Could someone explain this waterflow sensor
Hello people of the interwebs.
I have been working a project for the last 10 weeks. I am trying to get let a rgb led strip lightup when a generator is spinned. It worked all fine and dandy. But i wanted to try it with a waterflow sensor instred of a electromotor(thegenerator). And its not working with my orginal code. I got the found some code on the internet and it works but i have no idea how this peace of code works. If someone could explain this peace of code to me that would really help a lot.
this is the image of the waterflow sensor if you were wondering
this is the peace of code that came with it
YF‐ S201 Water Flow Sensor
Water Flow Sensor output processed to read in litres/hour
Adaptation Courtesy: www.hobbytronics.co.uk
volatile int flow_frequency; // Measures flow sensor pulses
unsigned int l_hour; // Calculated litres/hour
unsigned char flowsensor = 2; // Sensor Input
unsigned long currentTime;
unsigned long cloopTime;
void flow () // Interrupt function
   flow_frequency++;
   pinMode(flowsensor, INPUT);
   digitalWrite(flowsensor, HIGH); // Optional Internal Pull-Up
   attachInterrupt(0, flow, RISING); // Setup Interrupt
   sei(); // Enable interrupts
   currentTime = millis();
   cloopTime = currentTime;
void loop ()
   // Every second, calculate and print litres/hour
   if(currentTime >= (cloopTime + 1000))
      cloopTime = currentTime; // Updates cloopTime
      // Pulse frequency (Hz) = 7.5Q, Q is flow rate in L/min.
      l_hour = (flow_frequency * 60 / 7.5); // (Pulse frequency x 60 min) / 7.5Q = flowrate in L/hour
      flow_frequency = 0; // Reset Counter
      Serial.print(l_hour, DEC); // Print litres/hour
      Serial.println(" L/hour");
if you are wondering what my code looks like that i make to control the rgb led strip this is it. If there is anything you say could be done better or could improve please let me know
//generator pins
  int GeneratorPin1 = 2;
  int GeneratorPin2 = A1;
//buttonpin
  int ButtonPin = 1;
//RGB verlichting pins
  #define REDPIN 6
  #define GREENPIN 10
  #define BLUEPIN 11
//include timer & storage of values
  #include <elapsedMillis.h>
  #include <EEPROM.h>
//generator1 values
  int GeneratorValue1 = 0;
  int GeneratorMin1 = 0;
  int GeneratorMax1 = 0;
//generator2 values
  int GeneratorValue2 = 0;
  int GeneratorMin2 = 0;
  int GeneratorMax2 = 0;
//generators saved values
  int GeneratorMax1Save;
  int GeneratorMax2Save;
//button values
  int ButtonCurrent = 0;
  int ButtonCurrent1 = 0;
//set elapsedmillis to time elapsed
  elapsedMillis timeElapsed;
//run void setup 1x
  Serial.print("Pre-Setup Compleet\n");
//in-built led is output-ing
  pinMode(LED_BUILTIN, OUTPUT);
//in-built led is low
  digitalWrite(LED_BUILTIN, LOW);
//Button Input pin
  pinMode(ButtonPin, INPUT);
//RGB Output pin
  pinMode(REDPIN, OUTPUT);
  pinMode(GREENPIN, OUTPUT);
  pinMode(BLUEPIN, OUTPUT);
  Serial.print("Pinmodes Set\n");
//see if data is stored above 0 then skip to
  //Dataread();
//run buttonswitch setup
  ButtonSwitch();
//run calibration setup
  Calibration();
//rerun calibation for other water source
  ButtonSwitch();
  Calibration();
//write data to save variables
  //Datawrite();
  Serial.print("Starting loop\n");
//starts RGB values
  int r, g, b;
//read generator 1 pin value
  GeneratorValue1 = analogRead(GeneratorPin1);
//read generator 2 pin value
  GeneratorValue2 = analogRead(GeneratorPin2);
//remap generator1 value
  int GeneratorValue1map = map(GeneratorValue1, GeneratorMin1, GeneratorMax1, 0, 255);
  int GeneratorValue2map = map(GeneratorValue2, GeneratorMin2, GeneratorMax2, 0, 255);
//constrain generator values
