I want to make counter up with 7segment and 4511 decoder. I used sketch from https://www.instructables.com/Making-a-7-Segment-Display-Counter-With-BCD-Logic/ that allows running counter from 0 to 99.
My project is when IO-pin connected to button is HIGH >> Start Counting, IO-pin connected to button is LOW >> pause counting and when HIGH again resume counting.
My question is how to modify the code from the sketch that I got?
Here's the code:
//BCD 1
int a1 = 4;
int a2 = 5;
int a3 = 6;
int a4 = 7;
//BCD 2
int b1 = 8;
int b2 = 9;
int b3 = 10;
int b4 = 11;
int n=0; //Setting initial value of n to 0
int d1;
int d2;
int button = 2;
int state = 0;
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
pinMode(11,OUTPUT);
pinMode(button,INPUT);
void loop(){
state = digitalRead(button);
if(state == HIGH)
n++;
if(n==100)
n=0;
d1=n%10; // This will divide n by 10 and the remainder will be stored in d1
d2=n/10; // This will divide n by 10 and the value before decimal will be stored in d2
disp1(d1);
disp2(d2);
delay(100);//100 ms delay to debounce
void disp1(int num){
if(num == 0)//0000
digitalWrite(a1, LOW);
digitalWrite(a2, LOW);
digitalWrite(a3, LOW);
digitalWrite(a4, LOW);
if(num == 1)//0001
digitalWrite(a1, HIGH);
if(num == 2)//0010
digitalWrite(a1, LOW);//0
digitalWrite(a2, HIGH);//1
digitalWrite(a3, LOW);//0
digitalWrite(a4, LOW);//0
if(num == 3)//0011
digitalWrite(a1, HIGH);//1
if(num == 4)//0100
digitalWrite(a2, LOW);//0
digitalWrite(a3, HIGH);//1
if(num == 5)//0101
if(num == 6)//0110
if(num == 7) //0111
if(num == 8) //1000
digitalWrite(a4, HIGH);//1
if(num == 9)//1001
void disp2(int num)
if(num == 0)//0000
digitalWrite(b1, LOW);//
digitalWrite(b2, LOW);//0
digitalWrite(b3, LOW);//0
digitalWrite(b4, LOW);//0
if(num == 1)//0001
digitalWrite(b1, HIGH);//1
if(num == 2)//0010
digitalWrite(b1, LOW);//0
digitalWrite(b2, HIGH);//1
if(num == 3)//0011
if(num == 4)//0100
digitalWrite(b3, HIGH);//1
if(num == 5) //0101
if(num == 6) //0110
if(num == 7) //0111
if(num == 8) //1000
digitalWrite(b4, HIGH);//1
if(num == 9)//1001
Thanks before
