[cod
#include <SPI.h>
#include <LiquidCrystal.h>
// these are the pins used on the shield for this sketch
LiquidCrystal lcd(8, 13, 9, 4, 5, 6, 7);
// variables used on more than 1 function need to be declared here
unsigned long start , finished, elapsed;
boolean running1 = false;
boolean running2 = false;
// Variables for button debounce time
long lastButtonPressTime = 0; // the last time the button was pressed
long debounceDelay = 50; // the debounce time; keep this as low as possible
lcd.begin(16, 2); // inicialize the lcd (16 chars, 2 lines)
// a little introduction :)
lcd.setCursor(4, 0); // set the cursor to first character on line 1 - NOT needed (it sets automatically on lcd.begin()
lcd.print("Arduino");
lcd.setCursor(3, 1); // set the cursor to 4th character on line 2
lcd.print("StopWatch");
delay(2000);
lcd.clear();
lcd.print("Press select for");
lcd.setCursor(2, 1); // set the cursor to 3rd character on line 2
lcd.print("Start & Stop");
CheckStartStop1();
DisplayResult();
void CheckStartStop1()
void CheckStartStop2()
int x = analogRead (0); // assign 'x' to the Arduino's AnalogueInputs (Shield's buttons)
if (x < 800 && x > 600 ) // if the button is SELECT
if ((millis() - lastButtonPressTime) > debounceDelay)
if (running1 == false)
lcd.clear();
lcd.setCursor(3, 0); // needed
lcd.print("Time Past");
start = millis(); // saves start time to calculate the elapsed time
else if (running1 == true)
lcd.setCursor(2, 0); // needed
lcd.print(" Final Time ");
running1 = !running1;
lastButtonPressTime = millis();
void DisplayResult()
finished = millis(); // saves stop time to calculate the elapsed time
// declare variables
float h, m, s, ms;
unsigned long over;
// CheckStartStop1();
DisplayResult();
if (x < 400 && x > 200 ) // if the button is SELECT
if (running2 == false)
lcd.clear();
else if (running2 == true)
running2 = !running2;
float h, m, s, ms;
unsigned long over;
// MATH time!!!
elapsed = finished - start;
h = int(elapsed / 3600000);
over = elapsed % 3600000;
m = int(over / 60000);
over = over % 60000;
s = int(over / 1000);
ms = over % 1000;
// display the results
lcd.setCursor(0, 0);
lcd.print(h, 0); // display variable 'h' - the 0 after it is the number of algorithms after a comma (ex: lcd.print(h, 2); would print 0,00
lcd.print("h "); // and the letter 'h' after it
lcd.print(m, 0);
lcd.print("m ");
lcd.print(s, 0);
lcd.print("s ");
if (h < 10)
//lcd.print(ms, 0);
//lcd.print("ms ");
lcd.setCursor(8, 0);
lcd.print(m, 0);
lcd.print("m ");
lcd.print(s, 0);
lcd.print("s ");
if (h < 10)
//lcd.print(ms, 0);
//lcd.print("ms ");
lcd.setCursor(0, 1);
lcd.print(m, 0);
lcd.print("m ");
lcd.print(s, 0);
lcd.print("s ");
if (h < 10)
//lcd.print(ms, 0);
//lcd.print("ms ");
lcd.setCursor(8, 1);
lcd.print(m, 0);
lcd.print("m ");
lcd.print(s, 0);
lcd.print("s ");
if (h < 10)
//lcd.print(ms, 0);
//lcd.print("ms ");
e][/code]