  int GeneratorValue1con = constrain(GeneratorValue1map, 0, 255);
  int GeneratorValue2con = constrain(GeneratorValue2map, 0, 255);
//set rgb values
  r = GeneratorValue1con;
  g = 0;
  b = GeneratorValue2con;
//output rgb values
  analogWrite(REDPIN, r);
  analogWrite(GREENPIN, g);
  analogWrite(BLUEPIN, b);
  Serial.print("red: ");
  Serial.println(r);
  Serial.print("blue: ");
  Serial.println(b);
//read button value
  //if button value changed run resetvalue
  if(ButtonCurrent1 != ButtonCurrent)
  resetvalues();
  Serial.print("resetting");
//delay
  void Calibration()
  Serial.print("Calibration starting\n");
  timeElapsed = 0;
//herhaal codering voor 10000ms
  while (timeElapsed < 10000)
//set generator values met analogread
//set generator max
  if (GeneratorValue1 > GeneratorMax1)
  GeneratorMax1 = GeneratorValue1;
//set generator max
  if (GeneratorValue2 > GeneratorMax2)
  GeneratorMax2 = GeneratorValue2;
  Serial.print("Calibration finished\n");
  Serial.println(GeneratorMax1);
  Serial.println(GeneratorMax2);
  void ButtonSwitch()
  Serial.print("ButtonSwitch started\n");
//set buttoncurrent to high or low
  ButtonCurrent = digitalRead(ButtonPin);
//buttoncurrent en buttoncurrent1 same value
  ButtonCurrent1 = ButtonCurrent;
//run while buttoncurrent is same as buttoncurrent1
  while(ButtonCurrent == ButtonCurrent1)
  Serial.print("Press Button\n");
//while flashing press button
//in-built led high
  digitalWrite(LED_BUILTIN, HIGH);
//read button value
//repeat while buttoncurrent value is same as buttoncurrent1value
  ButtonCurrent1 = digitalRead(ButtonPin);
//wait 1000ms
//sketch finished
  Serial.print("Buttonsetup compleet\n");
  void Datawrite()
//create saveble formate
    GeneratorMax1Save = GeneratorMax1 / 4;
    GeneratorMax2Save = GeneratorMax2 / 4;
//write generatormax
    EEPROM.write(GeneratorMax1, GeneratorMax1Save);
    EEPROM.write(GeneratorMax2, GeneratorMax2Save);
  void Dataread()
  Serial.print("Running dataread\n");
//start reading from the first byte
  byte GeneratorMax1Save;
  byte GeneratorMax2Save;
//generatormax read
  GeneratorMax1Save = EEPROM.read(GeneratorMax1);
  GeneratorMax2Save = EEPROM.read(GeneratorMax2);
  GeneratorMax1 = GeneratorMax1Save * 4;
  GeneratorMax2 = GeneratorMax2Save * 4;
  if (GeneratorMax1 > 0)
    if (GeneratorMax2 > 0)
//run void loop and skip calibration
      loop();
  void resetvalues()
//set time elapsed to 0
  timeElapsed = 0;
//generator1 values
    GeneratorValue2 = analogRead(GeneratorPin1);
//generator2 values
    ButtonSwitch();
    Calibration();
    ButtonSwitch();
    Calibration();
    Datawrite();
  loop();
ps: The electricmotor i have been using the last couple of weeks only has a + and a -, as you can see the waterflow sensor has 3. and i am not sure how to combine the 2 codes to make the waterflow sensor replace the "generators"
If your wandering what am i talking about and i haven't been clear with my post, please let me know, and i will try to make my self more clear.
Also if i write a simple code like
int flowsensor = 2; // Sensor Input
void loop ()
  Serial.print(analogRead(flowsensor));
it just prints 264 L/hour of sometimes 263L/hour at idle. and when it spins it does not have any effect
Piece be unto you, brother.
The flow code uses an interrupt function to count pulses from the sensor, and every second in loop(), computes the number of pulses per second, converts that into liters/hour and prints the result.
AustinBakker:
wrong wiring?
Quote from: AustinBakker on Today at 06:45 am
wrong wiring?
Nope. The simple program is just printing the result of analogRead(), which is meaningless if the sensor switch is open.
