hello everyone
I am stuck at some point in data conversion project and need help.
i wan to convert two decimal values to equivalent 12-bit binary values for each decimal values and assign each binary values to digital pins.
i m using arduino mega 2560.
need your help in coding.
thank you
guix
December 23, 2015, 6:32am
2
Hello and welcome,
At least give an example of such decimal numbers and what you expect the output to be.
Such as "123" into 0001 0010 0011 as on/off outputs?
or "789" into 0111 1000 1010?
hello
for example i have decimal 276 and 153 whos equivalent are 000100010100 and 000010011001.
my problem s i have declared local variable x and y which stores processed data (deciamal values), now next step is to convert these decimal values to equivalent 12 bit binary and assign each bit of binary value to digital pins ( i mean 12 * 2 binary values to 24 digital pins).
thank you.
guix
December 23, 2015, 7:19am
5
You don't need to convert anything, a number can be written in different ways:
x = 276; // decimal
x = 0b0000000100010100; // binary
x = 0b100010100; // binary with useless zero's removed
x = 0x114; // hexadecimal
It's all the same number.
To get the value of a bit, use bitRead .
Use a for loop to read the first 12 bits, and write the value of the bit to the digital output of your choice.
For example:
uint16_t x = 276;
for ( uint8_t i = 0; i < 12; i++ )
digitalWrite( i, bitRead(x, i) == 1 ? HIGH : LOW );
that would output:
pin state
0 0
1 0
2 1
3 0
4 1
etc..
Thankq guix
that was so helpful...
appreciate your concern ...
good day
