Converting byte arrays to strings
Hello,
my program involves hashing, and the hashing library takes strings as inputs.
However because I need to store many hash values in memory (more than 20, 256-bits each) and these are dynamically changed, I cannot fit them into memory so I thought I could change them into byte arrays. However this involves storing the initial values in flash memory and convert them into Byte arrays, then convert them back to strings so I can hash them.
The problem is with the following snippet, I have an array_to_string() function which works for one bytearray, but if I add a second then the program misbehaves (doesn't output anything).
Anyone has an idea of what could be wrong?
const byte MaxByteArraySize = 32;
void hexCharacterStringToBytes(byte *byteArray, const char *hexString)
  bool oddLength = strlen(hexString) & 1;
  byte currentByte = 0;
  byte byteIndex = 0;
  for (byte charIndex = 0; charIndex < strlen(hexString); charIndex++)
    bool oddCharIndex = charIndex & 1;
    if (oddLength)
      // If the length is odd
      if (oddCharIndex)
        // odd characters go in high nibble
        currentByte = nibble(hexString[charIndex]) << 4;
        // Even characters go into low nibble
        currentByte |= nibble(hexString[charIndex]);
        byteArray[byteIndex++] = currentByte;
        currentByte = 0;
      // If the length is even
      if (!oddCharIndex)
        // Odd characters go into the high nibble
        // Odd characters go into low nibble
        currentByte = 0;
byte nibble(char c)
  if (c >= '0' && c <= '9')
    return c - '0';
  if (c >= 'a' && c <= 'f')
    return c - 'a' + 10;
  if (c >= 'A' && c <= 'F')
    return c - 'A' + 10;
  return 0;  // Not a valid hexadecimal character
String array_to_string(byte array[], unsigned int len)
    char buffer[32];
    for (unsigned int i = 0; i < len; i++)
        byte nib1 = (array[i] >> 4) & 0x0F;
        byte nib2 = (array[i] >> 0) & 0x0F;
        buffer[i*2+0] = nib1  < 0xA ? '0' + nib1  : 'A' + nib1  - 0xA;
        buffer[i*2+1] = nib2  < 0xA ? '0' + nib2  : 'A' + nib2  - 0xA;
    //buffer[len*2] = '\0';
    return (String(buffer));
  byte byteArray[MaxByteArraySize] = {0};
  byte byteArray2[MaxByteArraySize] = {0};
  hexCharacterStringToBytes(byteArray, "173af653133d964edfc16cafe0aba33c8f500a07f3ba3f81943916910c257705");
  Serial.println(array_to_string(byteArray,32));
  hexCharacterStringToBytes(byteArray2, "3a397279c72e019a31729d7536dfd407c37cc63dcde44a0222be2e098d85181a"); //
  Serial.println(array_to_string(byteArray2,32)); //if I comment these 2 lines out then the output for the first byteArray works..
void loop() {}
What library? Post a link to the library.
What do you mean by "strings"? If you mean String objects, these are to be avoided on Arduino, because they cause memory problems and program crashes. C-strings are zero terminated character arrays, like "12345".
Please try to clearly describe exactly what you are trying to do. Posting snippets is not useful.
20 x 256 bit hash values require 640 bytes of storage. No problem there.
The library is this one Arduino Cryptography Library: SHA256 Class Reference
(from Tools->Manage libraries)
I also see it here arduinolibs/libraries/Crypto at master · rweather/arduinolibs · GitHub
Here is my complete code. This works fine for up to 6 hash values (SIGMA = 6 in the code). However if I add more the program misbehaves and I also get dynamic memory warnings. Think for 20 values it doesn't work at all.
So my ultimate goal is to minimize memory usage, that's why I thought of converting the hash values to byte arrays...
#include <Crypto.h>
#include <SHA256.h>
#include <string.h>
#define HASH_SIZE 32
#define BLOCK_SIZE 64
#define OUTPUT_MAX 32
#include <limits.h> //for infinity
char hex[256];
char *btoh(char *dest, uint8_t *src, int len) {
  char *d = dest;
  while( len-- ) sprintf(d, "%02x", (unsigned char)*src++), d += 2;
  return dest;
void PrintHex8(uint8_t *data, uint8_t length) // prints 8-bit data in hex with leading zeroes
     char tmp[16];
       for (int i=0; i<length; i++) {
         sprintf(tmp, "0x%.2X",data[i]);
         Serial.print(tmp); Serial.print(" ");
char* h(String input) {
SHA256 hash;
uint8_t result[32];
hash.reset();
hash.update(input.c_str(), input.length());
hash.finalize(result, sizeof(result));
  return(btoh(hex, result, 32));
//Pebble code
unsigned int SIGMA = 6;
//Stop function
void stop()
 while(1);
typedef struct Pebble{
  int StartIncr;
  int DestIncr;
  int position;
  int destination;
  String value;
String FindValue(struct Pebble pebble_List[])
  for (int i = 1; i < SIGMA; i++)
        if (pebble_List[i].position == pebble_List[0].position) {
            return pebble_List[i].value;
int struct_cmp_by_destin(const void *a, const void *b)
    struct Pebble *ia = (struct Pebble *)a;
    struct Pebble *ib = (struct Pebble *)b;
    return (ia->destination - ib->destination);
unsigned int Pow2(byte ex)
   return 1 << ex;
  //boolean DEBUG = 0;
  Pebble pebblelist[SIGMA];
