Converting Hex to Decimal
Hi, I'm working on an RFID door lock system. For now I'm just trying to get my program to distinguish between a "good" card and a "bad" card. My problem is that it is reading the card in Hex (pretty sure) and when I try to use that number in the program, there's an error saying it's an invalid interger. I really haven't had much experience with programming so any help is appreciated.
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
int  val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW);                  // Activate the RFID reader
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
      digitalWrite(2, HIGH);                  // deactivate the RFID reader for a moment so it will not flood
           delay(1500);                       // wait for a bit
// extra stuff
// digitalWrite(2, HIGH);             // deactivate RFID reader
That's the stock code I'm running from the arduino website.
Perhaps there's a way to get it to just read in decimal instead of hex?
The value being read from the RFID tag is reported as neither HEX or decimal. It is a string of characters. You need to use strcmp() to compare that string to a (set of) known value(s).
That code looks pretty much bugged.
use char code[11];
and add code[bytesread]=0 before the if (bytesread==10).
the code you read is a string, so you usually need to convert it and you can try to use the sscanf function, i.e.:
   unsigned long value;
   sscanf(code,"%x", &value); // if hex string
BUT (and this is crucially important), the RFID will give you a 40 bits code, which does not fit in a 32bit unsigned integer value.
So, if you convert it in an unsigned long you loose 8bits. Even worse, if you use unsigned int you will loose much more. You should continue to use the string as is for further processing.
HTH
I agree. Treat the string of characters as a string of characters.
Might be a good time to use the String type:
// PARALLAX RFID VCC     to Arduino 5V
// PARALLAX RFID /ENABLE to Arduino D2
// PARALLAX RFID SOUT    to Arduino D3
// PARALLAX RFID GND     to Arduino Gnd
// Modified by Worapoht K.
#include <SoftwareSerial.h>
int  val = 0;
String code;
int bytesread = 0;
#define enablePin 2
#define rxPin 3
#define txPin 4
SoftwareSerial RFID = SoftwareSerial(rxPin, txPin);
#define START_CHAR 10
#define END_CHAR 13
  Serial.begin(9600);  // Hardware serial for Monitor 2400bps
  RFID.begin(2400);    // RFID reader SOUT at 2400bps
  pinMode(enablePin,OUTPUT);       // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(enablePin, LOW);    // Activate the RFID reader
  code = "";
  // Wait for header byte
  while(RFID.read() != START_CHAR) ;
  for (bytesread = 0; bytesread < 10; bytesread++)
    val = RFID.read();
    if (val == END_CHAR)
    code += val;     // append the character
  digitalWrite(enablePin, HIGH);    // Deactivate the RFID reader
  if (bytesread == 10)
    if (code == "48524953696548555648")
      Serial.println("That's the round tag.");
    if (code == "48704851485249505067")
      Serial.println("That's the rectangular tag.");
  delay(1000);                       // wait for a second
I notice that my Parallax RFID was getting spurious hits.  Probably best to check the END_CHAR as well as the START_CHAR rather than accepting nay 10 characters that follow a START_CHAR:
{code]
#define enablePin 2
#define rxPin 3
#define txPin 4
#define END_CHAR 13
  int bytesread, val;
  String code = "";
    /* DO NOTHING */    ;
  bytesread = 0;
  while ((val = RFID.read()) != END_CHAR)
    if (val == START_CHAR)
      break; // Bad frame
    bytesread++;
    if (bytesread > 10)
      break;  // Too many characters
  if (bytesread == 10)  // Valid read.  10 characters + END_CHAR
        Serial.print("Unrecognized code: ");   // possibly a good TAG
Thank you so much for the help! That got me on the right track.
So here's the modified version of your code that I'm going to use. It needs a little bit of work yet, as there is a bug that leaves pin 4 active from when the program starts running until you swipe a good card. But I think I'll just deal with it and swipe a card when i start it up.
// Modified by Alex G.
#define enablePin 2
#define rxPin 3
#define txPin 4
#define END_CHAR 13
  pinMode(4,OUTPUT);               // Set digital pin 4 as OUTPUT to connect it to the lock relay
  pinMode(5,OUTPUT);               // Set digital pin 5 as OUTPUT to connect it to the buzzer
  int bytesread, val;
  String code = "";
    /* DO NOTHING */    ;
  bytesread = 0;
      break; // Bad frame
    bytesread++;
    if (bytesread > 10)
      if (code == "50544848685656485166","50544848685667505470")  // add allowed tags in this area
        Serial.println("That's a good tag.");  // good tag
        digitalWrite(4,HIGH);                  // activate lock relay for 5 seconds
        delay(5000);
        digitalWrite(4,LOW);
        Serial.print("Invalid Tag: ");   // tag not allowed.  Use this number from the serial monitor to add new cards to program.
        digitalWrite(5, HIGH);           // sound buzzer or alarm for 3 seconds
        delay(3000);
        digitalWrite(5, LOW);
Thanks again for the help. The only other code I found for a similar project was on Instructables. But I like having the ability to put the tags into the program myself instead of using the Master and Delete cards. Hopefully this helps out somebody else in the future as well.
Thanks again for your help!
#define txPin 4
So, which purpose is pin 4 ACTUALLY serving?
SoftwareSerial is obsolete. You should be using NewSoftSerial, instead.
