I got an old cordless drill with PWM control of speed.
The right image is my circuit right now. The motor starts to turn if i only tuch the blue dot pin, and slowly stops. If conect to +5V nothing happens. Any suggestion on how to get this thing going?
It should supposed to be a 25A @ 15Vmax.
Is it possible to control this from Arduino with PWM?
If I am correct, the pins are:
G = Base
D = Collector
S = Emiter
Wright?
Yes possible, but not directly from an arduino output pin. The device is a mosfet that requires normally a +10vdc or higher to insure full on for the mosfet. So you would need a switching transistor to interface from the arduino 0 to +5vdc PWM switching to a 0 to +10 or higher voltage (but stay under the mosfets maximum allowable gate voltage) PWM signal it should work OK. What is the battery voltage run at?
You use a pull-up resistor to connect the Gate to +14.4V and use an NPN transistor to connect the Gate to Ground. When the transistor is OFF the pull-up resistor makes sure the MOSFET is fully ON. Use a 200+Ohm resistor between the Arduino pin and transistor Base to limit Base current.
You will find that the sense of PWM is inverted: 255 is OFF and 0 is FULL ON.
Can you show the full markings on that MOSFET - it may be logic-level in which its simple to interface. If not just replace it with a logic-level MOSFET.
Logic level mosfets have the words "Logic Level" at the start of the datasheet, or have a rating that looks like "Rds(on) = xxx ohms at Vgs=4.5V" (sometimes Vgs=5.0V). If there is only a specification with Vgs=10V then its unlikely to be logic level.
