I am currently building a gps clock with 7 segment displays and I have the utc hour from the gps stored in the variable "hr" how would I convert this to local time? (I live in +6 Central Time Zone but I would like to be able to set it to any time zone). Every thing i have found requires a library to handle the time clock when i just want to do that with the gps.. Any help is appreciated! (I can post the code if you like but I've given pretty much all the info you need here.)
cmk20:
It would be useful to have a date and time variable declaration example and some sample data.
If it is just about time (and not date) you just can add 6 hours and do the hours%24 to get the local time hour.
Besides of that: Many countries use "Daylight Saving Time" (summertime) during the summer months. If you want to have valid "local time" considering summertime setting, you also would have to tell about the summertime rule in your country (if there is one), for developing a function.
Thanks for your replies, I manged to fix it myself... (I missed most of the replies as my emil notifications werent configured... also yes I realize central time is -6)
Heres the code:
I have to variables timezonehr and timezonemn for both minute and hour offsets, i add them to the hr or mn variables and then check if they went over... pretty simple
OK, so if your local time calculation is for the Canadian province of Saskatchewan, you are done. This province in Canada is at Central Standard Time all through the year.
In other areas CST might switch to Central DayLight Time CDT during the summer months (1 hour forward), and in case you want to calculate CDT correctly, you would have to do additional date calculations.
Sensible people!
There is hardly any nationwide practice more wasteful and idiotic than setting/resetting clocks to Daylight Savings Time. At the institution where I work, they actually have two complete sets of clocks, so that twice a year the janitorial staff can replace all the clocks, rather than fiddling with each one.
cmk20:
Heres the code:
What type are hr and mn? Are you using bytes or ints for them?
Is there any current limiting between the 7447A(40mA sink current) or 74LS47(24mA sink current) and the segments of the displays? Good chance you'll burn them out if not.
CrossRoads:
Yes there are resisters on the cathode of each of the displays. I have run the clock for 24 hrs without any problems.
I think you meant Anode. 1 per common anode is better than nothing. If you see brightness variation dependent on the amount of segments that are on, the 1 resistor is the reason.
CrossRoads:
Hmm.... OK that's the reason they dim, its not too bad its only noticeable in a very dark room.
I Am Built A Gps Clock About A Year Ago, The Clock Works However I Am Tired Of Changing The Code Every Dst Change. I Have Looked On The Internet For Answers However I Cant Find Anything That Would Work With My Code
Here's A Picture Of The Clock:
Here Is The Code:
#include <TinyGPS++.h>
TinyGPSPlus gps;
const int timezonehr = -5; //Timezone hour offset
const int timezonemn = 0; //Timezone minute offset
const int d1a = 12; //Lcd Controller Pin Definitions
const int d1b = 11;
const int d1c = 10;
const int d1d = 9;
const int d2a = 7;
const int d2b = 6;
const int d2c = 5;
const int d2d = 4;
const int d3a = 22;
const int d3b = 23;
const int d3c = 24;
const int d3d = 25;
const int d4a = 26;
const int d4b = 27;
const int d4c = 28;
const int d4d = 29;
const int ampmled = 30; //Am/Pm Led Pin
const int numbers[][4] = //Display Codes
{0,0,0,0}, // 0
{0,0,0,1}, // 1
{1,0,0,0}, // 2
{1,0,0,1}, // 3
{0,1,0,0}, // 4
{0,1,0,1}, // 5
{1,1,0,0}, // 6
{1,1,0,1}, // 7
{0,0,1,0}, // 8
{0,0,1,1}, // 9
{1,1,1,1} // Clear
int num[4];
