I have some old libraries that look like:
const prog_char flModeStr [5][11] PROGMEM = {
" Run ", //0
" Pause ", //1
" Stop ", //2
" Wait ", //3
" Heat ", //4
" "}; //5
const char *flight_mode[] = {
flModeStr[0], flModeStr[1], flModeStr[2], flModeStr[3], flModeStr[4], flModeStr[5]
I figured out that
const char flModeStr [5][11] PROGMEM = {
just works, I am not completely sure if that's how it's supposed to be, if that's fully equvalent.
- but then I have another array :
const prog_uchar sig_pattern[22][40] PROGMEM = {
{ 1,1,1,1,1,1,1,1,1,1 ,1,1,1,1,1,1,1,1,1,1 ,1,1,1,1,1,1,0,0,0,0 ,1,1,1,1,1,1,0,0,0,0},
- but this time the trick of removing "prog_" does not work, "uchar" is not recognized, so "byte" should be correct ?
The sources, with all it's old libraries are still ar from a successfull compilation, so I just needed to verify these two before taking an all the other work..
