Hello. I want to hook up a stepper and am a little unsure of what way to plug in the motor wires, and worried about blowing the driver if I do it wrong.
I get continuity between Black & Green, and continuity between Blue & Red, but unsure of what the correct way to connect them to 1A, 1B, 2A, 2B should be.
Noooo! It isn't difficult and you shouldn't have to experiment. Assume:
Black and Green are winding 1
Blue and Red are winding 2
So connect exactly as you have shown.
You may find the motor goes the "wrong" way but then you just reverse the sense of the direction pin, or reverse the connections to ONE of the windings.
So that isn't a coil connection problem. How fast are you trying to drive it? Steppers will stall if driven too fast without any acceleration.
Have you set the coil current? How is it powered? It's often recommended to have a 100uF capacitor added to the Vm pin and Gnd (presumably the neighbouring Arduino Gnd pin) as close as possible to the driver.
As others have said, there are only two combinations. If the step direction is wrong, swap the wires to one coil.
NEVER change wiring with the power connected, as that will instantly destroy the motor driver.
But, it just shudders a little left to right and locks up with some coil noise?
Post the code, using code tags and links to the motor and the motor power supply. Either you have not set the current limit correctly, the power supply is inadequate, or you are trying to step the motor incorrectly or too rapidly.
Do not use the Arduino 5V output for motors, servos, etc. as that will damage the Arduino.
Yes, but find it it a little range as the videos I have seen they can all go over 1V on the Vref pin, I seem to only have a sweep from 0-0.25v on the trim pot. But its set as 600mA in the code.
Via the VCC pin on an Arduino mega power by 12V and getting 12V at the VM pin on the stepper.
Really slow, in the 10s of mm/s as it's for a camera slider.
#include "TimerOne.h"
#include <Encoder.h>
#include <stdint.h>
#define DEBUG
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
//#include <TouchScreen.h>
#include <Adafruit_GFX.h> // Core graphics library
//#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <Fonts/FreeSans9pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans12pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans18pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold24pt7b.h> // Hardware-specific library
//IM - Touch Screen presure
#define MINPRESSURE 10
#define MAXPRESSURE 10000
//IM - Define the limits of the touch screen
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
//IM - TRINAMIC 2130 STEPPER DRIVER
//#include <SPI.h> // SPI FOR SPI COMMS to the 2130 driver
#include <TMC2130Stepper.h>
#include <TMC2130Stepper_REGDEFS.h>
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
//TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
/*#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0*/
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit color values
// Modify these to match the colorspace of your LCD
#define WHITE 0x0000 //
#define YELLOW 0x001F //
#define CYAN 0xF800 //
#define PURPLE 0x07E0 //
#define RED 0x07FF //
#define GREEN 0xF81F //
#define BLUE 0xFFE0 //
#define BLACK 0xFFFF //
#define PIN_BATTVOLT 15
#define STEPSMM 160
//IM - Pins for the Encoder with button. If the encoders running backwards swap enc0 and enc1 pins
#define PIN_BUTTON 19
#define PIN_ENC0 21 //encoder pin 1
#define PIN_ENC1 20 //encoder pin 2
//IM - Stepper Driver Enable Pin
#define PIN_ENABLE 40
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
//IM - Step and direction pin settings for the Stepper driver
#define MAX_SPEED 40 // In timer value
#define MIN_SPEED 1000
#define STALL_VALUE 5 // [-64..63]
#define DEBOUNCE 300
#define MINRUNTIME 10000
//number of battery voltage points
#define LOOKUP 20
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
long day = 86400000; // 86400000 milliseconds in a day
long hour = 3600000; // 3600000 milliseconds in an hour
long minute = 60000; // 60000 milliseconds in a minute
long second = 1000; // 1000 milliseconds in a second
//IM - Instansiate the encoder (on the rotary button) and tell it what pins we have used
Encoder myEnc(PIN_ENC1, PIN_ENC0);
//Config for the Trinamic 2130 set the pins pins
TMC2130Stepper driver = TMC2130Stepper(PIN_ENABLE, PIN_DIR, PIN_STEP, PIN_CS);
long oldPosition = 0;
//long MaxSlide = 73235; //IM - Test value for max slide (aprox 1mtr)
long MaxSlide = 0; //IM - holds the maximum number of steps for the length of the slide rail. Its set during initialisation proccess.
long calSteps = 0; //IM - holds the value of steps whilst performing the calibration.
long RailLength = 0; //IM - holds the value for the lenght of the rail;
float StepsPerMM = 80.3; //IM - the number of steps on my stepper motor that cover 1mm of rail travel.
volatile long numruns = 0;
volatile long period = 10000;
volatile long carragePos = 0; //the absolute carrage position on the slider.
volatile unsigned long lastTriggered = 0;
long nextBattMillis = 0;
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
//IM - Defines the mid point of the touch screen, this will determin the direction of movment, buy pressing either side of this line.