  for (int i = 0; i < SIGMA; i++) {
    pebblelist[i].StartIncr = 3*Pow2(i+1);
    pebblelist[i].DestIncr = Pow2(i+2) ;
    pebblelist[i].position = Pow2(i+1);
    pebblelist[i].destination = Pow2(i+1);
  pebblelist[0].value = "dbd575734d4c87e9287ee5233e9b83611004f9f996befbc9b68d34d4e423bd98";
  pebblelist[1].value = "3a397279c72e019a31729d7536dfd407c37cc63dcde44a0222be2e098d85181a";
  pebblelist[2].value = "701e771b21edc950887818f5c41a5ac3f0e8b471318599aef9c836291987c82f";
  pebblelist[3].value = "c5c6432924112bb666e4eec23d9855c3d817416b36a2a9dfd0acb968a07f203f";
  pebblelist[4].value = "6a85d015df7b6be69c75a9067945052117c4da060d1e95fc3f59079d36216da2";
  pebblelist[5].value = "a665a45920422f9d417e4867efdc4fb8a04a1f3fff1fa07e998e86f7f7a27ae3";
  unsigned int currentposition = 0;
  while(1) {
  //Serial.print("Hash ");
  //Serial.println(currentposition);
  //delay(500);
  //1
  if (currentposition >= Pow2(SIGMA) ) { stop();}
  else {currentposition++ ;};
  //2
    if (pebblelist[i].position != pebblelist[i].destination) {
      pebblelist[i].position = pebblelist[i].position -2;
      pebblelist[i].value = h(h(pebblelist[i].value));
  String output;
  //3
  if (currentposition % 2 == 1 ) {
    output = h(pebblelist[0].value);
  else {
    output = pebblelist[0].value;
    pebblelist[0].position = pebblelist[0].position + pebblelist[0].StartIncr;
    pebblelist[0].destination = pebblelist[0].destination + pebblelist[0].DestIncr;
    if (pebblelist[0].destination > Pow2(SIGMA) ) {
        pebblelist[0].destination = INT_MAX;
        pebblelist[0].position = INT_MAX;
    else {
        pebblelist[0].value = FindValue(pebblelist);
    qsort(pebblelist, sizeof(pebblelist)/sizeof(pebblelist[0]), sizeof(pebblelist[0]), struct_cmp_by_destin);
  Serial.println(output);
Each two characters in the string becomes one byte, so you will save the data in half the space.
What IS the problem? Grabbing two characters at a time from a string is trivial. Converting the 2 characters to a byte is simple. Storing the resulting value in an array is a no-brainer.
pan19ss:
PaulS:
Example:
char srcArray[] = {0x31, 0x32, 0x33, 0x34, 0x35, 0x46};
byte destArray[3];   //12 34 5F
  for (int i = 0, j = 0; i < sizeof(srcArray) - 2, j < sizeof(srcArray) / 2; i = i + 2, j++)
    byte x = hexDigit(srcArray[i]);    //scArray[0] = 0x31; x = 01
    x = x << 4;                              //x = 10
    // Serial.println(x, HEX);
    byte z = hexDigit(srcArray[i + 1]);  //srcArray[1] = 0x32; z = 02
    z = x | z;                                      // z = 12
    //  Serial.println(z, HEX);
    destArray[j] = z;                            //destArray[0] = 12
  for (int i = 0; i < 3; i++)
    Serial.print(destArray[i], HEX);  //shows: 12 34 5F
    Serial.print(' ');
byte hexDigit(byte y)
  if (y <= 0x39)
    y = (y - 0x30);  //01
    y = (y - 0x37);
  return y;
Why do you insist on providing examples that do NOT match what the OP has?
char srcArray[] = "12345F";
This is certainly a problem:
 String value;
To achieve your goal and vastly increase operational reliability:
  1. Don't use Strings
  2. As already mentioned, convert hex character data arrays to byte data arrays, and cut space requirements in half
PaulS:
Strictly speaking, I should have declared the array in my example as:
char srcArray[] = {'1', '2', '3', '4', '5', 'F', '\0'};
in order to maintain consistency with @PaulS's following statement:
Ok so yes I have understood that string is "bad" in arduino. However the I am trying to make the hashing function work with char instead of strings but it outputs incorrect values.
Here's a minimal working example of what I mean. h1() which uses string outputs the correct hash of value1 (starts with "6db...") but h2() which uses char outputs wrong hash.
Here's the usage example also from the library.
#include <Crypto.h>
#include <SHA256.h>
#include <string.h>
char hex[256];
const char*  value1 = "dbd575734d4c87e9287ee5233e9b83611004f9f996befbc9b68d34d4e423bd98";
  char *d = dest;
  return dest;
char* h1(String input) {
SHA256 hash;
uint8_t result[32];
hash.reset();
char* h2(char* input) {
SHA256 hash;
uint8_t result[32];
hash.reset();
hash.update(input, sizeof(input));
//hash.update(input.c_str(), input.length());
  Serial.println(h1(value1));
  Serial.println(h2(value1));
There are no Strings in the linked example code. Start with that and do not use Strings for anything.
jremington:
Ok can you please suggest how to fix my hash function h2() ? I've been struggling with this so long and can't find how to do this right..
You are confusing the size of a character pointer with the length of a character string. To demonstrate that, I've added a couple of debug prints to the function h2().
The fix should be immediately obvious.
SHA256 hash;
Serial.print("sizeof(input) ");
Serial.println(sizeof(input));
Serial.print("strlen(input) ");
Serial.println(strlen(input));
uint8_t result[32];
hash.reset();
PS: this should not be in the function:
SHA256 hash;
Understood, thanks!
