Hey guys! I'm working on a project that I can't share too much about, but one of the things we need to do is convert decimal values to an array of 8bit hex values. and back again. but also from dec to just hex. and from hex to 8bit array of hex.
so for example from:
the values are just examples int num = 609 to uint8_t bitArray[4] = {0x01, 0x01, 0x02, 0x01} //whatever 609 value may be in this format
but also the other way around.
I also need to be able to go from: 0x45e454f32 to the array format and back.
I've done some extensive googling over the course of 2 days and found nothing quite like this. it either means that this is silly and shouldn't be done in the first place, or I'm just completely misunderstanding the explanations out there.
the idea is to standardise all the data that the Arduino sends into the array format.
It is straightforward to write a program that accepts numerical input, and outputs text, suitable for incorporation into your source code, in forms similar to this:
we have a few sensors, some outputting in integer format eg: 4542 and other in hex format eg: 0x438e82 and others in the uint8_t format eg: {0x01, 0x01, 0x02, 0x01, 0x01, 0x01, 0x02, 0x01}
the idea is to convert all of it to the array format and send that array over serial.
I'm only having trouble with the conversion because for some reason there isn't a recourse on that kind of conversation in one convenient place and thought I would kill 2 stones with one bird and get it in one spot, and ask about it for myself.
The important thing to remember is that you're not really "converting" between hex & decimal.Everything in the processor (or computer) is binary and the conversions are just for input/output, usually for humans so most-often we use decimal in our code and we print/display in decimal...
But you can also print-as hex, octal, or binary. Nothing about the variable changes, just what's displayed/printed.
So... If you copy a type long into a type char (or type byte) we get the low byte (8 least-significant bits). If you shift-right 8-bits, those bits are lost and you can do the same thing again ("copy" to a char or byte) to get the next byte and save it as a different variable or to a different array position.
BTW - For troubleshooting the Windows Calculator in Programmer mode can convert between decimal & binary. It won't group the hex value as bytes, but each pair of hex values represents a byte so you'll see what should be in your array.
And if you don't already know this the text character representing a digit is different from its numerical value. The character representing a '1' is stored-as 49 decimal (= 31 hex =00110001 binary). Most of the time the software "knows" the context so it knows it's supposed to be the character '1' and not the value 49). (ASCII table )