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
byte oldMinutes = 0;
byte oldSeconds = 0;
boolean buttonPressed = false; //Holds the value seeing if the button has been pressed by the user
boolean srunning = false;
boolean sdir = 0; //Bit Direction of travel of the motor
boolean oldsdir = !sdir; //Bit holding the last known Direction of travel of the motor
boolean needsInit = false;
boolean drawnStatusBlank = 1;
boolean drawnStatus = srunning;
boolean driverEnabled = false; //set the default to the stepper driver disabled.
boolean calibratedSlider = false; //sets true if the slider rail has been calibrated to the length.
boolean stall = false; //set the motor stall value to false.
boolean TMC2130enabled = false;
boolean carrageHomed = false; //has the carraged reached its home position (during calibration)
boolean lcdFlipped = false; //has the LCD been installed physically upsidedown?
boolean haltCarrage = false;
boolean countCarrage = true;
boolean carrageHalted = false;
boolean stallSleep = false; //some times we dont want to detect a motor stall, like right after it just happend.
int stallSleepDuration = 1000;
int calibrationStep = 0; //IM - stores the value of the calibrations step 1 - 3. 3 is fully calibrated and homed.
float rawVolt;
float volt;
int checkInerval = 50; //use as a delay to count down too.
void catchButton() {
if (lastTriggered + DEBOUNCE < millis()) {
buttonPressed = true;
lastTriggered = millis();
Serial.print("catchButton: Button Pressed");
//enable the stepper driver
void enableTMC2130() {
Serial.println("enableTMC2130: stepper ENABLED");
digitalWrite(PIN_ENABLE, LOW);
TMC2130enabled = true;
//dissables the stepper driver
void disableTMC2130() {
Serial.println("disableTMC2130: stepper dissabled");
digitalWrite(PIN_ENABLE, HIGH);
//IM - VSense for Trinamic 2130
bool vsense;
//IM - RMS current for Trinamic 2130
uint16_t rms_current(uint8_t CS, float Rsense = 0.11) {
return (float)(CS + 1) / 32.0 * (vsense ? 0.180 : 0.325) / (Rsense + 0.02) / 1.41421 * 1000;
//IM - Sets up the screen based on its physical mounted positon. Some screens may be mounted upsidedown for physical reasons
//this flips the image if required so the screen contents appear the right way up for the user. Other thigs get messed up when
//the screen is flipped round so we must account for that tool, setting the LCDFlipped bool helps track.
void SetScreenOrientation(bool flip) {
if (flip) {
tft.setRotation(3);
lcdFlipped = true;
else {
tft.setRotation(1);
lcdFlipped = false;
//##################################### SETUP #####################################
tft.begin();
if (!ts.begin()) {
Serial.println("Unable to start touchscreen.");
else {
Serial.println("Touchscreen started.");
#ifdef DEBUG
Serial.begin(250000);
Serial.println(F("TFT LCD test"));
Serial.print("TFT size is ");
Serial.print(tft.width());
Serial.print("x");
Serial.println(tft.height());
#endif // DEBUG
Serial.println("Setup Started");
Serial.println("Instansiate TMC2130");
//set TMC2130 config
driver.begin();
driver.rms_current(600); // mA
driver.microsteps(16);
driver.diag1_stall(1);
driver.diag1_active_high(1);
driver.coolstep_min_speed(0xFFFFF); // 20bit max
driver.THIGH(0);
driver.semin(5);
driver.semax(2);
driver.sedn(0b01);
driver.sg_stall_value(STALL_VALUE);
driver.stealthChop(1);
Serial.println("Set stepper interrupt");
// Set stepper interrupt
cli();//stop interrupts
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
//turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bits for 8 prescaler
TCCR1B |= (1 << CS11);// | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
//sei();//allow interrupts
//TMC2130 outputs on (LOW active)
disableTMC2130();
vsense = driver.vsense();
//IM - SET THE STATE OF ALL THE PINS WE WILL BE USING
//IM - Set the pins for the stepper driver
//pinMode(PIN_STEP, OUTPUT); //step pin
//pinMode(PIN_DIR, OUTPUT); //direction pin