int hr = 0;
int mn = 0;
int oldmn = 0;
void disp(int dispnum,int numtodisplay){ //Function That Displays A Number On A Seleced Display
for (int x = 0; x < 4; x++){ //Loop Through The Number Codes And Store The Correct One In The List Num
num[x] = numbers[numtodisplay][x];
if (dispnum == 1){ //Use A Large If Tree To Display The Number Code Stored In Num
if (num[0] == 1){
digitalWrite(d1a, HIGH);
else{
digitalWrite(d1a, LOW);
if (num[1] == 1){
digitalWrite(d1b, HIGH);
else{
digitalWrite(d1b, LOW);
if (num[2] == 1){
digitalWrite(d1c, HIGH);
else{
digitalWrite(d1c, LOW);
if (num[3] == 1){
digitalWrite(d1d, HIGH);
else{
digitalWrite(d1d, LOW);
if (dispnum == 2){
if (num[0] == 1){
digitalWrite(d2a, HIGH);
else{
digitalWrite(d2a, LOW);
if (num[1] == 1){
digitalWrite(d2b, HIGH);
else{
digitalWrite(d2b, LOW);
if (num[2] == 1){
digitalWrite(d2c, HIGH);
else{
digitalWrite(d2c, LOW);
if (num[3] == 1){
digitalWrite(d2d, HIGH);
else{
digitalWrite(d2d, LOW);
if (dispnum == 3){
if (num[0] == 1){
digitalWrite(d3a, HIGH);
else{
digitalWrite(d3a, LOW);
if (num[1] == 1){
digitalWrite(d3b, HIGH);
else{
digitalWrite(d3b, LOW);
if (num[2] == 1){
digitalWrite(d3c, HIGH);
else{
digitalWrite(d3c, LOW);
if (num[3] == 1){
digitalWrite(d3d, HIGH);
else{
digitalWrite(d3d, LOW);
if (dispnum == 4){
if (num[0] == 1){
digitalWrite(d4a, HIGH);
else{
digitalWrite(d4a, LOW);
if (num[1] == 1){
digitalWrite(d4b, HIGH);
else{
digitalWrite(d4b, LOW);
if (num[2] == 1){
digitalWrite(d4c, HIGH);
else{
digitalWrite(d4c, LOW);
if (num[3] == 1){
digitalWrite(d4d, HIGH);
else{
digitalWrite(d4d, LOW);
pinMode(d1a, OUTPUT); //Set The Display Pins As Outputs
pinMode(d1b, OUTPUT);
pinMode(d1c, OUTPUT);
pinMode(d1d, OUTPUT);
pinMode(d2a, OUTPUT);
pinMode(d2b, OUTPUT);
pinMode(d2c, OUTPUT);
pinMode(d2d, OUTPUT);
pinMode(d3a, OUTPUT);
pinMode(d3b, OUTPUT);
pinMode(d3c, OUTPUT);
pinMode(d3d, OUTPUT);
pinMode(d4a, OUTPUT);
pinMode(d4b, OUTPUT);
pinMode(d4c, OUTPUT);
pinMode(d4d, OUTPUT);
pinMode(ampmled, OUTPUT);
//Serial.begin(9600); //DEBUG
Serial3.begin(9600); //Connect To The Gps Via Serial3
while (Serial3.available()) { //If Data Is Available Form The Gps
gps.encode(Serial3.read()); //Pull Data From The Gps, Then Send It To TinyGps++
if (gps.time.minute() != oldmn) { //If The Minute Changes Update The Display
oldmn = gps.time.hour(); //Store The Current Minute In oldmin To Be Compared To Later
hr = gps.time.hour(); //Pull The Time From TinyGps++
mn = gps.time.minute();
//hr = 0; //DEBUG
//mn = 0; //DEBUG
//The Rest Of The Code Changes The Time Zone, Converts To 12 Hour Am/Pm Time Then Updates The Am/Pm Led And The Displays
mn = mn + timezonemn; //Add The Minute Time Zone Offset
if (mn > 59) { //If The Minute Is Over 59 (From The Time Zone Conversion)
mn = mn - 60; //Subtract 60 From It
hr = hr + 1; //Then Add 1 To The Hour
else {
if (mn < 0) { //If Minute Is Less Than 0, Do The Inverse Of Above
mn = mn + 60;
hr = hr - 1;
hr = hr + timezonehr; //Add The Hour Time Zone Offset
if (hr > 23) { //Do The Same Thing We Did Above
hr = hr - 24;
else {
if (hr < 0) {
hr = hr + 24;
if (hr > 11) { //If The Hour Is Above 11
hr = hr - 12; //Subtract 12 (Thus Converting To 12 Hour Time)
digitalWrite(ampmled, LOW); //Ajust The Am/Pm Led Accordingly
else {
digitalWrite(ampmled, HIGH);
if (hr == 0) { //If The Hour Is 0
hr = 12; //Make It 12 (This Makes Sure When Its 12:XX The Clock Says 12 Not 0)
if (int(hr / 10) == 0) { //If The Hour Is 1 Digit Long
disp(1, 10); //Dont Display Anything On Disp 1 (Ex: If Its 2:30 The Clock Will Display 2:30 Not 02:30)
else {
disp(1, int(hr / 10)); //Otherwise Display A 1
disp(2, int(hr % 10)); //Wirte The Other Numbers To There Respective Displays
disp(3, int(mn / 10));
disp(4, int(mn % 10));
