could no seen the output in the ThingSpeak
Hey guys i try to run a project Temperature and Humidity Monitoring over Internet using Arduino UNO.
I am using ESP8266,Arduino UNO & DHT22 and for display Thingspeak Server....
Code:
/* Arduino IOT - Temperature (oC) and Humidity (%) on the web
*Use the DHT-22 sensor to read temperature and humidity values
*Send these values to www.thingSpeak.com with the ESP8266 serial Wifi module */
//Libraires
#include <stdlib.h>
#include <DHT.h>
/------------------------DHT SENSOR------------------------/
#define DHTPIN 2 // DHT data pin connected to Arduino pin 2
#define DHTTYPE DHT22 // DHT 22 (or AM2302)
DHT dht(DHTPIN, DHTTYPE); // Initialize the DHT sensor
/-----------------ESP8266 Serial WiFi Module---------------/
#define SSID "singh family" // "SSID-WiFiname"
#define PASS "smkpp789" // "password"
#define IP "184.106.153.149"// thingspeak.com ip
String msg = "GET /update?key=P5CFVZFRXZ0F6ZQS"; //change it with your key..
//Variables
float temp;
int hum;
String tempC;
int error;
Serial.begin(9600); //or use default 115200.
Serial.println("AT");
delay(5000);
if(Serial.find("OK"))
connectWiFi();
//Read temperature and humidity values from DHT sensor:
start: //label
error=0;
temp = dht.readTemperature();
hum = dht.readHumidity();
char buffer[10];
// there is a useful c function called dtostrf() which will convert a float to a char array
//so it can then be printed easily. The format is: dtostrf(floatvar, StringLengthIncDecimalPoint, numVarsAfterDecimal, charbuf);
tempC = dtostrf(temp, 4, 1, buffer);
updateTemp();
//Resend if transmission is not completed
if (error==1)
goto start; //go to label "start"
delay(60000); //Update every 1 min
void updateTemp(){
String cmd = "AT+CIPSTART="TCP","";
cmd += IP;
cmd += "",80";
Serial.println(cmd);
delay(2000);
if(Serial.find("Error"))
return;
cmd = msg ;
cmd += "&field1="; //field 1 for temperature
cmd += tempC;
cmd += "&field2="; //field 2 for humidity
cmd += String(hum);
cmd += "\r\n";
Serial.print("AT+CIPSEND=");
Serial.println(cmd.length());
if(Serial.find(">"))
Serial.print(cmd);
else{
Serial.println("AT+CIPCLOSE");
//Resend...
error=1;
boolean connectWiFi()
Serial.println("AT+CWMODE=1");
delay(2000);
String cmd="AT+CWJAP="";
cmd+=SSID;
cmd+="","";
cmd+=PASS;
cmd+=""";
delay(5000);
return true;
}else
return false;
ThingSpeak Server: Field device - ThingSpeak IoT
Ref i got : Arduino IOT: Temperature and Humidity ( with ESP8266 - Ardumotive Arduino Greek Playground
not a once it transmit the data
Please guide me.....ASAP
