code sketch to set and read time in my application:
#include <Arduino.h>
#include <DS3231.h>
LiquidCrystal_I2C lcd(0x27, 16, 2);
DS3231 rtc(SDA, SCL);
Time t;
int currentDigit = 0; // Current digit being edited (0 for hours tens, 1 for hours ones, 2 for minutes tens, etc.)
int timeInput[6];     // Array to store user input for hours tens, hours ones, minutes tens, minutes ones, seconds tens, and seconds ones
#define BUTTON_UP 2
#define BUTTON_DOWN 3
#define BUTTON_ENTER 4
#define BUTTON_BACK 5
unsigned long lastDebounceTime = 0;
unsigned long debounceDelay = 150;
bool isSetTimeMode = false; // Flag to indicate if in set time mode
void displayTime();
void adjustTime(int direction);
void switch_digit();
void set_time();
    lcd.init();
    lcd.backlight();
    rtc.begin();
    pinMode(BUTTON_ENTER, INPUT_PULLUP);
    pinMode(BUTTON_UP, INPUT_PULLUP);
    pinMode(BUTTON_DOWN, INPUT_PULLUP);
    pinMode(BUTTON_BACK, INPUT_PULLUP);
    if (!isSetTimeMode)
        // Fetch current time from RTC
        t = rtc.getTime();
        timeInput[0] = t.hour / 10; // Tens digit of hours
        timeInput[1] = t.hour % 10; // Ones digit of hours
        timeInput[2] = t.min / 10;  // Tens digit of minutes
        timeInput[3] = t.min % 10;  // Ones digit of minutes
        timeInput[4] = t.sec / 10;  // Tens digit of seconds
        timeInput[5] = t.sec % 10;  // Ones digit of seconds
    displayTime();
    // Check for button presses
    if (digitalRead(BUTTON_UP) == LOW)
        adjustTime(1); // Increment time
        isSetTimeMode = true;
        delay(debounceDelay); // Debounce delay
    if (digitalRead(BUTTON_DOWN) == LOW)
        adjustTime(-1); // Decrement time
    if (digitalRead(BUTTON_ENTER) == LOW)
        switch_digit(); // Switch to the next digit
    if (digitalRead(BUTTON_BACK) == LOW)
        set_time();    // Set the time
void displayTime()
    lcd.setCursor(0, 0);
    lcd.print("Set Time:");
    lcd.setCursor(3, 1);
    for (int i = 0; i < 6; i++)
        lcd.print(timeInput[i]); // Display each digit of the time
        if (i == 1 || i == 3)
            lcd.print(":"); // Add colon between hours, minutes, and seconds
    // Increment or decrement the current digit
    timeInput[currentDigit] += direction;
    // Ensure the digit stays within valid range
    switch (currentDigit)
    case 0: // Tens digit of hours
        if (timeInput[currentDigit] > 2)
            timeInput[currentDigit] = 0;
        else if (timeInput[currentDigit] < 0)
            timeInput[currentDigit] = 2;
        if (timeInput[currentDigit] == 2 && timeInput[1] > 3) // If the tens digit is 2 and the ones digit exceeds 3, wrap it around
            timeInput[1] = 0;
    case 1: // Ones digit of hours
        if (timeInput[0] == 2) {
            if (timeInput[currentDigit] > 3)
                timeInput[currentDigit] = 3;
            if (timeInput[currentDigit] > 9)
                timeInput[currentDigit] = 9;
    case 2: // Tens digit of minutes
        if (timeInput[currentDigit] > 5)
            timeInput[currentDigit] = 5;
    case 3: // Ones digit of minutes
    case 4: // Tens digit of seconds
    case 5: // Ones digit of seconds
void switch_digit()
    // Move to the next digit
    currentDigit++;
    // Wrap around if reached the last digit
    if (currentDigit > 5)
        currentDigit = 0;
void set_time()
    // Set the RTC time based on the entered values
    rtc.setTime(timeInput[0] * 10 + timeInput[1], timeInput[2] * 10 + timeInput[3], timeInput[4] * 10 + timeInput[5]);
    // Print message indicating time has been set
    lcd.clear(); // Clear the display
    lcd.print("Time Set!");
    delay(2000); // Display the message for 2 seconds