//pinMode(PIN_ENABLE, OUTPUT); //enable pin
//IM - Set the initial pin states
digitalWrite(PIN_BUTTON, HIGH); //IM - set the initial state of the button pin to high
digitalWrite(PIN_ENABLE, LOW); //IM - set the initial state enable pin for the stepper driver
/*tft.reset();
uint16_t identifier = tft.readID();
if (identifier == 0x9325) {
#ifdef DEBUG
Serial.println(F("Found ILI9325 LCD driver"));
} else if (identifier == 0x9328) {
Serial.println(F("Found ILI9328 LCD driver"));
} else if (identifier == 0x7575) {
Serial.println(F("Found HX8347G LCD driver"));
} else if (identifier == 0x9341) {
Serial.println(F("Found ILI9341 LCD driver"));
} else if (identifier == 0x8357) {
Serial.println(F("Found HX8357D LCD driver"));
#endif // DEBUG
#ifdef DEBUG
/*Serial.print(F("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.print(F("I try use ILI9341 LCD driver "));
Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));
#endif // DEBUG
identifier = 0x9341;*/
//tft.begin(identifier);
//main timer for the slider application
Timer1.initialize(period); // initialize timer1, and set a 1/2 second period
// Timer1.pwm(9, 512); // setup pwm on pin 9, 50% duty cycle
Timer1.attachInterrupt(callback); // attaches callback() as a timer overflow interrupt
Timer1.stop();
// IM - This is the interupt that will fire when the button is pressed
attachInterrupt(digitalPinToInterrupt(PIN_BUTTON), catchButton, FALLING);
//##################################### LCD ORIENTATION #####################################
//IM - Set the screen orientation. True is normal, False upsideown.
SetScreenOrientation(true);
tft.fillScreen(BLACK);
updateLCDTime(true);
updateLCDStatus();
rawVolt = ((float) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT)) / 5;
volt = toVolt(rawVolt);
//enable the stepper motor.
enableTMC2130();
//IM - Run the stepper motor.
//IM - this runs every half step
void callback()
//IM - If the device has been calibrated we can check we dont hit the end of the rail
if (calibratedSlider) {
//Run the position as a half time
if (countCarrage) {
//if the direction is false then we are moving away from the home position towards MaxSlide
if (sdir == true) {
if (carragePos != MaxSlide) {
//if it does then stop
carragePos++;
else {
haltCarrage = true;
//otherwise were heading for home watch out for 0
if (carragePos != 0) {
carragePos--;
haltCarrage = true;
countCarrage = false;
//IM - Unless halt carrage is true run the slider
if (!haltCarrage) {
numruns++;
digitalWrite(PIN_STEP, digitalRead(PIN_STEP) ^ 1);
if (!carrageHalted) {
Serial.println("############ Carratge halted! ############");
//stopSlider();
catchButton(); //IM - emulate the button being pressed.
carrageHalted = true;
} else //if its not calibrated we'll just hit the buffers.
numruns++;
void stopSlider() {
Serial.println("############ stopSlider! ############");
srunning = 0;
//disableTMC2130();
Timer1.stop();
updateLCDStatus();
//cDir is ture for left false for right. Unless the screen has been flipped
void carrageDirection(bool cDir) {
if (cDir) {
if (oldsdir != cDir) {
digitalWrite(PIN_DIR, 0);
sdir = true;
Serial.print("#################################### Carrage Direction: ####################################");
Serial.println(cDir);
oldsdir = cDir;
updateLcdDirection(cDir);
digitalWrite(PIN_DIR, 1);
sdir = false;
oldsdir = cDir;
ISR(TIMER1_COMPA_vect) {
PORTF |= 1 << 0;
PORTF &= ~(1 << 0);
//##################################### LOOP #####################################
//##################################### Check Endstop Initiailisation #####################################
//if the unit has just been switched on then perform a calibration of the rail.
if (!calibratedSlider) {
Calibrate();
//if the calibration has already been done then
MainLoop();
//calibrate the slider for MAXSlide.
void Calibrate()
//if the carrage hasnt been homed then home it.
