I am trying to convert Celsius to Fahrenheit reading from a DHT11and displaying onto a 1602 LCD display. It continues to show "32" as the temperature, but if I have it output in Celsius its giving around 20.8.
Here is the code I am running.
#include <DHT_Async.h>
#define DHT_SENSOR_TYPE DHT_TYPE_11
#include <LiquidCrystal.h>
static const int DHT_SENSOR_PIN = 7;
DHT_Async dht_sensor( DHT_SENSOR_PIN, DHT_SENSOR_TYPE );
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
void setup( )
lcd.begin(16, 2);
lcd.print( "T = " );
lcd.setCursor(10, 0);
lcd.print( "deg. F" );
lcd.setCursor(0, 1);
lcd.print( "H = " );
lcd.setCursor(10, 1);
lcd.print( "%" );
static bool measure_environment( float *temperature, float *humidity )
static unsigned long measurement_timestamp = millis( );
if( millis( ) - measurement_timestamp > 3000ul )
if( dht_sensor.measure( temperature, humidity ) == true )
return( true );
return( false );
void loop( )
float temperature;
float humidity;
float tempF;
tempF = (temperature * 1.8)+32.0;
if( measure_environment( &temperature, &humidity ) == true )
lcd.setCursor(4, 0);
lcd.print( tempF );
lcd.setCursor(4, 1);
lcd.print( humidity );