if (!carrageHomed) {
HomeCarrage();
if (calibrationStep == 0)
Serial.println("calibration step 1 complete");
calibrationStep = 1;
if (calibrationStep == 1) {
//once the carrage is at home send it all the way to the other end of the rail.
if (MaxSlide == 0) {
SeekEndStop();
Serial.println("calibration step 2 complete");
calibrationStep = 2;
if (calibrationStep == 2) {
HomeCarrage();
Serial.println("calibration step 3 complete");
calibrationStep = 3;
calibratedSlider = true;
carrageDirection(true);
void SeekEndStop() {
//rest the stall value
//IM - only run this part the first time we start this process.
if (!TMC2130enabled)
Serial.println("########### SeekEndStop ###########");
resetStallSleep();
enableTMC2130();
static int cal_last_time = checkInerval;
int StallVal;
//set the carrage direction toward home
if ((cal_last_time--) == 0) //IM - dont run every loop the stepper driver wont like it!
//Serial.println("Calibration Mode");
uint32_t drv_status = driver.DRV_STATUS();
StallVal = (drv_status & SG_RESULT_bm) >> SG_RESULT_bp;
//Serial.println(StallVal);
if (!stallSleep) {
if (StallVal == 0) {
stall = true;
Serial.println("SeekEndStop: stall!");
if (stallSleep) {
decrementStallSleep();
if (!stall) {
digitalWrite(PIN_STEP, HIGH);
delayMicroseconds(100);
digitalWrite(PIN_STEP, LOW);
calSteps++;
if (TMC2130enabled) {
stallSleep = true;
MaxSlide = calSteps;
CalcRailLength();
Serial.print(" ########### Max Slide Found: ");
Serial.print(MaxSlide);
Serial.println(" ########### ");
carragePos = MaxSlide; //as were at the end of the rail then set carrage pos to maxslide.
disableTMC2130();
//IM - Calculates the lenght of the rail based on the number of steps taken before it hit the end (MaxSlide),
//devided by the number of steps taken in one mm (a fixed value up top calculated for our stepper motor).
void CalcRailLength() {
//calculate the rail length in MM
RailLength = MaxSlide / StepsPerMM;
Serial.print(" ########### Rail Length: ");
Serial.print(RailLength);
//psudo timer, allows some clock cycles to happen to delay a redetection of a motor stall.
void decrementStallSleep() {
if (stallSleep) {
Serial.print("Stall Sleep:");
Serial.println(stallSleepDuration);
stallSleepDuration-- ;
if (stallSleepDuration == 0) {
Serial.println("STALL SLEEP END");
stallSleep = false;
//IM - if you know your not stalling out then you can reset the stall sleeper.
void resetStallSleep() {
stall = false;
stallSleep = false;
void HomeCarrage() {
if (!TMC2130enabled) {
Serial.println("########### Home Carrage ###########");
enableTMC2130();
resetStallSleep();
Serial.print("Check Interval: ");
Serial.println(checkInerval);
Serial.print("Stall: ");
Serial.println(stall);
int StallVal;
carrageDirection(false);
//Serial.println("HomeCarrage: here");
if (!stallSleep) {
stall = true;
Serial.println("HomeCarrage: Stall!");
stallSleep = true;
if (stallSleep) {
if (!stall) {
stallSleep = true;
carrageHomed = true;
carragePos = 0; //IM - Where home!
Serial.println(" ########### Homed ############");
//disableTMC2130();
void StartStop() {
Serial.println("if button pressed");
//if the slider is running then enable or dissable the stepper.
if ((sspeed == 0) && (decimals == 0)) {
srunning = 0;
Serial.print("######### StartStop: STOPPED #########");
else {
Serial.print("######### StartStop: STARTED #########");
if (carrageHalted == true) {
srunning = !srunning;
setPeriod();
updateLCDStatus();
void MainLoop() {
static uint32_t last_time = 0;
uint32_t ms = millis();
//##################################### ENCODER AND BUTTON START #####################################
long newPosition = myEnc.read();
if ((newPosition < 0) && (newPosition < offset)) {
offset = newPosition;
newPosition = newPosition - offset;
//IM If the new position of the rotary encoder is different then..
if (newPosition != oldPosition) {
oldPosition = newPosition;
updateRuntime();
//Serial.println(newPosition);
//Serial.print("\n");
setPeriod();
//IM - If the interupt has been triggered by the button being pressed, buttonPressed will be true.
if (buttonPressed) {
StartStop();
//##################################### ENCODER AND BUTTON END #####################################
//##################################### TOUCH SCREEN START #####################################
// a point object holds x y and z coordinates
if (!ts.bufferEmpty())
// Retrieve a point
TS_Point p = ts.getPoint();
// Scale using the calibration #'s
// and rotate coordinate system
/*TSPoint p = ts.getPoint();
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
//if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
if (p.z > ts.pressureThreshhold) {*/
//IM - Map the touch screen relitive to it size
p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
//IM - Print the y position value
//Serial.print("X = "); Serial.print(p.x);
//Serial.print("\tY = "); Serial.print(p.y);
//a temporary variable to store the new direction
int DIR = 0;
//IM - If the new point os less than the mid value then its to the left.
//IM - Note: this depends on physical screen orientation! if it is upside down change < to >.
if (p.x < ts_MID) {
sdir = 0; //IM - Set the direction bit to 0
//IM - Write to the pin the direction value
DIR = 0;
//Serial.println("left");
else {
sdir = 1; //IM - Set the direction bit to 1
DIR = 1;
//Serial.println("right");
//IM - if its a new direction up date the desplay
carrageDirection(sdir);
if (sdir != oldsdir) {
updateLCDStatus();
//##################################### TOUCH SCREEN END #####################################
//##################################### BATTERY STATUS CHECK START #####################################
// if ((long)(millis() - nextBattMillis) >= 0) {
//update Battery status
// nextBattMillis += 10000;
// rawVolt = ((float)analogRead(PIN_BATTVOLT)) * 0.02 + rawVolt * 0.98;
// volt = toVolt(rawVolt);
// tft.setTextColor(WHITE);
// if (volt < 8) {
// tft.setTextColor(GREEN);
// if (volt < 7.2) {
// tft.setTextColor(YELLOW);
// if (volt < 6.5) {
// tft.setTextColor(RED);
// tft.fillRect(0, 110, 150, 22, BLACK);
// tft.setTextSize(1);
// tft.setCursor(0, 130);
// tft.setFont(&FreeSans12pt7b);
// tft.print(mapFloat(volt, 6, 8.4, 0, 100)); tft.print("% ");
// tft.print("volt"); tft.print("V ");
// tft.print("rawVolt"); tft.print("int ");
// Serial.print("Battery Check:"); Serial.print(volt); Serial.print("; "); Serial.println(millis());
//##################################### BATTERY STATUS CHECK END #####################################
void updateLcdDirection(bool d) {
if (!d) {
tft.fillTriangle(
320, 200, // peak
280, 240, // bottom left
320, 240, // bottom right
BLACK);
tft.fillTriangle(
0, 200, // peak
40, 240, // bottom right
tft.color565(255, 0, 50));
else {
tft.fillTriangle(
0, 200, // peak
BLACK);
tft.fillTriangle(
320, 200, // peak
void updateLCDStatus() {
if (runtime < MINRUNTIME) {
if (!drawnStatusBlank) {
tft.fillRect(75, 200, 170, 35, BLACK);
srunning = 0;
drawnStatus = 0;
return;
else if (drawnStatusBlank || (drawnStatus != srunning)) {
tft.setTextSize(1);
tft.setCursor(0, 0);
tft.setFont(&FreeSans18pt7b);
if (srunning) {
tft.setCursor(75, 230);
tft.print("RUNNING");
else {
tft.setCursor(100, 230);
tft.setTextColor(BLUE);
tft.print("READY");
drawnStatusBlank = 0;
//IM Updates the runtime when the rotary encoder is turned.
void updateRuntime() {
if (oldPosition != 0) {
runtime = 1000 * oldPosition * oldPosition / 4;
if (needsInit) {
else {
updateLCDTime(false);
updateLCDStatus();
//IM Updates the LCD with the new run time
void updateLCDTime(boolean firstrun) {
int days = runtime / day ; //number of days
int hours = (runtime % day) / hour; //the remainder from days division (in milliseconds) divided by hours, this gives the full hours
int minutes = ((runtime % day) % hour) / minute ; //and so on...
int seconds = (((runtime % day) % hour) % minute) / second;
tft.setCursor(0, 20);
tft.setTextSize(4);
tft.setFont();
if (oldPosition == 0) {
tft.setCursor(42, 70);
tft.setFont(&FreeMonoBold24pt7b);
tft.setTextSize(2);
tft.fillRect(0, 5, 320, 28, BLACK); //clear time
tft.fillRect(0, 54, 320, 35, BLACK); // clear speed
tft.print("HALT");
srunning = false;
tft.setTextSize(1);
tft.setFont(&FreeMono18pt7b);
tft.setCursor(0, 100);
// tft.print("0 mm/s");
sspeed = 0;
decimals = 0;
needsInit = true;
else {
if (firstrun) {
tft.fillRect(42, 24, 230, 30, BLACK); //clear HALT/STOP
tft.setFont(&FreeMonoBold18pt7b);
tft.setTextSize(1);
//DAYS
if ((days != oldDays) || firstrun) {
tft.setCursor(0, 30);
tft.fillRect(0, 5, 42, 28, BLACK);
if (days < 10) {
tft.print("0");
tft.print(days);
oldDays = days;
//HOURS
if (firstrun) {
tft.print("d");
tft.setCursor(80, 30);
if ((hours != oldHours) || firstrun) {
tft.fillRect(80, 5, 42, 28, BLACK);
if (hours < 10) {
tft.print("0");
tft.print(hours);
oldHours = hours;
//MINUTES
if (firstrun) {
tft.print("h");
tft.setCursor(160, 30);
if ((minutes != oldMinutes) || firstrun) {
tft.fillRect(160, 5, 42, 28, BLACK);
if (minutes < 10) {
tft.print("0");
tft.print(minutes);
oldMinutes = minutes;
//SECONDS
if (firstrun) {
tft.print("m");
tft.setCursor(240, 30);
if ((seconds != oldSeconds) || firstrun) {
tft.fillRect(240, 5, 42, 28, BLACK);
if (seconds < 10) {
tft.print("0");
tft.print(seconds);
oldSeconds = seconds;
if (firstrun) {
tft.print("s");
needsInit = false;
if ((oldPosition + offset) != myEnc.read()) {
return;
tft.setCursor(0, 80);
tft.setTextSize(1);
//IM INTERESTING.speed = distance over time
//sspeed = (1000000) / (runtime);
sspeed = (RailLength * 1000) / (runtime);
if (runtime < (MINRUNTIME * 2)) {
tft.print(sspeed);
tft.print(".");
decimals = ((1000000000) / (runtime)) - (((1000000) / (runtime)) * 1000);
//decimals = ((RailLength*1000000) / (runtime)) - (((RailLength*1000) / (runtime)) * 1000);
if (decimals < 100) {
if (decimals < 10) {
tft.print("0");
tft.print("0");
tft.print(decimals);
tft.print(" mm/s");
//########################### TIMER PERIOD ###############################
void setPeriod() {
Serial.println("########################### set period ########################### ");
if ((runtime < MINRUNTIME) | ! srunning) {
Serial.print("srunning: ");
Serial.println(srunning);
//disableTMC2130();
Timer1.stop();
Serial.print("setPeriod: Timer Stopped");
Serial.print("\n");
else {
//IM - TIMER CODE TO WORKOUT THE RUNNING TIME
enableTMC2130();
//calculate the speed in mm/s by deviding the rail lenght by the desired runtime in microseconds
float ssspeed = (RailLength * 1000) / ((float) runtime);
float sps = ssspeed * (StepsPerMM);
float pperiod = (RailLength * 1000) / sps;
Serial.print("RunTime: ");
Serial.println(runtime);
Serial.print("ssspeed: ");
Serial.println(ssspeed, 7);
Serial.print("RailLength: ");
Serial.println(RailLength * 1000);
Serial.print("sps: ");
Serial.println(sps, 7);
pperiod = ((float)runtime) / ((float)MaxSlide);
Serial.print("setPeriod: ");
Serial.println(pperiod);
Timer1.setPeriod(pperiod * 500);
float toVolt(float rawADC) {
return mapFloat(rawADC, 0, 1023, 0, 10.8); //empirical calibration
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float lookup(float inval, short lut[][2], short clamp) {
float out;
byte i;
for (i = 1; i < LOOKUP; i++)
if (lut[i][0] > inval)
return lut[i - 1][1] + (inval - lut[i - 1][0]) * (lut[i][1] - lut[i - 1][1]) / (lut[i][0] - lut[i - 1][0]);
if (i == LOOKUP) {
return clamp;
Yep, using the VCC pin from the Arduino so the motor is getting 12V from the Powersupply.
